root/radiance/ray/doc/man/man1/rtrace.1
Revision: 1.36
Committed: Wed Oct 19 21:25:20 2022 UTC (2 years, 8 months ago) by greg
Changes since 1.35: +20 -2 lines
1 .\" RCSid "$Id: rtrace.1,v 1.35 2022/10/19 18:23:14 greg Exp $"
2 .TH RTRACE 1 10/17/97 RADIANCE
3 .SH NAME
4 rtrace - trace rays in RADIANCE scene
5 .SH SYNOPSIS
6 .B rtrace
7 [
8 .B options
9 ]
10 [
11 .B $EVAR
12 ]
13 [
14 .B @file
15 ]
16 .B octree
17 .br
18 .B "rtrace [ options ] \-defaults"
19 .br
20 .B "rtrace \-features [feat1 ..]"
21 .SH DESCRIPTION
22 .I Rtrace
23 traces rays from the standard input through the RADIANCE scene given by
24 .I octree
25 and sends the results to the standard output.
26 (The octree may be given as the output of a command enclosed in quotes
27 and preceded by a `!'.)\0
28 Input for each ray is:
29
30 xorg yorg zorg xdir ydir zdir
31
32 If the direction vector is (0,0,0), a bogus record
33 is printed and the output is flushed if the
34 .I -x
35 value is one or zero.
36 (See the notes on this option below.)\0
37 This may be useful for programs that run
38 .I rtrace
39 as a separate process.
40 .PP
41 In the second form shown above, the default values
42 for the options (modified by those options present)
43 are printed with a brief explanation.
44 .PP
45 In the third form, a list of supported features is sent
46 to the standard output, one per line.
47 If additional arguments follow, they are checked for presence in
48 this list.
49 If a feature includes subfeatures, these may be checked as well by
50 specifying:
51 .nf
52
53 rtrace -features FeatName=subfeat1,subfeat2
54
55 .fi
56 If any named feature or subfeature is missing, an error is
57 reported and the program returns an error status.
58 If all of the named features are present, a zero status is returned.
59 .PP
60 Options may be given on the command line and/or read from the
61 environment and/or read from a file.
62 A command argument beginning with a dollar sign ('$') is immediately
63 replaced by the contents of the given environment variable.
64 A command argument beginning with an at sign ('@') is immediately
65 replaced by the contents of the given file.
66 Most options are followed by one or more arguments, which must be
67 separated from the option and each other by white space.
68 The exceptions to this rule are the boolean options.
69 Normally, the appearance of a boolean option causes a feature to
70 be "toggled", that is switched from off to on or on to off
71 depending on its previous state.
72 Boolean options may also be set
73 explicitly by following them immediately with a '+' or '-', meaning
74 on or off, respectively.
75 Synonyms for '+' are any of the characters "yYtT1", and synonyms
76 for '-' are any of the characters "nNfF0".
77 All other characters will generate an error.
78 .TP 10n
79 .BI -f io
80 Format input according to the character
81 .I i
82 and output according to the character
83 .I o.
84 .I Rtrace
85 understands the following input and output formats: 'a' for
86 ascii, 'f' for single-precision floating point,
87 and 'd' for double-precision floating point.
88 In addition to these three choices, the character 'c' may be used
89 to denote 4-byte RGBE (Radiance) color format
90 for the output of individual color values only, and the
91 .I \-x
92 and
93 .I \-y
94 options should also be specified to create a valid output picture.
95 If the output character is missing, the input format is used.
96 .IP
97 Note that there is no space between this option and its argument.
98 .TP
99 .BI -o spec
100 Produce output fields according to
101 .I spec.
