--- ray/doc/man/man1/rtcontrib.1 2005/05/26 19:19:19 1.3 +++ ray/doc/man/man1/rtcontrib.1 2008/04/18 18:06:29 1.18 @@ -1,21 +1,34 @@ -.\" RCSid "$Id: rtcontrib.1,v 1.3 2005/05/26 19:19:19 greg Exp $" +.\" RCSid "$Id: rtcontrib.1,v 1.18 2008/04/18 18:06:29 greg Exp $" .TH RTCONTRIB 1 5/25/05 RADIANCE .SH NAME -rtcontrib - compute contributions in a RADIANCE scene +rtcontrib - compute contribution coefficients in a RADIANCE scene .SH SYNOPSIS .B rtcontrib [ .B "\-n nprocs" ][ +.B \-V +][ +.B "\-c count" +][ +.B \-fo +| +.B \-r +][ .B "\-e expr" ][ .B "\-f source" ][ -.B "\-o fspec" +.B "\-o ospec" ][ .B "\-b binv" +][ +.B "\-bn nbins" ] -.B "\-m mod .." +{ +.B "\-m mod | \-M file" +} +.. [ .B $EVAR ] @@ -26,15 +39,84 @@ rtcontrib - compute contributions in a RADIANCE scene rtrace options ] .B octree +.br +.B "rtcontrib [ options ] \-defaults" .SH DESCRIPTION .I Rtcontrib -computes ray contributions (i.e., color coefficients) +computes ray coefficients for objects whose modifiers are named in one or more .I \-m settings. These modifiers are usually materials associated with light sources or sky domes, and must directly modify some geometric primitives to be considered in the output. +A modifier list may also be read from a file using the +.I \-M +option. +The RAYPATH environment variable determines directories to search for +this file. +(No search takes place if a file name begins with a '.', '/' or '~' +character.)\0 +.PP +If the +.I \-n +option is specified with a value greater than 1, multiple +.I rtrace +processes will be used to accelerate computation on a shared +memory machine. +Note that there is no benefit to using more processes +than there are local CPUs available to do the work, and the +.I rtcontrib +process itself may use a considerable amount of CPU time. +.PP +By setting the boolean +.I \-V +option, you may instruct +.I rtcontrib +to report the contribution from each material rather than the ray +coefficient. +This is particularly useful for light sources with directional output +distributions, whose value would otherwise be lost in the shuffle. +With the default +.I -V- +setting, the output of rtcontrib is a coefficient that must be multiplied +by the radiance of each material to arrive at a final contribution. +This is more convenient for computing daylight coefficeints, or cases +where the actual radiance is not desired. +Use the +.I -V+ +setting when you wish to simply sum together contributions +(with possible adjustment factors) to obtain a final radiance value. +Combined with the +.I \-i +or +.I \-I +option, irradiance contributions are reported by +.I \-V+ +rather than radiance, and +.I \-V- +coefficients contain an additonal factor of PI. +.PP +The +.I \-c +option tells +.I rtcontrib +how many rays to accumulate for each record. +The default value is 1, meaning a full record will be produced for +each input ray. +For values greater than 1, contributions will be averaged together +over the given number of input rays. +If set to zero, only a single record will be produced at the very +end, corresponding to the sum of all rays given on the input +(rather than the average). +This is equivalent to passing all the output records through a program like +.I total(1) +to sum RGB values together, but is much more efficient. +Using this option, it is possible to reverse sampling, sending rays from +a parallel source such as the sun to a diffuse surface, for example. +Note that output flushing via zero-direction rays is disabled +for accumulated evaluations. +.PP The output of .I rtcontrib has many potential uses. @@ -49,10 +131,27 @@ systems, such as luminaires, light pipes, and shading .I Rtcontrib calls .I rtrace(1) -to calculate the contributions for each input ray, -and the output tallies are sent to one or more files according to the +with the \-oTW (or \-oTV) option to calculate the daughter ray +contributions for each input ray, and the output tallies +are sent to one or more destinations according to the given .I \-o specification. +If a destination begins with an exclamation mark ('!'), then +a pipe is opened to a command and data is sent to its standard input. +Otherwise, the destination is treated as a file. +An existing file of the same name will not be clobbered, unless the +.I \-fo +option is given. +If instead the +.I \-r +option is specified, data recovery is attempted on existing files. +(If +.I "\-c 0" +is used together with the +.I \-r +option, existing files are read in and new ray evaluations are added +to the previous results, providing a convenient means for +progressive simulation.)