--- ray/doc/man/man1/rtcontrib.1 2005/06/10 20:53:55 1.10 +++ ray/doc/man/man1/rtcontrib.1 2005/10/06 16:28:59 1.13 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: rtcontrib.1,v 1.10 2005/06/10 20:53:55 greg Exp $" +.\" RCSid "$Id: rtcontrib.1,v 1.13 2005/10/06 16:28:59 greg Exp $" .TH RTCONTRIB 1 5/25/05 RADIANCE .SH NAME rtcontrib - compute contribution coefficients in a RADIANCE scene @@ -16,6 +16,8 @@ rtcontrib - compute contribution coefficients in a RAD .B "\-o ospec" ][ .B "\-b binv" +][ +.B "\-bn nbins" ] { .B "\-m mod | \-M file" @@ -85,8 +87,16 @@ this will be applied to a "%d" format in the output fi specification if present. The actual bin number is computed at run time based on ray direction and surface intersection, as described below. +If the number of bins is known in advance, it should be specified with the +.I \-bn +option, and this is critical for output files containing multiple values +per record. +Since bin numbers start from 0, the bin count is always equal to +the last bin plus 1. +Set the this value to 0 if the bin count is unknown (the default). The most recent -.I \-b +.I \-b, +.I \-bn and .I \-o options to the left of each @@ -204,7 +214,7 @@ pcomb -c 100 90 75 c_light1.pic -c 50 55 57 c_light2.p .PP To compute an array of illuminance contributions according to a Tregenza sky: .IP "" .2i -rtcontrib -b tbin -o sky.dat -m skyglow -b 0 -o ground.dat -m groundglow +rtcontrib -I+ -b tbin -o sky.dat -m skyglow -b 0 -o ground.dat -m groundglow @render.opt -f tregenza.cal scene.oct < test.dat .SH ENVIRONMENT RAYPATH path to search for -f and -M files