102 Characters are interpreted as follows:
103 .IP
104 o origin (input)
105 .IP
106 d direction (normalized)
107 .IP
108 v value (radiance)
109 .IP
110 V contribution (radiance)
111 .IP
112 w weight
113 .IP
114 W color coefficient
115 .IP
116 l effective length of ray
117 .IP
118 L first intersection distance
119 .IP
120 c local (u,v) coordinates
121 .IP
122 p point of intersection
123 .IP
124 n normal at intersection (perturbed)
125 .IP
126 N normal at intersection (unperturbed)
127 .IP
128 s surface name
129 .IP
130 m modifier name
131 .IP
132 M material name
133 .IP
134 r mirrored value contribution
135 .IP
136 x unmirrored value contribution
137 .IP
138 R mirrored ray length
139 .IP
140 X unmirrored ray length
141 .IP
142 ~ tilde (end of trace marker)
143 .IP
144 If the letter 't' appears in
145 .I spec,
146 then the fields following will be printed for every ray traced,
147 not just the final result.
148 If the capital letter 'T' is given instead of 't', then all rays will
149 be reported, including shadow testing rays to light sources.
150 Spawned rays are indented one tab for each level.
151 The tilde marker ('~') is a handy way of differentiating the final ray
152 value from daughter values in a traced ray tree, and usually appears
153 right before the 't' or 'T' output flags.
154 E.g.,
155 .I \-ov~TmW
156 will emit a tilde followed by a tab at the end of each trace,
157 which can be easily distinguished even in binary output.
158 .IP
159 Note that there is no space between this option and its argument.
160 .TP
161 .BI -te \ mod
162 Append
163 .I mod
164 to the trace exclude list,
165 so that it will not be reported by the trace option
166 .I (\-o*t*).
167 Any ray striking an object having
168 .I mod
169 as its modifier will not be reported to the standard output with
170 the rest of the rays being traced.
171 This option has no effect unless either the 't' or 'T'
172 option has been given as part of the output specifier.
173 Any number of excluded modifiers may be given, but each
174 must appear in a separate option.
175 .TP
176 .BI -ti \ mod
177 Add
178 .I mod
179 to the trace include list,
180 so that it will be reported by the trace option.
181 The program can use either an include list or an exclude
182 list, but not both.
183 .TP
184 .BI -tE \ file
185 Same as
186 .I \-te,
187 except read modifiers to be excluded from
188 .I file.
189 The RAYPATH environment variable determines which directories are
190 searched for this file.
191 The modifier names are separated by white space in the file.
192 .TP
193 .BI -tI \ file
194 Same as
195 .I \-ti,
196 except read modifiers to be included from
197 .I file.
198 .TP
199 .BR \-i
200 Boolean switch to compute irradiance rather than radiance values.
201 This only affects the final result, substituting a Lambertian
202 surface and multiplying the radiance by pi.
203 Glass and other transparent surfaces are ignored during this stage.
204 Light sources still appear with their original radiance values,
205 though the
206 .I \-dv
207 option (below) may be used to override this.
208 This option is especially useful in
209 conjunction with ximage(1) for computing irradiance at scene points.
210 .TP
211 .BR \-u
212 Boolean switch to control uncorrelated random sampling.
213 When "off", a low-discrepancy sequence is used, which reduces
214 variance but can result in a brushed appearance in specular highlights.
215 When "on", pure Monte Carlo sampling is used in all calculations.
216 .TP
217 .BR \-I
218 Boolean switch to compute irradiance rather than radiance,
219 with the input origin and direction interpreted instead
220 as measurement point and orientation.
221 .TP
222 .BR \-h
223 Boolean switch for information header on output.
224 .TP
225 .BI -x \ res
226 Set the x resolution to
227 .I res.
228 The output will be flushed after every
229 .I res
230 input rays if
231 .I \-y
232 is set to zero.
233 A value of one means that every ray will be flushed, whatever
234 the setting of
235 .I \-y.
236 A value of zero means that no output flushing will take place.
237 .TP
238 .BI -y \ res
239 Set the y resolution to
240 .I res.
241 The program will exit after
242 .I res
243 scanlines have been processed, where a scanline is the number of rays
244 given by the
245 .I \-x
246 option, or 1 if
247 .I \-x
248 is zero.