\0 If an output specification contains a "%s" format, this will be replaced by the modifier name. The @@ -63,14 +162,29 @@ this will be applied to a "%d" format in the output fi specification if present. The actual bin number is computed at run time based on ray direction and surface intersection, as described below. +If the number of bins is known in advance, it should be specified with the +.I \-bn +option, and this is critical for output files containing multiple values +per record. +Since bin numbers start from 0, the bin count is always equal to +the last bin plus 1. +Set the this value to 0 if the bin count is unknown (the default). The most recent -.I \-b +.I \-b, +.I \-bn and .I \-o options to the left of each .I \-m setting affect only that modifier. -(The ordering of other options is unimportant.)\0 +The ordering of other options is unimportant, except for +.I \-x +and +.I \-y +if the +.I \-c +is present, when they control the resolution string +produced in the corresponding output. .PP If a .I \-b @@ -96,12 +210,18 @@ The rules and predefined functions available for these described in the .I rcalc(1) man page. +Unlike +.I rcalc, +.I rtcontrib +will search the RADIANCE library directories for each file given in a +.I \-f +option. .PP If no .I \-o specification is given, results are written on the standard output in order of modifier (as given on the command line) then bin number. -Concatenated data is also sent to a lone output file (i.e., an initial +Concatenated data is also sent to a single destination (i.e., an initial .I \-o specification without formatting strings). If a "%s" format appears but no "%d" in the @@ -139,17 +259,6 @@ suitable for manipulation with .I pcomb(1) and related tools. .PP -If the -.I \-n -option is specified with a value greater than 1, multiple -.I rtrace -processes will be used to accelerate computation on a shared -memory machine. -Note that there is no benefit to using more processes -than there are local CPUs available to do the work, and the -.I rtcontrib -process itself may use a considerable amount of CPU time. -.PP Options may be given on the command line and/or read from the environment and/or read from a file. A command argument beginning with a dollar sign ('$') is immediately @@ -160,26 +269,28 @@ replaced by the contents of the given file. To compute the proportional contributions from sources modified by "light1" vs. "light2" on a set of illuminance values: .IP "" .2i -rtcontrib -I+ @render.opt -o c_%s.dat -m light1 -m light2 scene.oct < test.dat +rtcontrib \-I+ @render.opt \-o c_%s.dat \-m light1 \-m light2 scene.oct < test.dat .PP To generate a pair of images corresponding to these two lights' contributions: .IP "" .2i -vwrays -ff -x 1024 -y 1024 -vf best.vf | -rtcontrib -ffc `vwrays -d -x 1024 -y 1024 -vf best.vf` -@render.opt -o c_%s.pic -m light1 -m light2 scene.oct +vwrays \-ff \-x 1024 \-y 1024 \-vf best.vf | +rtcontrib \-ffc `vwrays \-d \-x 1024 \-y 1024 \-vf best.vf` +@render.opt \-o c_%s.pic \-m light1 \-m light2 scene.oct .PP These images may then be recombined using the desired outputs of light1 and light2: .IP "" .2i -pcomb -c 100 90 75 c_light1.pic -c 50 55 57 c_light2.pic > combined.pic +pcomb \-c 100 90 75 c_light1.pic \-c 50 55 57 c_light2.pic > combined.pic .PP To compute an array of illuminance contributions according to a Tregenza sky: .IP "" .2i -rtcontrib -b tbin -o sky.dat -m skyglow -b 0 -o ground.dat -m groundglow -@render.opt -f tregenza.cal scene.oct < test.dat +rtcontrib \-I+ \-b tbin \-o sky.dat \-m skyglow \-b 0 \-o ground.dat \-m groundglow +@render.opt \-f tregenza.cal scene.oct < test.dat +.SH ENVIRONMENT +RAYPATH path to search for \-f and \-M files .SH AUTHOR Greg Ward .SH "SEE ALSO" cnt(1), getinfo(1), pcomb(1), pfilt(1), ra_rgbe(1), -rcalc(1), rpict(1), rtrace(1), vwrays(1), ximage(1) +rcalc(1), rpict(1), rtrace(1), total(1), vwrays(1), ximage(1)
