--- ray/doc/man/man1/rtcontrib.1 2005/10/11 16:54:26 1.14 +++ ray/doc/man/man1/rtcontrib.1 2006/02/05 22:22:20 1.15 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: rtcontrib.1,v 1.14 2005/10/11 16:54:26 greg Exp $" +.\" RCSid "$Id: rtcontrib.1,v 1.15 2006/02/05 22:22:20 greg Exp $" .TH RTCONTRIB 1 5/25/05 RADIANCE .SH NAME rtcontrib - compute contribution coefficients in a RADIANCE scene @@ -7,6 +7,8 @@ rtcontrib - compute contribution coefficients in a RAD [ .B "\-n nprocs" ][ +.B \-V +][ .B \-fo | .B \-r @@ -39,7 +41,7 @@ rtrace options .B "rtcontrib [ options ] \-defaults" .SH DESCRIPTION .I Rtcontrib -computes ray contributions (i.e., color coefficients) +computes ray coefficients for objects whose modifiers are named in one or more .I \-m settings. @@ -54,6 +56,34 @@ this file. (No search takes place if a file name begins with a '.', '/' or '~' character.)\0 .PP +By setting the boolean +.I \-V +option, you may instruct +.I rtcontrib +to report the contribution from each material rather than the ray +coefficient. +This is particularly useful for light sources with directional output +distributions, whose value would otherwise be lost in the shuffle. +With the default +.I -V- +setting, the output of rtcontrib is a coefficient that must be multiplied +by the radiance of each material to arrive at a final contribution. +This is more convenient for computing daylight coefficeints, or cases +where the actual radiance is not desired. +Use the +.I -V+ +setting when you wish to simply sum together contributions +(with possible adjustment factors) to obtain a final radiance value. +Combined with the +.I \-i +or +.I \-I +option, irradiance contributions are reported by +.I \-V+ +rather than radiance, and +.I \-V- +coefficients contain an additonal factor of PI. +.PP The output of .I rtcontrib has many potential uses. @@ -68,7 +98,7 @@ systems, such as luminaires, light pipes, and shading .I Rtcontrib calls .I rtrace(1) -with the -oTW option to calculate the daughter ray +with the -oTW (or -oTV) option to calculate the daughter ray contributions for each input ray, and the output tallies are sent to one or more destinations according to the given .I \-o