249 A value of zero means the program will not halt until the end
250 of file is reached.
251 .IP
252 If both
253 .I \-x
254 and
255 .I \-y
256 options are given, a resolution string is printed at the beginning
257 of the output.
258 This is mostly useful for recovering image dimensions with
259 .I pvalue(1),
260 and for creating valid Radiance picture files using the color output
261 format.
262 (See the
263 .I \-f
264 option, above.)
265 .TP
266 .BI -n \ nproc
267 Execute in parallel on
268 .I nproc
269 local processes.
270 This option is incompatible with the
271 .I \-P
272 and
273 .I \-PP,
274 options.
275 Multiple processes also do not work properly with ray tree output
276 using any of the
277 .I \-o*t*
278 options.
279 There is no benefit from specifying more processes than there are
280 cores available on the system or the
281 .I \-x
282 setting, which forces a wait at each flush.
283 .TP
284 .BI -dj \ frac
285 Set the direct jittering to
286 .I frac.
287 A value of zero samples each source at specific sample points
288 (see the
289 .I \-ds
290 option below), giving a smoother but somewhat less accurate
291 rendering.
292 A positive value causes rays to be distributed over each
293 source sample according to its size, resulting in more accurate
294 penumbras.
295 This option should never be greater than 1, and may even
296 cause problems (such as speckle) when the value is smaller.
297 A warning about aiming failure will issued if
298 .I frac
299 is too large.
300 .TP
301 .BI -ds \ frac
302 Set the direct sampling ratio to
303 .I frac.
304 A light source will be subdivided until
305 the width of each sample area divided by the distance
306 to the illuminated point is below this ratio.
307 This assures accuracy in regions close to large area sources
308 at a slight computational expense.
309 A value of zero turns source subdivision off, sending at most one
310 shadow ray to each light source.
311 .TP
312 .BI -dt \ frac
313 Set the direct threshold to
314 .I frac.
315 Shadow testing will stop when the potential contribution of at least
316 the next and at most all remaining light sources is less than
317 this fraction of the accumulated value.
318 (See the
319 .I \-dc
320 option below.)
321 The remaining light source contributions are approximated
322 statistically.
323 A value of zero means that all light sources will be tested for shadow.
324 .TP
325 .BI \-dc \ frac
326 Set the direct certainty to
327 .I frac.
328 A value of one guarantees that the absolute accuracy of the direct calculation
329 will be equal to or better than that given in the
330 .I \-dt
331 specification.
332 A value of zero only insures that all shadow lines resulting in a contrast
333 change greater than the
334 .I \-dt
335 specification will be calculated.
336 .TP
337 .BI -dr \ N
338 Set the number of relays for virtual sources to
339 .I N.
340 A value of 0 means that virtual sources will be ignored.
341 A value of 1 means that sources will be made into first generation
342 virtual sources; a value of 2 means that first generation
343 virtual sources will also be made into second generation virtual
344 sources, and so on.
345 .TP
346 .BI -dp \ D
347 Set the virtual source presampling density to D.
348 This is the number of samples per steradian
349 that will be used to determine ahead of time whether or not
350 it is worth following shadow rays through all the reflections and/or
351 transmissions associated with a virtual source path.
352 A value of 0 means that the full virtual source path will always
353 be tested for shadows if it is tested at all.
354 .TP
355 .BR \-dv
356 Boolean switch for light source visibility.
357 With this switch off, sources will be black when viewed directly
358 although they will still participate in the direct calculation.
359 This option is mostly for the program
360 .I mkillum(1)
361 to avoid inappropriate counting of light sources, but it
362 may also be desirable in conjunction with the
363 .I \-i
364 option.
365 .TP
366 .BI -ss \ samp
367 Set the specular sampling to
368 .I samp.
369 For values less than 1, this is the degree to which the highlights
370 are sampled for rough specular materials.
371 A value greater than one causes multiple ray samples to be sent
372 to reduce noise at a commmesurate cost.
