1 |
.\" RCSid "$Id: rtcontrib.1,v 1.2 2005/05/26 18:53:04 greg Exp $" |
2 |
.TH RTCONTRIB 1 5/25/05 RADIANCE |
3 |
.SH NAME |
4 |
rtcontrib - compute contributions in a RADIANCE scene |
5 |
.SH SYNOPSIS |
6 |
.B rtcontrib |
7 |
8 |
.B "\-n nprocs" |
9 |
10 |
.B "\-e expr" |
11 |
12 |
.B "\-f source" |
13 |
14 |
.B "\-o fspec" |
15 |
16 |
.B "\-b binv" |
17 |
18 |
.B "\-m mod .." |
19 |
20 |
.B $EVAR |
21 |
22 |
23 |
.B @file |
24 |
25 |
26 |
rtrace options |
27 |
28 |
.B octree |
29 |
.SH DESCRIPTION |
30 |
.I Rtcontrib |
31 |
computes ray contributions (i.e., color coefficients) |
32 |
for objects whose modifiers are named in one or more |
33 |
.I \-m |
34 |
settings. |
35 |
These modifiers are usually materials associated with |
36 |
light sources or sky domes, and must directly modify some geometric |
37 |
primitives to be considered in the output. |
38 |
The output of |
39 |
.I rtcontrib |
40 |
has many potential uses. |
41 |
Source contributions can be used as components in linear combination to |
42 |
reproduce any desired variation, e.g., simulating lighting controls or |
43 |
changing sky conditions via daylight coefficients. |
44 |
More generally, |
45 |
.I rtcontrib |
46 |
can be used to compute arbitrary input-output relationships in optical |
47 |
systems, such as luminaires, light pipes, and shading devices. |
48 |
.PP |
49 |
.I Rtcontrib |
50 |
calls |
51 |
.I rtrace(1) |
52 |
to calculate the contributions for each input ray, |
53 |
and the output tallies are sent to one or more files according to the |
54 |
.I \-o |
55 |
specification. |
56 |
If an output specification contains a "%s" format, this will be |
57 |
replaced by the modifier name. |
58 |
The |
59 |
.I \-b |
60 |
option may be used to further define |
61 |
a "bin number" within each object if finer resolution is needed, and |
62 |
this will be applied to a "%d" format in the output file |
63 |
specification if present. |
64 |
The actual bin number is computed at run time based on ray direction |
65 |
and surface intersection, as described below. |
66 |
The most recent |
67 |
.I \-b |
68 |
and |
69 |
.I \-o |
70 |
options to the left of each |
71 |
.I \-m |
72 |
setting affect only that modifier. |
73 |
(The ordering of other options is unimportant.)\0 |
74 |
.PP |
75 |
If a |
76 |
.I \-b |
77 |
expression is defined for a particular modifier, |
78 |
the bin number will be evaluated at run time for each |
79 |
ray contribution from |
80 |
.I rtrace. |
81 |
Specifically, each ray's world intersection point will be assigned to |
82 |
the variables Px, Py, and Pz, and the normalized ray direction |
83 |
will be assigned to Dx, Dy, and Dz. |
84 |
These parameters may be combined with definitions given in |
85 |
.I \-e |
86 |
arguments and files read using the |
87 |
.I \-f |
88 |
option. |
89 |
The computed bin value will be |
90 |
rounded to the nearest whole number. |
91 |
This mechanism allows the user to define precise regions or directions |
92 |
they wish to accumulate, such as the Tregenza sky discretization, |
93 |
which would be otherwise impossible to specify |
94 |
as a set of RADIANCE primitives. |
95 |
The rules and predefined functions available for these expressions are |
96 |
described in the |
97 |
.I rcalc(1) |
98 |
man page. |
99 |
.PP |
100 |
If no |
101 |
.I \-o |
102 |
specification is given, results are written on the standard output in order |
103 |
of modifier (as given on the command line) then bin number. |
104 |
Concatenated data is also sent to a lone output file (i.e., an initial |
