1 |
.\" RCSid "$Id: rtpict.1,v 1.11 2022/04/11 04:03:36 greg Exp $" |
2 |
.TH RTPICT 1 3/19/2018 RADIANCE |
3 |
.SH NAME |
4 |
rtpict - generate a RADIANCE picture or layered image using rtrace |
5 |
.SH SYNOPSIS |
6 |
.B rtpict |
7 |
.B "-n nproc" |
8 |
9 |
.B "-o[vrxlLRXnNsmM] out_dir" |
10 |
11 |
.B "-d ref_depth/unit" |
12 |
13 |
14 |
.B "rpict options" |
15 |
16 |
17 |
.B @file |
18 |
19 |
.B octree |
20 |
.SH DESCRIPTION |
21 |
.I Rtpict |
22 |
is a script that generates a picture from the RADIANCE scene given in |
23 |
.I octree |
24 |
and sends it to the standard output, or to a file specified with the |
25 |
.I \-o |
26 |
option. |
27 |
Most options and defaults are the same as |
28 |
.I rpict(1), |
29 |
although a few switches are silently ignored. |
30 |
Options incompatible with multi-processing can generate an error. |
31 |
.PP |
32 |
The |
33 |
.I rtrace(1) |
34 |
tool is called with |
35 |
.I vwrays(1) |
36 |
to perform the actual work. |
37 |
This enables the |
38 |
.I \-n |
39 |
option for multiprocessing on platforms that support it. |
40 |
If the |
41 |
.I \-n |
42 |
option is not specified or is set to 1, then |
43 |
.I rpict |
44 |
is called directly. |
45 |
There is no benefit in setting the number of processes to anything |
46 |
greater than the number of virtual cores available on your machine. |
47 |
Also, it is very important to set the |
48 |
.I \-af |
49 |
option if an irradiance cache is being generated; |
50 |
otherwise, your speed-up will be far from linear. |
51 |
.PP |
52 |
If the |
53 |
.I \-o |
54 |
option has additional characters corresponding to output types from |
55 |
.I rtrace, |
56 |
it must be followed by the name of a directory that either exists or |
57 |
will be created to contain image layers, one per output type. |
58 |
The supported types are listed below, and do not include types that |
59 |
are useless or have no convenient representation. |
60 |
The table below shows the correspondence between output type and file name |
61 |
in the specified directory: |
62 |
.sp |
63 |
.nf |
64 |
v radiance.hdr |
65 |
r r_refl.hdr |
66 |
x r_unrefl.hdr |
67 |
l d_effective.dpt |
68 |
L d_firstsurf.dpt |
69 |
R d_refl.dpt |
70 |
X d_unrefl.dpt |
71 |
n perturbed.nrm |
72 |
N unperturbed.nrm |
73 |
s surface.idx |
74 |
m modifier.idx |
75 |
M material.idx |
76 |
.fi |
77 |
.sp |
78 |
Different encodings are associated with different data types. |
79 |
Color data (from the 'v', 'r', and 'x' types) will be converted to |
80 |
a flat RGBE picture by |
81 |
.I pvalue(1). |
82 |
Distances (from the 'l', 'L', 'R', and 'X' types) will be |
83 |
converted to a 16-bit representation by |
84 |
.I rcode_depth(1), |
85 |
and the |
86 |
.I \-d |
87 |
option should be used to assign the reference (median) depth and world |
88 |
units, which applies to the overall scene. |
89 |
Surface normals (from the 'n' and 'N' types) will be converted |
90 |
to a 32-bit representation by |
91 |
.I rcode_norm(1). |
92 |
Finally, identifiers (from the 's', 'm', and 'M' types) will be |
93 |
converted to a 16-bit index format by |
94 |
.I rcode_ident(1). |
95 |
.PP |
96 |
If the |
97 |
.I \-i |
98 |
option is used to turn on irradiane output, then the picture associated |
99 |
with the 'v' type will be renamed |
100 |
.I "irradiance.hdr" |
101 |
and some other output types become irrelevant (i.e., 'r', 'x', 'R', and 'X'). |
102 |
If one or more of the associated output files already exists in the |
103 |
destination directory, an error will be printed and the command will abort. |
104 |
.SH EXAMPLES |
105 |
To render a scene with four processes: |
106 |
.IP "" .2i |
107 |
rtpict -n 4 -vf mypers.vf -ab 1 -af scene.amb scene.oct > scene_pers.hdr |
108 |
.PP |
109 |
To render radiance, first surface distance, and normals in a layered image: |
110 |
.IP "" .2i |
111 |
rtpict -n 8 -vf fish.vf @render.opt -ovLn fisholay scene.oct |
112 |
.SH AUTHOR |
113 |
Greg Ward |
114 |
.SH "SEE ALSO" |
115 |
getinfo(1), mkpmap(1), oconv(1), pfilt(1), |
116 |
pvalue(1), rad(1), rcode_depth(1), rcode_norm(1), rcode_ident(1), |
117 |
rcrop(1), rpiece(1), rpict(1), rsplit(1), rtrace(1), rvu(1), vwrays(1) |