373 A value of zero means that no jittering will take place, and all
374 reflections will appear sharp even when they should be diffuse.
375 .TP
376 .BI -st \ frac
377 Set the specular sampling threshold to
378 .I frac.
379 This is the minimum fraction of reflection or transmission, under which
380 no specular sampling is performed.
381 A value of zero means that highlights will always be sampled by
382 tracing reflected or transmitted rays.
383 A value of one means that specular sampling is never used.
384 Highlights from light sources will always be correct, but
385 reflections from other surfaces will be approximated using an
386 ambient value.
387 A sampling threshold between zero and one offers a compromise between image
388 accuracy and rendering time.
389 .TP
390 .BR -bv
391 Boolean switch for back face visibility.
392 With this switch off, back faces of all objects will be invisible
393 to view rays.
394 This is dangerous unless the model was constructed such that
395 all surface normals face outward.
396 Although turning off back face visibility does not save much
397 computation time under most circumstances, it may be useful as a
398 tool for scene debugging, or for seeing through one-sided walls from
399 the outside.
400 .TP
401 .BI -av " red grn blu"
402 Set the ambient value to a radiance of
403 .I "red grn blu".
404 This is the final value used in place of an
405 indirect light calculation.
406 If the number of ambient bounces is one or greater and the ambient
407 value weight is non-zero (see
408 .I -aw
409 and
410 .I -ab
411 below), this value may be modified by the computed indirect values
412 to improve overall accuracy.
413 .TP
414 .BI -aw \ N
415 Set the relative weight of the ambient value given with the
416 .I -av
417 option to
418 .I N.
419 As new indirect irradiances are computed, they will modify the
420 default ambient value in a moving average, with the specified weight
421 assigned to the initial value given on the command and all other
422 weights set to 1.
423 If a value of 0 is given with this option, then the initial ambient
424 value is never modified.
425 This is the safest value for scenes with large differences in
426 indirect contributions, such as when both indoor and outdoor
427 (daylight) areas are visible.
428 .TP
429 .BI -ab \ N
430 Set the number of ambient bounces to
431 .I N.
432 This is the maximum number of diffuse bounces computed by the indirect
433 calculation. A value of zero implies no indirect calculation.
434 .IP
435 This value defaults to 1 in photon mapping mode (see
436 .I -ap
437 below), implying that global photon irradiance is always computed via
438 .I one
439 ambient bounce; this behaviour applies to any positive number of ambient
440 bounces, regardless of the actual value specified. A negative value enables
441 a preview mode that directly visualises the irradiance from the global
442 photon map without any ambient bounces.
443 .TP
444 .BI -ar \ res
445 Set the ambient resolution to
446 .I res.
447 This number will determine the maximum density of ambient values
448 used in interpolation.
449 Error will start to increase on surfaces spaced closer than
450 the scene size divided by the ambient resolution.
451 The maximum ambient value density is the scene size times the
452 ambient accuracy (see the
453 .I \-aa
454 option below) divided by the ambient resolution.
455 The scene size can be determined using
456 .I getinfo(1)
457 with the
458 .I \-d
459 option on the input octree.
460 .TP
461 .BI -aa \ acc
462 Set the ambient accuracy to
463 .I acc.
464 This value will approximately equal the error
465 from indirect irradiance interpolation.
466 A value of zero implies no interpolation.
467 .TP
468 .BI -ad \ N
469 Set the number of ambient divisions to
470 .I N.
471 The error in the Monte Carlo calculation of indirect
472 irradiance will be inversely proportional to the square
473 root of this number.
474 A value of zero implies no indirect calculation.
475 .TP
476 .BI -as \ N
477 Set the number of ambient super-samples to
478 .I N.
479 Super-samples are applied only to the ambient divisions which
480 show a significant change.
481 .TP
482 .BI -af \ fname
483 Set the ambient file to
484 .I fname.
