--- ray/doc/man/man1/rtpict.1 2023/01/05 19:25:21 1.12 +++ ray/doc/man/man1/rtpict.1 2023/12/12 16:31:45 1.14 @@ -1,11 +1,13 @@ -.\" RCSid "$Id: rtpict.1,v 1.12 2023/01/05 19:25:21 greg Exp $" +.\" RCSid "$Id: rtpict.1,v 1.14 2023/12/12 16:31:45 greg Exp $" .TH RTPICT 1 3/19/2018 RADIANCE .SH NAME -rtpict - generate a RADIANCE picture or layered image using rtrace +rtpict - generate a RADIANCE picture, hyperspectral image, or layers using rtrace .SH SYNOPSIS .B rtpict .B "-n nproc" [ +.B -co +][ .B "-o[vrxlLRXnNsmM] out_dir" ][ .B "-d ref_depth/unit" @@ -19,18 +21,22 @@ rtpict - generate a RADIANCE picture or layered image .B octree .SH DESCRIPTION .I Rtpict -is a script that generates a picture from the RADIANCE scene given in +is a script that generates a picture or hyperspectral image +from the RADIANCE scene given in .I octree and sends it to the standard output, or to a file specified with the .I \-o option. Most options and defaults are the same as .I rpict(1), -although a few switches are silently ignored. -Options incompatible with multi-processing can generate an error. +although a few options are silently ignored, and the +.I rtrace(1) +.I \-co +boolean switch is supported. +Options incompatible with multi-processing may generate an error. .PP The -.I rtrace(1) +.I rtrace tool is called with .I vwrays(1) to perform the actual work. @@ -78,7 +84,16 @@ M material.idx Different encodings are associated with different data types. Color data (from the 'v', 'r', and 'x' types) will be converted to a flat RGBE picture by -.I pvalue(1). +.I pvalue(1), +unless the +.I \-co+ +option is specified and +.I \-cs +is greater than 3. +In this case, a hyperspectral image will be generated for each +of the value types, converted by +.I rcomb(1) +and with its suffix set to ".hsr" rather than ".hdr". Distances (from the 'l', 'L', 'R', and 'X' types) will be converted to a 16-bit representation by .I rcode_depth(1), @@ -98,7 +113,10 @@ If the option is used to turn on irradiane output, then the picture associated with the 'v' type will be renamed .I "irradiance.hdr" -and some other output types become irrelevant (i.e., 'r', 'x', 'R', and 'X'). +or +.I "irradiance.hsr" +and some other output types become irrelevant +(i.e., 'r', 'x', 'R', and 'X'). If one or more of the associated output files already exists in the destination directory, an error will be printed and the command will abort. .SH EXAMPLES @@ -109,9 +127,14 @@ rtpict -n 4 -vf mypers.vf -ab 1 -af scene.amb scene.oc To render radiance, first surface distance, and normals in a layered image: .IP "" .2i rtpict -n 8 -vf fish.vf @render.opt -ovLn fisholay scene.oct +.PP +To render a hyperspectral irradiance image with 18 spectral samples: +.IP "" .2i +rtpict -vf inside.vf -cs 18 -co+ scene.oct > scene_inside.hsr .SH AUTHOR Greg Ward .SH "SEE ALSO" getinfo(1), mkpmap(1), oconv(1), pfilt(1), pvalue(1), rad(1), rcode_depth(1), rcode_norm(1), rcode_ident(1), -rcrop(1), rpiece(1), rpict(1), rsplit(1), rtrace(1), rvu(1), vwrays(1) +rcomb(1), rcrop(1), rmtxop(1), +rpiece(1), rpict(1), rsplit(1), rtrace(1), rvu(1), vwrays(1)