105 |
.I \-o |
106 |
specification without formatting strings). |
107 |
If a "%s" format appears but no "%d" in the |
108 |
.I \-o |
109 |
specification, then each modifier will have its own output file, with |
110 |
multiple values per record in the case of a non-zero |
111 |
.I \-b |
112 |
definition. |
113 |
If a "%d" format appears but no "%s", then each bin will get its own |
114 |
output file, with modifiers output in order in each record. |
115 |
For text output, each RGB coefficient triple is separated by a tab, |
116 |
with a newline at the end of each ray record. |
117 |
For binary output formats, there is no such delimiter to mark |
118 |
the end of each record. |
119 |
.PP |
120 |
Input and output format defaults to plain text, where each ray's |
121 |
origin and direction (6 real values) are given on input, |
122 |
and one line is produced per output file per ray. |
123 |
Alternative data representations may be specified by the |
124 |
.I \-f[io] |
125 |
option, which is described in the |
126 |
.I rtrace |
127 |
man page along with the associated |
128 |
.I \-x |
129 |
and |
130 |
.I \-y |
131 |
resolution settings. |
132 |
In particular, the color ('c') output data representation |
133 |
together with positive dimensions for |
134 |
.I \-x |
135 |
and |
136 |
.I \-y |
137 |
will produce an uncompressed RADIANCE picture, |
138 |
suitable for manipulation with |
139 |
.I pcomb(1) |
140 |
and related tools. |
141 |
.PP |
142 |
If the |
143 |
.I \-n |
144 |
option is specified with a value greater than 1, multiple |
145 |
.I rtrace |
146 |
processes will be used to accelerate computation on a shared |
147 |
memory machine. |
148 |
Note that there is no benefit to using more processes |
149 |
than there are local CPUs available to do the work, and the |
150 |
.I rtcontrib |
151 |
process itself may use a considerable amount of CPU time. |
152 |
.PP |
153 |
Options may be given on the command line and/or read from the |
154 |
environment and/or read from a file. |
155 |
A command argument beginning with a dollar sign ('$') is immediately |
156 |
replaced by the contents of the given environment variable. |
157 |
A command argument beginning with an at sign ('@') is immediately |
158 |
replaced by the contents of the given file. |
159 |
.SH EXAMPLES |
160 |
To compute the proportional contributions from sources modified |
161 |
by "light1" vs. "light2" on a set of illuminance values: |
162 |
.IP "" .2i |
163 |
rtcontrib -I+ @render.opt -o c_%s.dat -m light1 -m light2 scene.oct < test.dat |
164 |
.PP |
165 |
To generate a pair of images corresponding to these two lights' |
166 |
contributions: |
167 |
.IP "" .2i |
168 |
vwrays -ff -x 1024 -y 1024 -vf best.vf | |
169 |
rtcontrib -ffc `vwrays -d -x 1024 -y 1024 -vf best.vf` |
170 |
@render.opt -o c_%s.pic -m light1 -m light2 scene.oct |
171 |
.PP |
172 |
These images may then be recombined using the desired outputs |
173 |
of light1 and light2: |
174 |
.IP "" .2i |
175 |
pcomb -c 100 90 75 c_light1.pic -c 50 55 57 c_light2.pic > combined.pic |
176 |
.PP |
177 |
To compute an array of illuminance contributions according to a Tregenza sky: |
178 |
.IP "" .2i |
179 |
rtcontrib -b tbin -o sky.dat -m skyglow -b 0 -o ground.dat -m groundglow |
180 |
@render.opt -f tregenza.cal scene.oct < test.dat |
181 |
.SH AUTHOR |
182 |
Greg Ward |
183 |
.SH "SEE ALSO" |
184 |
cnt(1), getinfo(1), pcomb(1), pfilt(1), ra_rgbe(1), |
185 |
rcalc(1), rpict(1), rtrace(1), vwrays(1), ximage(1) |
