--- ray/doc/man/man1/rtcontrib.1 2005/05/26 06:55:22 1.1 +++ ray/doc/man/man1/rtcontrib.1 2007/11/17 01:13:50 1.17 @@ -1,20 +1,34 @@ -.\" RCSid "$Id: rtcontrib.1,v 1.1 2005/05/26 06:55:22 greg Exp $" -.TH RPIECE 1 5/25/05 RADIANCE +.\" RCSid "$Id: rtcontrib.1,v 1.17 2007/11/17 01:13:50 greg Exp $" +.TH RTCONTRIB 1 5/25/05 RADIANCE .SH NAME -rtcontrib - compute contributions in a RADIANCE scene +rtcontrib - compute contribution coefficients in a RADIANCE scene .SH SYNOPSIS .B rtcontrib [ .B "\-n nprocs" ][ +.B \-V +][ +.B \-c +][ +.B \-fo +| +.B \-r +][ .B "\-e expr" ][ .B "\-f source" ][ -.B "\-o fspec" +.B "\-o ospec" ][ .B "\-b binv" +][ +.B "\-bn nbins" ] +{ +.B "\-m mod | \-M file" +} +.. [ .B $EVAR ] @@ -24,77 +38,176 @@ rtcontrib - compute contributions in a RADIANCE scene [ rtrace options ] -.B "\-m mod .." .B octree +.br +.B "rtcontrib [ options ] \-defaults" .SH DESCRIPTION .I Rtcontrib -computes ray contributions (i.e., color coefficients) +computes ray coefficients for objects whose modifiers are named in one or more .I \-m settings. -These modifiers are usually materials associated with specific -light sources, though they could correspond to intermediate objects as well. -The resulting contributions may then be used in linear combination to +These modifiers are usually materials associated with +light sources or sky domes, and must directly modify some geometric +primitives to be considered in the output. +A modifier list may also be read from a file using the +.I \-M +option. +The RAYPATH environment variable determines directories to search for +this file. +(No search takes place if a file name begins with a '.', '/' or '~' +character.)\0 +.PP +By setting the boolean +.I \-V +option, you may instruct +.I rtcontrib +to report the contribution from each material rather than the ray +coefficient. +This is particularly useful for light sources with directional output +distributions, whose value would otherwise be lost in the shuffle. +With the default +.I -V- +setting, the output of rtcontrib is a coefficient that must be multiplied +by the radiance of each material to arrive at a final contribution. +This is more convenient for computing daylight coefficeints, or cases +where the actual radiance is not desired. +Use the +.I -V+ +setting when you wish to simply sum together contributions +(with possible adjustment factors) to obtain a final radiance value. +Combined with the +.I \-i +or +.I \-I +option, irradiance contributions are reported by +.I \-V+ +rather than radiance, and +.I \-V- +coefficients contain an additonal factor of PI. +.PP +The output of +.I rtcontrib +has many potential uses. +Source contributions can be used as components in linear combination to reproduce any desired variation, e.g., simulating lighting controls or changing sky conditions via daylight coefficients. More generally, .I rtcontrib -can compute general input-output relationships in optical -systems, such as light pipes and shading devices. +can be used to compute arbitrary input-output relationships in optical +systems, such as luminaires, light pipes, and shading devices. .PP -.I Rtrace(1) -is called to calculate the contributions for each input ray, -and the output tallies are sent to one or more files according to the +Setting the +.I \-c +option instructs +.I rtcontrib +to accumulate values rather than reporting one record per ray. +With this option, only a single record will be produced at the very +end, corresponding to the sum of all rays given on the input. +This is equivalent to passing all the output records through a program like +.I total(1) +to sum RGB values together, but is much more efficient. +Using this option, it is possible to reverse sampling, sending rays from +a parallel source such as the sun to a diffuse surface, for example. +Care must be taken to perform normalization based on the +radiation density and the number of rays sampled. +.PP +.I Rtcontrib +calls +.I rtrace(1) +with the \-oTW (or \-oTV) option to calculate the daughter ray +contributions for each input ray, and the output tallies +are sent to one or more destinations according to the given .I \-o specification. -If the output file specification contains a "%s" format, this will be +If a destination begins with an exclamation mark ('!'), then +a pipe is opened to a command and data is sent to its standard input. +Otherwise, the destination is treated as a file. +An existing file of the same name will not be clobbered, unless the +.I \-fo +option is given. +If instead the +.I \-r +option is specified, data recovery is attempted on existing files. +(If +.I \-c +is used together with the +.I \-r +option, existing files are read in and new ray evaluations are added +to the previous results, providing a convenient means for +progressive simulation.)