--- ray/doc/man/man1/rtcontrib.1 2007/09/04 17:36:41 1.16 +++ ray/doc/man/man1/rtcontrib.1 2008/10/06 23:00:53 1.19 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: rtcontrib.1,v 1.16 2007/09/04 17:36:41 greg Exp $" +.\" RCSid "$Id: rtcontrib.1,v 1.19 2008/10/06 23:00:53 greg Exp $" .TH RTCONTRIB 1 5/25/05 RADIANCE .SH NAME rtcontrib - compute contribution coefficients in a RADIANCE scene @@ -9,6 +9,8 @@ rtcontrib - compute contribution coefficients in a RAD ][ .B \-V ][ +.B "\-c count" +][ .B \-fo | .B \-r @@ -56,6 +58,17 @@ this file. (No search takes place if a file name begins with a '.', '/' or '~' character.)\0 .PP +If the +.I \-n +option is specified with a value greater than 1, multiple +.I rtrace +processes will be used to accelerate computation on a shared +memory machine. +Note that there is no benefit to using more processes +than there are local CPUs available to do the work, and the +.I rtcontrib +process itself may use a considerable amount of CPU time. +.PP By setting the boolean .I \-V option, you may instruct @@ -84,6 +97,26 @@ rather than radiance, and .I \-V- coefficients contain an additonal factor of PI. .PP +The +.I \-c +option tells +.I rtcontrib +how many rays to accumulate for each record. +The default value is 1, meaning a full record will be produced for +each input ray. +For values greater than 1, contributions will be averaged together +over the given number of input rays. +If set to zero, only a single record will be produced at the very +end, corresponding to the sum of all rays given on the input +(rather than the average). +This is equivalent to passing all the output records through a program like +.I total(1) +to sum RGB values together, but is much more efficient. +Using this option, it is possible to reverse sampling, sending rays from +a parallel source such as the sun to a diffuse surface, for example. +Note that output flushing via zero-direction rays is disabled +for accumulated evaluations. +.PP The output of .I rtcontrib has many potential uses. @@ -112,6 +145,13 @@ option is given. If instead the .I \-r option is specified, data recovery is attempted on existing files. +(If +.I "\-c 0" +is used together with the +.I \-r +option, existing files are read in and new ray evaluations are added +to the previous results, providing a convenient means for +progressive simulation.)\0 If an output specification contains a "%s" format, this will be replaced by the modifier name. The @@ -137,7 +177,14 @@ and options to the left of each .I \-m setting affect only that modifier. -(The ordering of other options is unimportant.)\0 +The ordering of other options is unimportant, except for +.I \-x +and +.I \-y +if the +.I \-c +is 0, when they control the resolution string +produced in the corresponding output. .PP If a .I \-b @@ -212,17 +259,6 @@ suitable for manipulation with .I pcomb(1) and related tools. .PP -If the -.I \-n -option is specified with a value greater than 1, multiple -.I rtrace -processes will be used to accelerate computation on a shared -memory machine. -Note that there is no benefit to using more processes -than there are local CPUs available to do the work, and the -.I rtcontrib -process itself may use a considerable amount of CPU time. -.PP Options may be given on the command line and/or read from the environment and/or read from a file. A command argument beginning with a dollar sign ('$') is immediately @@ -257,4 +293,4 @@ RAYPATH path to search for \-f and \-M files Greg Ward .SH "SEE ALSO" cnt(1), getinfo(1), pcomb(1), pfilt(1), ra_rgbe(1), -rcalc(1), rpict(1), rtrace(1), vwrays(1), ximage(1) +rcalc(1), rpict(1), rtrace(1), total(1), vwrays(1), ximage(1)
