root/radiance/ray/doc/man/man1/rtpict.1
Revision: 1.16
Committed: Wed Jun 4 20:32:24 2025 UTC (2 weeks, 6 days ago) by greg
Changes since 1.15: +2 -2 lines
feat(rxpiece): Added rxpiece to standard distribution
# User Rev Content
1 greg 1.16 .\" RCSid "$Id: rtpict.1,v 1.15 2023/12/12 17:18:27 greg Exp $"
2 greg 1.1 .TH RTPICT 1 3/19/2018 RADIANCE
3     .SH NAME
4 greg 1.13 rtpict - generate a RADIANCE picture, hyperspectral image, or layers using rtrace
5 greg 1.1 .SH SYNOPSIS
6     .B rtpict
7 greg 1.2 .B "-n nproc"
8 greg 1.1 [
9 greg 1.13 .B -co
10     ][
11 greg 1.3 .B "-o[vrxlLRXnNsmM] out_dir"
12     ][
13     .B "-d ref_depth/unit"
14     ]
15     [
16 greg 1.1 .B "rpict options"
17     ]
18     [
19     .B @file
20     ]
21     .B octree
22     .SH DESCRIPTION
23     .I Rtpict
24 greg 1.13 is a script that generates a picture or hyperspectral image
25     from the RADIANCE scene given in
26 greg 1.1 .I octree
27     and sends it to the standard output, or to a file specified with the
28     .I \-o
29     option.
30     Most options and defaults are the same as
31     .I rpict(1),
32 greg 1.13 although a few options are silently ignored, and the
33     .I rtrace(1)
34     .I \-co
35     boolean switch is supported.
36     Options incompatible with multi-processing may generate an error.
37 greg 1.1 .PP
38     The
39 greg 1.13 .I rtrace
40 greg 1.1 tool is called with
41     .I vwrays(1)
42     to perform the actual work.
43     This enables the
44     .I \-n
45     option for multiprocessing on platforms that support it.
46     If the
47     .I \-n
48     option is not specified or is set to 1, then
49     .I rpict
50     is called directly.
51     There is no benefit in setting the number of processes to anything
52     greater than the number of virtual cores available on your machine.
53     Also, it is very important to set the
54     .I \-af
55     option if an irradiance cache is being generated;
56     otherwise, your speed-up will be far from linear.
57 greg 1.3 .PP
58     If the
59     .I \-o
60     option has additional characters corresponding to output types from
61     .I rtrace,
62     it must be followed by the name of a directory that either exists or
63     will be created to contain image layers, one per output type.
64     The supported types are listed below, and do not include types that
65     are useless or have no convenient representation.
66     The table below shows the correspondence between output type and file name
67     in the specified directory:
68     .sp
69     .nf
70     v radiance.hdr
71 greg 1.4 r r_refl.hdr
72     x r_unrefl.hdr
73     l d_effective.dpt
74     L d_firstsurf.dpt
75     R d_refl.dpt
76     X d_unrefl.dpt
77 greg 1.3 n perturbed.nrm
78     N unperturbed.nrm
79     s surface.idx
80     m modifier.idx
81     M material.idx
82     .fi
83     .sp
84     Different encodings are associated with different data types.
85     Color data (from the 'v', 'r', and 'x' types) will be converted to
86     a flat RGBE picture by
87 greg 1.13 .I pvalue(1),
88     unless the
89     .I \-co+
90     option is specified and
91     .I \-cs
92     is greater than 3.
93     In this case, a hyperspectral image will be generated for each
94     of the value types, converted by
95 greg 1.14 .I rcomb(1)
96 greg 1.13 and with its suffix set to ".hsr" rather than ".hdr".
97 greg 1.3 Distances (from the 'l', 'L', 'R', and 'X' types) will be
98     converted to a 16-bit representation by
99     .I rcode_depth(1),
100     and the
101     .I \-d
102 greg 1.5 option should be used to assign the reference (median) depth and world
103     units, which applies to the overall scene.
104 greg 1.3 Surface normals (from the 'n' and 'N' types) will be converted
105     to a 32-bit representation by
106 greg 1.12 .I rcode_norm(1).
107 greg 1.3 Finally, identifiers (from the 's', 'm', and 'M' types) will be
108     converted to a 16-bit index format by
109     .I rcode_ident(1).
110     .PP
111     If the
112     .I \-i
113     option is used to turn on irradiane output, then the picture associated
114     with the 'v' type will be renamed
115     .I "irradiance.hdr"
116 greg 1.13 or
117     .I "irradiance.hsr"
118     and some other output types become irrelevant
119     (i.e., 'r', 'x', 'R', and 'X').
120 greg 1.3 If one or more of the associated output files already exists in the
121 greg 1.8 destination directory, an error will be printed and the command will abort.
122 greg 1.3 .SH EXAMPLES
123 greg 1.1 To render a scene with four processes:
124     .IP "" .2i
125     rtpict -n 4 -vf mypers.vf -ab 1 -af scene.amb scene.oct > scene_pers.hdr
126 greg 1.3 .PP
127     To render radiance, first surface distance, and normals in a layered image:
128     .IP "" .2i
129     rtpict -n 8 -vf fish.vf @render.opt -ovLn fisholay scene.oct
130 greg 1.13 .PP
131     To render a hyperspectral irradiance image with 18 spectral samples:
132     .IP "" .2i
133 greg 1.15 rtpict -vf inside.vf -i+ -cs 18 -co+ scene.oct > scene_inside.hsr
134 greg 1.1 .SH AUTHOR
135     Greg Ward
136     .SH "SEE ALSO"
137 greg 1.3 getinfo(1), mkpmap(1), oconv(1), pfilt(1),
138 greg 1.12 pvalue(1), rad(1), rcode_depth(1), rcode_norm(1), rcode_ident(1),
139 greg 1.14 rcomb(1), rcrop(1), rmtxop(1),
140 greg 1.16 rpiece(1), rpict(1), rsplit(1), rtrace(1), rvu(1), rxpiece(1), vwrays(1)
