--- ray/doc/man/man1/rtpict.1 2018/03/20 18:03:52 1.2 +++ ray/doc/man/man1/rtpict.1 2020/05/06 14:23:18 1.6 @@ -1,11 +1,16 @@ -.\" RCSid "$Id: rtpict.1,v 1.2 2018/03/20 18:03:52 greg Exp $" +.\" RCSid "$Id: rtpict.1,v 1.6 2020/05/06 14:23:18 greg Exp $" .TH RTPICT 1 3/19/2018 RADIANCE .SH NAME -rtpict - generate a RADIANCE picture using rtrace +rtpict - generate a RADIANCE picture or layerd image using rtrace .SH SYNOPSIS .B rtpict .B "-n nproc" [ +.B "-o[vrxlLRXnNsmM] out_dir" +][ +.B "-d ref_depth/unit" +] +[ .B "rpict options" ] [ @@ -43,13 +48,89 @@ Also, it is very important to set the .I \-af option if an irradiance cache is being generated; otherwise, your speed-up will be far from linear. -.SH EXAMPLE +.PP +If the +.I \-o +option has additional characters corresponding to output types from +.I rtrace, +it must be followed by the name of a directory that either exists or +will be created to contain image layers, one per output type. +The supported types are listed below, and do not include types that +are useless or have no convenient representation. +The table below shows the correspondence between output type and file name +in the specified directory: +.sp +.nf +v radiance.hdr +r r_refl.hdr +x r_unrefl.hdr +l d_effective.dpt +L d_firstsurf.dpt +R d_refl.dpt +X d_unrefl.dpt +n perturbed.nrm +N unperturbed.nrm +s surface.idx +m modifier.idx +M material.idx +.fi +.sp +Different encodings are associated with different data types. +Color data (from the 'v', 'r', and 'x' types) will be converted to +a flat RGBE picture by +.I pvalue(1). +Distances (from the 'l', 'L', 'R', and 'X' types) will be +converted to a 16-bit representation by +.I rcode_depth(1), +and the +.I \-d +option should be used to assign the reference (median) depth and world +units, which applies to the overall scene. +Surface normals (from the 'n' and 'N' types) will be converted +to a 32-bit representation by +.I rcode_normal(1). +Finally, identifiers (from the 's', 'm', and 'M' types) will be +converted to a 16-bit index format by +.I rcode_ident(1). +.PP +If the +.I \-i +option is used to turn on irradiane output, then the picture associated +with the 'v' type will be renamed +.I "irradiance.hdr" +and some other output types become irrelevant (i.e., 'r', 'x', 'R', and 'X'). +If one or more of the associated output files already exists in the +destination directory, it will be overwritten with the new data. +.SH EXAMPLES To render a scene with four processes: .IP "" .2i rtpict -n 4 -vf mypers.vf -ab 1 -af scene.amb scene.oct > scene_pers.hdr +.PP +To render radiance, first surface distance, and normals in a layered image: +.IP "" .2i +rtpict -n 8 -vf fish.vf @render.opt -ovLn fisholay scene.oct +.SH NOTES +Users should seriously consider using +.I rpiece(1) +when irradiance caching is employed with a shared ambient file. +If +.I rtpict +is used in multiprocessing mode with a shared irradiance cache, +it is trying to compute almost +the same part of the same scanline in different processes, which +results in many redundant calculations. +The +.I rpiece +program avoids this by working on separate tiles in each +process, with less overlap in the indirect irradiance calculation. +Either program will benefit from an "overture" run of a +single-process rpict to create the ambient file using a low-resolution +rendering that is discarded, but this will not completely solve the +problem for +.I rtpict. .SH AUTHOR Greg Ward .SH "SEE ALSO" -getinfo(1), lookamb(1), mkpmap(1), oconv(1), pdfblur(1), pfilt(1), -pinterp(1), pmblur(1), printf(3), ra_rgbe(1), rad(1), rpiece(1), -rpict(1), rtrace(1), rvu(1) vwrays(1), +getinfo(1), mkpmap(1), oconv(1), pfilt(1), +pvalue(1), rad(1), rcode_depth(1), rcode_normal(1), rcode_ident(1), +rpiece(1), rpict(1), rsplit(1), rtrace(1), rvu(1), vwrays(1),
