--- ray/doc/man/man1/rtpict.1 2019/07/23 18:17:54 1.3 +++ ray/doc/man/man1/rtpict.1 2023/12/12 17:18:27 1.15 @@ -1,11 +1,13 @@ -.\" RCSid "$Id: rtpict.1,v 1.3 2019/07/23 18:17:54 greg Exp $" +.\" RCSid "$Id: rtpict.1,v 1.15 2023/12/12 17:18:27 greg Exp $" .TH RTPICT 1 3/19/2018 RADIANCE .SH NAME -rtpict - generate a RADIANCE picture or layerd image using rtrace +rtpict - generate a RADIANCE picture, hyperspectral image, or layers using rtrace .SH SYNOPSIS .B rtpict .B "-n nproc" [ +.B -co +][ .B "-o[vrxlLRXnNsmM] out_dir" ][ .B "-d ref_depth/unit" @@ -19,18 +21,22 @@ rtpict - generate a RADIANCE picture or layerd image u .B octree .SH DESCRIPTION .I Rtpict -is a script that generates a picture from the RADIANCE scene given in +is a script that generates a picture or hyperspectral image +from the RADIANCE scene given in .I octree and sends it to the standard output, or to a file specified with the .I \-o option. Most options and defaults are the same as .I rpict(1), -although a few switches are silently ignored. -Options incompatible with multi-processing can generate an error. +although a few options are silently ignored, and the +.I rtrace(1) +.I \-co +boolean switch is supported. +Options incompatible with multi-processing may generate an error. .PP The -.I rtrace(1) +.I rtrace tool is called with .I vwrays(1) to perform the actual work. @@ -62,12 +68,12 @@ in the specified directory: .sp .nf v radiance.hdr -r mirrored.hdr -x unmirrored.hdr -l effective.dpt -L firstsurface.dpt -R mirrored.dpt -X unmirrored.dpt +r r_refl.hdr +x r_unrefl.hdr +l d_effective.dpt +L d_firstsurf.dpt +R d_refl.dpt +X d_unrefl.dpt n perturbed.nrm N unperturbed.nrm s surface.idx @@ -78,16 +84,26 @@ M material.idx Different encodings are associated with different data types. Color data (from the 'v', 'r', and 'x' types) will be converted to a flat RGBE picture by -.I pvalue(1). +.I pvalue(1), +unless the +.I \-co+ +option is specified and +.I \-cs +is greater than 3. +In this case, a hyperspectral image will be generated for each +of the value types, converted by +.I rcomb(1) +and with its suffix set to ".hsr" rather than ".hdr". Distances (from the 'l', 'L', 'R', and 'X' types) will be converted to a 16-bit representation by .I rcode_depth(1), and the .I \-d -option should be used to assign the reference (median) depth and units. +option should be used to assign the reference (median) depth and world +units, which applies to the overall scene. Surface normals (from the 'n' and 'N' types) will be converted to a 32-bit representation by -.I rcode_normal(1). +.I rcode_norm(1). Finally, identifiers (from the 's', 'm', and 'M' types) will be converted to a 16-bit index format by .I rcode_ident(1). @@ -97,9 +113,12 @@ If the option is used to turn on irradiane output, then the picture associated with the 'v' type will be renamed .I "irradiance.hdr" -and some other output types become irrelevant (i.e., 'r', 'x', 'R', and 'X'). +or +.I "irradiance.hsr" +and some other output types become irrelevant +(i.e., 'r', 'x', 'R', and 'X'). If one or more of the associated output files already exists in the -destination directory, it will be overwritten with the new data. +destination directory, an error will be printed and the command will abort. .SH EXAMPLES To render a scene with four processes: .IP "" .2i @@ -108,9 +127,14 @@ rtpict -n 4 -vf mypers.vf -ab 1 -af scene.amb scene.oc To render radiance, first surface distance, and normals in a layered image: .IP "" .2i rtpict -n 8 -vf fish.vf @render.opt -ovLn fisholay scene.oct +.PP +To render a hyperspectral irradiance image with 18 spectral samples: +.IP "" .2i +rtpict -vf inside.vf -i+ -cs 18 -co+ scene.oct > scene_inside.hsr .SH AUTHOR Greg Ward .SH "SEE ALSO" getinfo(1), mkpmap(1), oconv(1), pfilt(1), -pvalue(1), rad(1), rcode_depth(1), rcode_normal(1), rcode_ident(1), -rpiece(1), rpict(1), rsplit(1), rtrace(1), rvu(1), vwrays(1), +pvalue(1), rad(1), rcode_depth(1), rcode_norm(1), rcode_ident(1), +rcomb(1), rcrop(1), rmtxop(1), +rpiece(1), rpict(1), rsplit(1), rtrace(1), rvu(1), vwrays(1)
