--- ray/doc/man/man1/rtcontrib.1 2005/06/02 04:47:26 1.7 +++ ray/doc/man/man1/rtcontrib.1 2005/07/23 19:53:36 1.11 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: rtcontrib.1,v 1.7 2005/06/02 04:47:26 greg Exp $" +.\" RCSid "$Id: rtcontrib.1,v 1.11 2005/07/23 19:53:36 greg Exp $" .TH RTCONTRIB 1 5/25/05 RADIANCE .SH NAME rtcontrib - compute contribution coefficients in a RADIANCE scene @@ -7,6 +7,8 @@ rtcontrib - compute contribution coefficients in a RAD [ .B "\-n nprocs" ][ +.B \-r +][ .B "\-e expr" ][ .B "\-f source" @@ -15,7 +17,10 @@ rtcontrib - compute contribution coefficients in a RAD ][ .B "\-b binv" ] -.B "\-m mod .." +{ +.B "\-m mod | \-M file" +} +.. [ .B $EVAR ] @@ -37,6 +42,14 @@ settings. These modifiers are usually materials associated with light sources or sky domes, and must directly modify some geometric primitives to be considered in the output. +A modifier list may also be read from a file using the +.I \-M +option. +The RAYPATH environment variable determines directories to search for +this file. +(No search takes place if a file name begins with a '.', '/' or '~' +character.)\0 +.PP The output of .I rtcontrib has many potential uses. @@ -59,7 +72,9 @@ specification. If a destination begins with an exclamation mark ('!'), then a pipe is opened to a command and data is sent to its standard input. Otherwise, the destination is treated as a file. -(An existing file of the same name is clobbered.)\0 +An existing file of the same name is clobbered, unless the +.I \-r +option is specified, in which case data recovery is attempted. If an output specification contains a "%s" format, this will be replaced by the modifier name. The @@ -109,8 +124,6 @@ Unlike will search the RADIANCE library directories for each file given in a .I \-f option. -(No search takes place if a file name begins with a '.', '/' or '~' -character.)\0 .PP If no .I \-o @@ -191,10 +204,10 @@ pcomb -c 100 90 75 c_light1.pic -c 50 55 57 c_light2.p .PP To compute an array of illuminance contributions according to a Tregenza sky: .IP "" .2i -rtcontrib -b tbin -o sky.dat -m skyglow -b 0 -o ground.dat -m groundglow +rtcontrib -I+ -b tbin -o sky.dat -m skyglow -b 0 -o ground.dat -m groundglow @render.opt -f tregenza.cal scene.oct < test.dat .SH ENVIRONMENT -RAYPATH path to search for -f files +RAYPATH path to search for -f and -M files .SH AUTHOR Greg Ward .SH "SEE ALSO"