485 This is where indirect irradiance will be stored and retrieved.
486 Normally, indirect irradiance values are kept in memory and
487 lost when the program finishes or dies.
488 By using a file, different invocations can share irradiance
489 values, saving time in the computation.
490 The ambient file is in a machine-independent binary format
491 which can be examined with
492 .I lookamb(1).
493 .IP
494 The ambient file may also be used as a means of communication and
495 data sharing between simultaneously executing processes.
496 The same file may be used by multiple processes, possibly running on
497 different machines and accessing the file via the network (ie.
498 .I nfs(4)).
499 The network lock manager
500 .I lockd(8)
501 is used to insure that this information is used consistently.
502 .IP
503 If any calculation parameters are changed or the scene
504 is modified, the old ambient file should be removed so that
505 the calculation can start over from scratch.
506 For convenience, the original ambient parameters are listed in the
507 header of the ambient file.
508 .I Getinfo(1)
509 may be used to print out this information.
510 .TP
511 .BI -ae \ mod
512 Append
513 .I mod
514 to the ambient exclude list,
515 so that it will not be considered during the indirect calculation.
516 This is a hack for speeding the indirect computation by
517 ignoring certain objects.
518 Any object having
519 .I mod
520 as its modifier will get the default ambient
521 level rather than a calculated value.
522 Any number of excluded modifiers may be given, but each
523 must appear in a separate option.
524 .TP
525 .BI -ai \ mod
526 Add
527 .I mod
528 to the ambient include list,
529 so that it will be considered during the indirect calculation.
530 The program can use either an include list or an exclude
531 list, but not both.
532 .TP
533 .BI -aE \ file
534 Same as
535 .I \-ae,
536 except read modifiers to be excluded from
537 .I file.
538 The RAYPATH environment variable determines which directories are
539 searched for this file.
540 The modifier names are separated by white space in the file.
541 .TP
542 .BI -aI \ file
543 Same as
544 .I \-ai,
545 except read modifiers to be included from
546 .I file.
547 .TP
548 .BI -ap " file [bwidth1 [bwidth2]]"
549 Enable photon mapping mode. Loads a photon map generated with
550 .I mkpmap(1)
551 from
552 .I file,
553 and evaluates the indirect irradiance depending on the photon type
554 (automagically detected) using density estimates with a bandwidth of
555 .I bwidth1
556 photons, or the default bandwidth if none is specified (a warning will be
557 issued in this case).
558 .IP
559 Global photon irradiance is evaluated as part of the ambient calculation (see
560 .I \-ab
561 above), caustic photon irradiance is evaluated at primary rays, and
562 indirect inscattering in
563 .I mist
564 is accounted for by volume photons. Contribution photons are treated as
565 global photons by
566 .I rtrace.
567 .IP
568 Additionally specifying
569 .I bwidth2
570 enables bias compensation for the density estimates with a
571 minimum and maximum bandwidth of
572 .I bwidth1
573 and
574 .I bwidth2,
575 respectively.
576 .IP
577 Global photon irradiance may be optionally precomputed by
578 .I mkpmap(1),
579 in which case the bandwidth, if specified, is ignored, as the nearest photon
580 is invariably looked up.
581 .IP
582 Using direct photons replaces the direct calculation with density estimates
583 for debugging and validation of photon emission.
584 .TP
585 .BI -am " frac"
586 Maximum search radius for photon map lookups. Without this option, an
587 initial maximum search radius is estimated for each photon map from the
588 average photon distance to the distribution's centre of gravity. It is then
589 adapted to the photon density in subsequent lookups. This option imposes a
590 global fixed maximum search radius for
591 .I all
592 photon maps, thus defeating the automatic adaptation. It is useful when
593 multiple warnings about short photon lookups are issued. Note that this
594 option does not conflict with the bandwidth specified with the
595 .I \-ap
596 option; the number of photons found will not exceed the latter, but may be
597 lower if the maximum search radius contains fewer photons, thus resulting in
598 short lookups. Setting this radius too large, on the other hand, may
599 degrade performance.
