--- ray/doc/man/man1/rtcontrib.1 2005/10/06 16:28:59 1.13 +++ ray/doc/man/man1/rtcontrib.1 2005/10/11 16:54:26 1.14 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: rtcontrib.1,v 1.13 2005/10/06 16:28:59 greg Exp $" +.\" RCSid "$Id: rtcontrib.1,v 1.14 2005/10/11 16:54:26 greg Exp $" .TH RTCONTRIB 1 5/25/05 RADIANCE .SH NAME rtcontrib - compute contribution coefficients in a RADIANCE scene @@ -7,6 +7,8 @@ rtcontrib - compute contribution coefficients in a RAD [ .B "\-n nprocs" ][ +.B \-fo +| .B \-r ][ .B "\-e expr" @@ -74,9 +76,12 @@ specification. If a destination begins with an exclamation mark ('!'), then a pipe is opened to a command and data is sent to its standard input. Otherwise, the destination is treated as a file. -An existing file of the same name is clobbered, unless the +An existing file of the same name will not be clobbered, unless the +.I \-fo +option is given. +If instead the .I \-r -option is specified, in which case data recovery is attempted. +option is specified, data recovery is attempted on existing files. If an output specification contains a "%s" format, this will be replaced by the modifier name. The