\0 +If an output specification contains a "%s" format, this will be replaced by the modifier name. The .I \-b option may be used to further define -a "bin number" within each object if finer resolution is desired, and -will be applied to a "%d" format in the output file +a "bin number" within each object if finer resolution is needed, and +this will be applied to a "%d" format in the output file specification if present. -(The actual bin number is computed at run time based on ray direction -and surface intersection, as described below.)\0 +The actual bin number is computed at run time based on ray direction +and surface intersection, as described below. +If the number of bins is known in advance, it should be specified with the +.I \-bn +option, and this is critical for output files containing multiple values +per record. +Since bin numbers start from 0, the bin count is always equal to +the last bin plus 1. +Set the this value to 0 if the bin count is unknown (the default). The most recent -.I \-b +.I \-b, +.I \-bn and .I \-o -options (to the left) of each +options to the left of each .I \-m -setting affect only that modifier, and the ordering -of other options is unimportant. -.PP -Input and output format defaults to plain text, where each ray's -origin and direction (6 real values) must appear together per -line of input, and one line of output is produced per output file -file per ray. -Alternative input and output formats may be specified using the -.I \-f[io] -option, which is explained in the -.I rtrace -man page along with the associated +setting affect only that modifier. +The ordering of other options is unimportant, except for .I \-x and .I \-y -resolution settings. -In particular, the 'c' output setting -together with positive dimensions for -.I \-x -and -.I \-y -will produce an uncompressed RADIANCE picture, -suitable for manipulation with -.I pcomb(1) -and related tools. +if the +.I \-c +is present, when they control the resolution string +produced in the corresponding output. .PP +If a +.I \-b +expression is defined for a particular modifier, +the bin number will be evaluated at run time for each +ray contribution from +.I rtrace. +Specifically, each ray's world intersection point will be assigned to +the variables Px, Py, and Pz, and the normalized ray direction +will be assigned to Dx, Dy, and Dz. +These parameters may be combined with definitions given in +.I \-e +arguments and files read using the +.I \-f +option. +The computed bin value will be +rounded to the nearest whole number. +This mechanism allows the user to define precise regions or directions +they wish to accumulate, such as the Tregenza sky discretization, +which would be otherwise impossible to specify +as a set of RADIANCE primitives. +The rules and predefined functions available for these expressions are +described in the +.I rcalc(1) +man page. +Unlike +.I rcalc, +.I rtcontrib +will search the RADIANCE library directories for each file given in a +.I \-f +option. +.PP If no .I \-o specification is given, results are written on the standard output in order of modifier (as given on the command line) then bin number. -The same format is used for a simple file name specification -without any embedded "%s" or "%d" formats. +Concatenated data is also sent to a single destination (i.e., an initial +.I \-o +specification without formatting strings). If a "%s" format appears but no "%d" in the .I \-o specification, then each modifier will have its own output file, with @@ -108,33 +221,38 @@ with a newline at the end of each ray record. For binary output formats, there is no such delimiter to mark the end of each record. .PP -If a -.I \-b -expression is defined for a particular modifier, -the bin number will be evaluated at run time for each -ray contribution from -.I rtrace. -Specifically, each ray's world intersection point will be assigned to -the variables Px, Py, and Pz, and the normalized ray direction -will be assigned to Dx, Dy, and Dz. -These ray parameters may be combined with any definitions given in -.I \-e -options, or any files read in from -.I \-f -options, to compute the bin, which will be -rounded to the closest whole number. -This mechanism allows the user to define precise regions (or directions) -they wish to accumulate, such as the Tregenza sky grid, which would be -otherwise impossible to specify as a set of RADIANCE primitives. +Input and output format defaults to plain text, where each ray's +origin and direction (6 real values) are given on input, +and one line is produced per output file per ray. +Alternative data representations may be specified by the +.I \-f[io] +option, which