600 .TP
601 .BI -ac " pagesize"
602 Set the photon cache page size when using out-of-core photon mapping. The
603 photon cache reduces disk I/O incurred by on-demand loading (paging) of
604 photons, and thus increases performance. This
605 is expressed as a (float) multiple of the density estimate bandwidth
606 specified with
607 .I \-ap
608 under the assumption that photon lookups are local to a cache page. Cache
609 performance is sensitive to this parameter: larger pagesizes will reduce the
610 paging frequency at the expense of higher latency when paging does occur.
611 Sensible values are in the range 4 (default) to 16.
612 .TP
613 .BI -aC " cachesize"
614 Set the total number of photons cached when using out-of-core photon
615 mapping, taking into account the pagesize specified by
616 .I \-ac.
617 Note that this is approximate as the number of cache pages is rounded to
618 the nearest prime. This allows adapting the cache to the available physical
619 memory. In conjunction with the
620 .I \-n
621 option, this is the cache size
622 .I per parallel process.
623 Cache performance is less sensitive to this parameter,
624 and reasonable performance can obtained with as few as 10k photons. The
625 default is 1M. This option recognises multiplier suffixes (k = 1e3, M =
626 1e6), both in upper and lower case.
627 .TP
628 .BI -me " rext gext bext"
629 Set the global medium extinction coefficient to the indicated color,
630 in units of 1/distance (distance in world coordinates).
631 Light will be scattered or absorbed over distance according to
632 this value.
633 The ratio of scattering to total scattering plus absorption is set
634 by the albedo parameter, described below.
635 .TP
636 .BI -ma " ralb galb balb"
637 Set the global medium albedo to the given value between 0\00\00
638 and 1\01\01.
639 A zero value means that all light not transmitted by the medium
640 is absorbed.
641 A unitary value means that all light not transmitted by the medium
642 is scattered in some new direction.
643 The isotropy of scattering is determined by the Heyney-Greenstein
644 parameter, described below.
645 .TP
646 .BI \-mg \ gecc
647 Set the medium Heyney-Greenstein eccentricity parameter to
648 .I gecc.
649 This parameter determines how strongly scattering favors the forward
650 direction.
651 A value of 0 indicates perfectly isotropic scattering.
652 As this parameter approaches 1, scattering tends to prefer the
653 forward direction.
654 .TP
655 .BI \-ms \ sampdist
656 Set the medium sampling distance to
657 .I sampdist,
658 in world coordinate units.
659 During source scattering, this will be the average distance between
660 adjacent samples.
661 A value of 0 means that only one sample will be taken per light
662 source within a given scattering volume.
663 .TP
664 .BI -lr \ N
665 Limit reflections to a maximum of
666 .I N,
667 if N is a positive integer.
668 If
669 .I N
670 is zero or negative, then Russian roulette is used for ray
671 termination, and the
672 .I -lw
673 setting (below) must be positive.
674 If N is a negative integer, then this limits the maximum
675 number of reflections even with Russian roulette.
676 In scenes with dielectrics and total internal reflection,
677 a setting of 0 (no limit) may cause a stack overflow.
678 .TP
679 .BI -lw \ frac
680 Limit the weight of each ray to a minimum of
681 .I frac.
682 During ray-tracing, a record is kept of the estimated contribution
683 (weight) a ray would have in the image.
684 If this weight is less than the specified minimum and the
685 .I -lr
686 setting (above) is positive, the ray is not traced.
687 Otherwise, Russian roulette is used to
688 continue rays with a probability equal to the ray weight
689 divided by the given
690 .I frac.
691 .TP
692 .BR -ld
693 Boolean switch to limit ray distance.
694 If this option is set, then rays will only be traced as far as the
695 magnitude of each direction vector.
696 Otherwise, vector magnitude is ignored and rays are traced to infinity.
697 .TP
698 .BI -e \ efile
699 Send error messages and progress reports to
700 .I efile
701 instead of the standard error.
