--- ray/doc/man/man1/rtcontrib.1 2005/05/26 18:53:04 1.2 +++ ray/doc/man/man1/rtcontrib.1 2005/06/10 16:42:10 1.9 @@ -1,21 +1,26 @@ -.\" RCSid "$Id: rtcontrib.1,v 1.2 2005/05/26 18:53:04 greg Exp $" -.TH RPIECE 1 5/25/05 RADIANCE +.\" RCSid "$Id: rtcontrib.1,v 1.9 2005/06/10 16:42:10 greg Exp $" +.TH RTCONTRIB 1 5/25/05 RADIANCE .SH NAME -rtcontrib - compute contributions in a RADIANCE scene +rtcontrib - compute contribution coefficients in a RADIANCE scene .SH SYNOPSIS .B rtcontrib [ .B "\-n nprocs" ][ +.B \-r +][ .B "\-e expr" ][ .B "\-f source" ][ -.B "\-o fspec" +.B "\-o ospec" ][ .B "\-b binv" ] -.B "\-m mod .." +{ +.B "\-m mod | \-M file" +} +.. [ .B $EVAR ] @@ -26,6 +31,8 @@ rtcontrib - compute contributions in a RADIANCE scene rtrace options ] .B octree +.br +.B "rtcontrib [ options ] \-defaults" .SH DESCRIPTION .I Rtcontrib computes ray contributions (i.e., color coefficients) @@ -35,21 +42,35 @@ settings. These modifiers are usually materials associated with light sources or sky domes, and must directly modify some geometric primitives to be considered in the output. -The computed contributions can then be used in linear combination to +A modifier list may also be read from a file using the +.I \-M +option. +.PP +The output of +.I rtcontrib +has many potential uses. +Source contributions can be used as components in linear combination to reproduce any desired variation, e.g., simulating lighting controls or changing sky conditions via daylight coefficients. More generally, .I rtcontrib -may be used to compute input-output relationships in optical -systems, such as light pipes and shading devices. +can be used to compute arbitrary input-output relationships in optical +systems, such as luminaires, light pipes, and shading devices. .PP .I Rtcontrib calls .I rtrace(1) -to calculate the contributions for each input ray, -and the output tallies are sent to one or more files according to the +with the -oTW option to calculate the daughter ray +contributions for each input ray, and the output tallies +are sent to one or more destinations according to the given .I \-o specification. +If a destination begins with an exclamation mark ('!'), then +a pipe is opened to a command and data is sent to its standard input. +Otherwise, the destination is treated as a file. +An existing file of the same name is clobbered, unless the +.I \-r +option is specified, in which case data recovery is attempted. If an output specification contains a "%s" format, this will be replaced by the modifier name. The @@ -58,8 +79,8 @@ option may be used to further define a "bin number" within each object if finer resolution is needed, and this will be applied to a "%d" format in the output file specification if present. -(The actual bin number is computed at run time based on ray direction -and surface intersection, as described below.)\0 +The actual bin number is computed at run time based on ray direction +and surface intersection, as described below. The most recent .I \-b and @@ -80,20 +101,33 @@ the variables Px, Py, and Pz, and the normalized ray d will be assigned to Dx, Dy, and Dz. These parameters may be combined with definitions given in .I \-e -options and files read in +arguments and files read using the .I \-f -options, to compute the bin, which will be +option. +The computed bin value will be rounded to the nearest whole number. This mechanism allows the user to define precise regions or directions they wish to accumulate, such as the Tregenza sky discretization, which would be otherwise impossible to specify as a set of RADIANCE primitives. +The rules and predefined functions available for these expressions are +described in the +.I rcalc(1) +man page. +Unlike +.I rcalc, +.I rtcontrib +will search the RADIANCE library directories for each file given in a +.I \-f +option. +(No search takes place if a file name begins with a '.', '/' or '~' +character.)\0 .PP If no .I \-o specification is given, results are written on the standard output in order of modifier (as given on the command line) then bin number. -Concatenated data is also sent to a lone output file (i.e., an initial +Concatenated data is also sent to a single destination (i.e., an initial .I \-o specification without formatting strings). If a "%s" format appears but no "%d" in the @@ -170,6 +204,8 @@ To compute an array of illuminance contributions accor .IP "" .2i rtcontrib -b tbin -o sky.dat -m skyglow -b 0 -o ground.dat -m groundglow @render.opt -f tregenza.cal scene.oct < test.dat +.SH ENVIRONMENT +RAYPATH path to search for -f files .SH AUTHOR Greg Ward .SH "SEE ALSO"
