--- ray/doc/man/man1/rtcontrib.1 2008/04/18 18:06:29 1.18 +++ ray/doc/man/man1/rtcontrib.1 2010/09/26 15:51:14 1.23 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: rtcontrib.1,v 1.18 2008/04/18 18:06:29 greg Exp $" +.\" RCSid "$Id: rtcontrib.1,v 1.23 2010/09/26 15:51:14 greg Exp $" .TH RTCONTRIB 1 5/25/05 RADIANCE .SH NAME rtcontrib - compute contribution coefficients in a RADIANCE scene @@ -166,6 +166,12 @@ If the number of bins is known in advance, it should b .I \-bn option, and this is critical for output files containing multiple values per record. +A variable or constant name may be given for this parameter if +it has been defined via a previous +.I \-f +or +.I \-e +option. Since bin numbers start from 0, the bin count is always equal to the last bin plus 1. Set the this value to 0 if the bin count is unknown (the default). @@ -176,14 +182,14 @@ and .I \-o options to the left of each .I \-m -setting affect only that modifier. +setting are the ones used for that modifier. The ordering of other options is unimportant, except for .I \-x and .I \-y if the .I \-c -is present, when they control the resolution string +is 0, when they control the resolution string produced in the corresponding output. .PP If a @@ -276,12 +282,12 @@ contributions: .IP "" .2i vwrays \-ff \-x 1024 \-y 1024 \-vf best.vf | rtcontrib \-ffc `vwrays \-d \-x 1024 \-y 1024 \-vf best.vf` -@render.opt \-o c_%s.pic \-m light1 \-m light2 scene.oct +@render.opt \-o c_%s.hdr \-m light1 \-m light2 scene.oct .PP These images may then be recombined using the desired outputs of light1 and light2: .IP "" .2i -pcomb \-c 100 90 75 c_light1.pic \-c 50 55 57 c_light2.pic > combined.pic +pcomb \-c 100 90 75 c_light1.hdr \-c 50 55 57 c_light2.hdr > combined.hdr .PP To compute an array of illuminance contributions according to a Tregenza sky: .IP "" .2i @@ -292,5 +298,5 @@ RAYPATH path to search for \-f and \-M files .SH AUTHOR Greg Ward .SH "SEE ALSO" -cnt(1), getinfo(1), pcomb(1), pfilt(1), ra_rgbe(1), -rcalc(1), rpict(1), rtrace(1), total(1), vwrays(1), ximage(1) +cnt(1), genklemsamp(1), getinfo(1), pcomb(1), pfilt(1), ra_rgbe(1), +rcalc(1), rpict(1), rsensor(1), rtrace(1), total(1), vwrays(1), ximage(1)
