--- ray/doc/man/man1/rtcontrib.1 2005/06/10 20:53:55 1.10 +++ ray/doc/man/man1/rtcontrib.1 2005/10/11 16:54:26 1.14 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: rtcontrib.1,v 1.10 2005/06/10 20:53:55 greg Exp $" +.\" RCSid "$Id: rtcontrib.1,v 1.14 2005/10/11 16:54:26 greg Exp $" .TH RTCONTRIB 1 5/25/05 RADIANCE .SH NAME rtcontrib - compute contribution coefficients in a RADIANCE scene @@ -7,6 +7,8 @@ rtcontrib - compute contribution coefficients in a RAD [ .B "\-n nprocs" ][ +.B \-fo +| .B \-r ][ .B "\-e expr" @@ -16,6 +18,8 @@ rtcontrib - compute contribution coefficients in a RAD .B "\-o ospec" ][ .B "\-b binv" +][ +.B "\-bn nbins" ] { .B "\-m mod | \-M file" @@ -72,9 +76,12 @@ specification. If a destination begins with an exclamation mark ('!'), then a pipe is opened to a command and data is sent to its standard input. Otherwise, the destination is treated as a file. -An existing file of the same name is clobbered, unless the +An existing file of the same name will not be clobbered, unless the +.I \-fo +option is given. +If instead the .I \-r -option is specified, in which case data recovery is attempted. +option is specified, data recovery is attempted on existing files. If an output specification contains a "%s" format, this will be replaced by the modifier name. The @@ -85,8 +92,16 @@ this will be applied to a "%d" format in the output fi specification if present. The actual bin number is computed at run time based on ray direction and surface intersection, as described below. +If the number of bins is known in advance, it should be specified with the +.I \-bn +option, and this is critical for output files containing multiple values +per record. +Since bin numbers start from 0, the bin count is always equal to +the last bin plus 1. +Set the this value to 0 if the bin count is unknown (the default). The most recent -.I \-b +.I \-b, +.I \-bn and .I \-o options to the left of each @@ -204,7 +219,7 @@ pcomb -c 100 90 75 c_light1.pic -c 50 55 57 c_light2.p .PP To compute an array of illuminance contributions according to a Tregenza sky: .IP "" .2i -rtcontrib -b tbin -o sky.dat -m skyglow -b 0 -o ground.dat -m groundglow +rtcontrib -I+ -b tbin -o sky.dat -m skyglow -b 0 -o ground.dat -m groundglow @render.opt -f tregenza.cal scene.oct < test.dat .SH ENVIRONMENT RAYPATH path to search for -f and -M files