702 .TP
703 .BR \-w
704 Boolean switch to suppress warning messages.
705 .TP
706 .BI \-P \ pfile
707 Execute in a persistent mode, using
708 .I pfile
709 as the control file.
710 Persistent execution means that after reaching end-of-file on
711 its input,
712 .I rtrace
713 will fork a child process that will wait for another
714 .I rtrace
715 command with the same
716 .I \-P
717 option to attach to it.
718 (Note that since the rest of the command line options will be those
719 of the original invocation, it is not necessary to give any arguments
720 besides
721 .I \-P
722 for subsequent calls.)
723 Killing the process is achieved with the
724 .I kill(1)
725 command.
726 (The process ID in the first line of
727 .I pfile
728 may be used to identify the waiting
729 .I rtrace
730 process.)
731 This option may be used with the
732 .I \-fr
733 option of
734 .I pinterp(1)
735 to avoid the cost of starting up
736 .I rtrace
737 many times.
738 .TP
739 .BI \-PP \ pfile
740 Execute in continuous-forking persistent mode, using
741 .I pfile
742 as the control file.
743 The difference between this option and the
744 .I \-P
745 option described above is the creation of multiple duplicate
746 processes to handle any number of attaches.
747 This provides a simple and reliable mechanism of memory sharing
748 on most multiprocessing platforms, since the
749 .I fork(2)
750 system call will share memory on a copy-on-write basis.
751 .SH NOTES
752 Photons are generally surface bound (an exception are volume photons), thus
753 the ambient irradiance in photon mapping mode will be biased at positions
754 which do not lie on a surface.
755 .SH EXAMPLES
756 To compute radiance values for the rays listed in samples.inp:
757 .IP "" .2i
758 rtrace \-ov scene.oct < samples.inp > radiance.out
759 .PP
760 To compute irradiance values at locations selected with the 't'
761 command of
762 .I ximage(1):
763 .IP "" .2i
764 ximage scene.hdr | rtrace \-h \-x 1 \-i scene.oct | rcalc \-e '$1=47.4*$1+120*$2+11.6*$3'
765 .PP
766 To record the object identifier corresponding to each pixel in an image:
767 .IP "" .2i
768 vwrays \-fd scene.hdr | rtrace \-fda `vwrays \-d scene.hdr` \-os scene.oct
769 .PP
770 To compute an image with an unusual view mapping:
771 .IP "" .2i
772 cnt 480 640 | rcalc \-e 'xr:640;yr:480' \-f unusual_view.cal | rtrace
773 \-x 640 \-y 480 \-fac scene.oct > unusual.hdr
774 .PP
775 To compute ambient irradiance in photon mapping mode from a global photon
776 map global.pm via one ambient bounce, and from a caustic photon map
777 caustic.pm at sensor positions in samples.inp:
778 .IP "" .2i
779 rtrace -h -ov -ab 1 -ap global.pm 50 -ap caustic.pm 50 scene.oct <
780 samples.inp > illum.out
781 .SH ENVIRONMENT
782 RAYPATH the directories to check for auxiliary files.
783 .SH FILES
784 /tmp/rtXXXXXX common header information for picture sequence
785 .SH DIAGNOSTICS
786 If the program terminates from an input related error, the exit status
787 will be 1.
788 A system related error results in an exit status of 2.
789 If the program receives a signal that is caught, it will exit with a status
790 of 3.
791 In each case, an error message will be printed to the standard error, or
792 to the file designated by the
793 .I \-e
794 option.
795 .SH AUTHOR
796 Greg Ward
797 .SH "SEE ALSO"
798 getinfo(1), lookamb(1), mkpmap(1), oconv(1), pfilt(1), pinterp(1),
799 pvalue(1), rcontrib(1), rsplit(1),
800 rpict(1), rtpict(1), rvu(1), vwrays(1), ximage(1)
