root/Development/ray/doc/man/man1/rtcontrib.1
Revision 1.24
Thu Jun 14 22:42:21 2012 UTC (13 years, 6 months ago) by greg
Changes since 1.23: +1 -1 lines
FILE REMOVED
Sun Sep 26 15:51:14 2010 UTC (15 years, 2 months ago) by greg
Diff to previous 1.22 , to selected 1.8
Sun Jun 14 18:21:58 2009 UTC (16 years, 6 months ago) by greg
Changes since 1.21: +8 -2 lines
Diff to previous 1.21 , to selected 1.8
Added ability to specify constant name in rtcontrib -bn option
Sun Jun 14 00:33:15 2009 UTC (16 years, 6 months ago) by greg
Changes since 1.20: +2 -2 lines
Diff to previous 1.20 , to selected 1.8
Mon Nov 10 19:08:17 2008 UTC (17 years, 1 month ago) by greg
Diff to previous 1.19 , to selected 1.8
Mon Oct 6 23:00:53 2008 UTC (17 years, 2 months ago) by greg
Diff to previous 1.18 , to selected 1.8
Fixed wording regarding -x and -y options with -c 0
Fri Apr 18 18:06:29 2008 UTC (17 years, 8 months ago) by greg
Changes since 1.17: +34 -29 lines
Diff to previous 1.17 , to selected 1.8
Modified rtcontrib -c option to accumulate a specified number of rays
Sat Nov 17 01:13:50 2007 UTC (18 years, 1 month ago) by greg
Changes since 1.16: +34 -3 lines
Diff to previous 1.16 , to selected 1.8
Added -c option to rtcontrib (barely tested, and -r does not work)
Tue Sep 4 17:36:41 2007 UTC (18 years, 3 months ago) by greg
Changes since 1.15: +10 -10 lines
Diff to previous 1.15 , to selected 1.8
Added backslashes in front of hyphens (thanks to Bernd Zeimetz for his effort)
Sun Feb 5 22:22:20 2006 UTC (19 years, 10 months ago) by greg
Changes since 1.14: +33 -3 lines
Diff to previous 1.14 , to selected 1.8
Added -V option to rtcontrib and -oV option to rtrace to report contributions
Tue Oct 11 16:54:26 2005 UTC (20 years, 2 months ago) by greg
Changes since 1.13: +8 -3 lines
Diff to previous 1.13 , to selected 1.8
Added rtcontrib -fo option to override new reluctance to clobber existing files
Thu Oct 6 16:28:59 2005 UTC (20 years, 2 months ago) by greg
Changes since 1.12: +6 -3 lines
Diff to previous 1.12 , to selected 1.8
Fixes in new rtcontrib -bn option
Thu Oct 6 05:49:44 2005 UTC (20 years, 2 months ago) by greg
Changes since 1.11: +9 -2 lines
Diff to previous 1.11 , to selected 1.8
Sat Jul 23 19:53:36 2005 UTC (20 years, 4 months ago) by greg
Diff to previous 1.10 , to selected 1.8
Minor fix in example
Fri Jun 10 20:53:55 2005 UTC (20 years, 6 months ago) by greg
Changes since 1.9: +6 -4 lines
Diff to previous 1.9 , to selected 1.8
Fixed it so rtcontrib -M option searches RAYPATH directories
Fri Jun 10 16:42:10 2005 UTC (20 years, 6 months ago) by greg
Changes since 1.8: +9 -2 lines
Diff to previous 1.8
Added rtcontrib -M option to read modifier list from a file
Revision 1.8 - (view) (download) (annotate) - [selected]
Thu Jun 9 17:27:27 2005 UTC (20 years, 6 months ago) by greg
Changes since 1.7: +6 -2 lines
Diff to previous 1.7
Thu Jun 2 04:47:26 2005 UTC (20 years, 6 months ago) by greg
Changes since 1.6: +8 -4 lines
Diff to previous 1.6 , to selected 1.8
Wed Jun 1 16:11:01 2005 UTC (20 years, 6 months ago) by greg
Changes since 1.5: +11 -1 lines
Diff to previous 1.5 , to selected 1.8
Fri May 27 19:15:28 2005 UTC (20 years, 6 months ago) by greg
Changes since 1.4: +5 -4 lines
Diff to previous 1.4 , to selected 1.8
Wording tweaks
Thu May 26 21:03:22 2005 UTC (20 years, 6 months ago) by greg
Diff to previous 1.3 , to selected 1.8
Added -defaults invocation to synopsis
Thu May 26 19:19:19 2005 UTC (20 years, 6 months ago) by greg
Changes since 1.2: +17 -9 lines
Diff to previous 1.2 , to selected 1.8
More wording fixes
Thu May 26 18:53:04 2005 UTC (20 years, 6 months ago) by greg
Changes since 1.1: +82 -126 lines
Diff to previous 1.1 , to selected 1.8
Finished basic man page
Thu May 26 06:55:22 2005 UTC (20 years, 6 months ago) by greg
Diff to selected 1.8