is described in the +.I rtrace +man page along with the associated +.I \-x +and +.I \-y +resolution settings. +In particular, the color ('c') output data representation +together with positive dimensions for +.I \-x +and +.I \-y +will produce an uncompressed RADIANCE picture, +suitable for manipulation with +.I pcomb(1) +and related tools. .PP If the .I \-n option is specified with a value greater than 1, multiple -.I rtrace(1) +.I rtrace processes will be used to accelerate computation on a shared memory machine. Note that there is no benefit to using more processes -than there are local CPUs available to do the work. +than there are local CPUs available to do the work, and the +.I rtcontrib +process itself may use a considerable amount of CPU time. .PP Options may be given on the command line and/or read from the environment and/or read from a file. @@ -142,80 +260,32 @@ A command argument beginning with a dollar sign ('$') replaced by the contents of the given environment variable. A command argument beginning with an at sign ('@') is immediately replaced by the contents of the given file. -.SH EXAMPLE -First -.I rpiece -process is started on the machine "goober": +.SH EXAMPLES +To compute the proportional contributions from sources modified +by "light1" vs. "light2" on a set of illuminance values: .IP "" .2i -goober% echo 1 8 > syncfile -.br -goober% echo -F syncfile -x 1024 -y 1024 -vf view -o picture octree > args -.br -goober% rpiece @args & +rtcontrib \-I+ @render.opt \-o c_%s.dat \-m light1 \-m light2 scene.oct < test.dat .PP -Second -.I rpiece -processes is started on the machine "sucker": +To generate a pair of images corresponding to these two lights' +contributions: .IP "" .2i -sucker% rpiece @args & -.SH NOTES -Due to NFS file buffering, the network lock manager is employed to -guarantee consistency in the output file even though non-overlapping -writes are used. -This would tend to slow the process down if -.I rpiece -were to wait for this I/O to complete before starting on the next -piece, so -.I rpiece -forks separate processes to hang around waiting for I/O completion. -The number of processes thus designated is set by the MAXFORK macro -in the program (compiled in the src/util directory). -If the fork call is slow on a system, it may actually be better to -set MAXFORK to zero. -In other cases, the network lock manager may be so slow that this -value should be increased to get the best utilization. +vwrays \-ff \-x 1024 \-y 1024 \-vf best.vf | +rtcontrib \-ffc `vwrays \-d \-x 1024 \-y 1024 \-vf best.vf` +@render.opt \-o c_%s.pic \-m light1 \-m light2 scene.oct .PP -The output picture is not run-length encoded, and can be quite -large. -The approximate size (in kilobytes) can be computed by the simple -formula: +These images may then be recombined using the desired outputs +of light1 and light2: .IP "" .2i -filesize = xres*yres/256 +pcomb \-c 100 90 75 c_light1.pic \-c 50 55 57 c_light2.pic > combined.pic .PP -Make sure that there is enough space on the filesystem to hold the -entire picture before beginning. -Once the picture is finished, the -.I ra_rgbe(1) -program with the -r option may be used to convert to a run-length -encoded picture for more efficient storage, although -.I pfilt(1) -or any of the other Radiance picture filters will do the same -thing. -.PP -The ALRM signal may be used to gracefully terminate an -.I rpiece -process after it finishes the current piece. -This permits other currently running or subsequently started -.I rpiece -process(es) to continue rendering the picture without loss. -The -.I \-T -option will send the ALRM signal to -.I rpiece -after the specified number of (decimal) hours. -This is the best way to force a time limit on the computation, -since information will not be lost, though the process may continue -for some time afterwards to finish its current piece. -.SH BUGS -This program may not work on some systems whose NFS lock manager is -unreliable. -In particular, some System V derivative UNIX systems often have -problems with the network lock manager. -If the output is scrambled or rpict aborts with some ambient file -related problem, you should just remove the ambient file and go -back to normal rendering. +To compute an array of illuminance contributions according to a Tregenza sky: +.IP "" .2i +rtcontrib \-I+ \-b tbin \-o sky.dat \-m skyglow \-b 0 \-o ground.dat \-m groundglow +@render.opt \-f tregenza.cal scene.oct < test.dat +.SH ENVIRONMENT +RAYPATH path to search for \-f and \-M files .SH AUTHOR Greg Ward .SH "SEE ALSO" cnt(1), getinfo(1), pcomb(1), pfilt(1), ra_rgbe(1), -rcalc(1), rpict(1), rtrace(1), vwrays(1), ximage(1) +rcalc(1), rpict(1), rtrace(1), total(1), vwrays(1), ximage(1)
