root/radiance/ray/doc/man/man1/rtcontrib.1
Revision: 1.6
Committed: Wed Jun 1 16:11:01 2005 UTC (20 years, 1 month ago) by greg
Changes since 1.5: +11 -1 lines
1 .\" RCSid "$Id: rtcontrib.1,v 1.5 2005/05/27 19:15:28 greg Exp $"
2 .TH RTCONTRIB 1 5/25/05 RADIANCE
3 .SH NAME
4 rtcontrib - compute contribution coefficients in a RADIANCE scene
5 .SH SYNOPSIS
6 .B rtcontrib
7 [
8 .B "\-n nprocs"
9 ][
10 .B "\-e expr"
11 ][
12 .B "\-f source"
13 ][
14 .B "\-o fspec"
15 ][
16 .B "\-b binv"
17 ]
18 .B "\-m mod .."
19 [
20 .B $EVAR
21 ]
22 [
23 .B @file
24 ]
25 [
26 rtrace options
27 ]
28 .B octree
29 .br
30 .B "rtcontrib [ options ] \-defaults"
31 .SH DESCRIPTION
32 .I Rtcontrib
33 computes ray contributions (i.e., color coefficients)
34 for objects whose modifiers are named in one or more
35 .I \-m
36 settings.
37 These modifiers are usually materials associated with
38 light sources or sky domes, and must directly modify some geometric
39 primitives to be considered in the output.
40 The output of
41 .I rtcontrib
42 has many potential uses.
43 Source contributions can be used as components in linear combination to
44 reproduce any desired variation, e.g., simulating lighting controls or
45 changing sky conditions via daylight coefficients.
46 More generally,
47 .I rtcontrib
48 can be used to compute arbitrary input-output relationships in optical
49 systems, such as luminaires, light pipes, and shading devices.
50 .PP
51 .I Rtcontrib
52 calls
53 .I rtrace(1)
54 with the -oTW option to calculate the daughter ray
55 contributions for each input ray, and the output tallies
56 are sent to one or more files according to the given
57 .I \-o
58 specification.
59 If an output specification contains a "%s" format, this will be
60 replaced by the modifier name.
61 The
62 .I \-b
63 option may be used to further define
64 a "bin number" within each object if finer resolution is needed, and
65 this will be applied to a "%d" format in the output file
66 specification if present.
67 The actual bin number is computed at run time based on ray direction
68 and surface intersection, as described below.
69 The most recent
70 .I \-b
71 and
72 .I \-o
73 options to the left of each
74 .I \-m
75 setting affect only that modifier.
76 (The ordering of other options is unimportant.)\0
77 .PP
78 If a
79 .I \-b
80 expression is defined for a particular modifier,
81 the bin number will be evaluated at run time for each
82 ray contribution from
83 .I rtrace.
84 Specifically, each ray's world intersection point will be assigned to
85 the variables Px, Py, and Pz, and the normalized ray direction
86 will be assigned to Dx, Dy, and Dz.
87 These parameters may be combined with definitions given in
88 .I \-e
89 arguments and files read using the
90 .I \-f
91 option.
92 The computed bin value will be
93 rounded to the nearest whole number.
94 This mechanism allows the user to define precise regions or directions
95 they wish to accumulate, such as the Tregenza sky discretization,
96 which would be otherwise impossible to specify
97 as a set of RADIANCE primitives.
98 The rules and predefined functions available for these expressions are
99 described in the
100 .I rcalc(1)
101 man page.
102 Unlike
103 .I rcalc,
104 .I rtcontrib
105 will search the RADIANCE library directories for each file given in a
106 .I \-f
107 option.
108 (No search takes place if a file name begins with a '.', '/' or '~'
109 character.)\0
110 .PP
111 If no
112 .I \-o
113 specification is given, results are written on the standard output in order
114 of modifier (as given on the command line) then bin number.
115 Concatenated data is also sent to a lone output file (i.e., an initial
116 .I \-o
117 specification without formatting strings).
118 If a "%s" format appears but no "%d" in the
119 .I \-o
120 specification, then each modifier will have its own output file, with
121 multiple values per record in the case of a non-zero
122 .I \-b
123 definition.
124 If a "%d" format appears but no "%s", then each bin will get its own
125 output file, with modifiers output in order in each record.
126 For text output, each RGB coefficient triple is separated by a tab,
127 with a newline at the end of each ray record.
128 For binary output formats, there is no such delimiter to mark
129 the end of each record.
130 .PP
131 Input and output format defaults to plain text, where each ray's
132 origin and direction (6 real values) are given on input,
133 and one line is produced per output file per ray.
134 Alternative data representations may be specified by the
135 .I \-f[io]
136 option, which is described in the
137 .I rtrace
138 man page along with the associated
139 .I \-x
140 and
141 .I \-y
142 resolution settings.
143 In particular, the color ('c') output data representation
144 together with positive dimensions for
145 .I \-x
146 and
147 .I \-y
148 will produce an uncompressed RADIANCE picture,
149 suitable for manipulation with
150 .I pcomb(1)
151 and related tools.
152 .PP
153 If the
154 .I \-n
155 option is specified with a value greater than 1, multiple
156 .I rtrace
157 processes will be used to accelerate computation on a shared
158 memory machine.
159 Note that there is no benefit to using more processes
160 than there are local CPUs available to do the work, and the
161 .I rtcontrib
162 process itself may use a considerable amount of CPU time.
163 .PP
164 Options may be given on the command line and/or read from the
165 environment and/or read from a file.
166 A command argument beginning with a dollar sign ('$') is immediately
167 replaced by the contents of the given environment variable.
168 A command argument beginning with an at sign ('@') is immediately
169 replaced by the contents of the given file.
170 .SH EXAMPLES
171 To compute the proportional contributions from sources modified
172 by "light1" vs. "light2" on a set of illuminance values:
173 .IP "" .2i
174 rtcontrib -I+ @render.opt -o c_%s.dat -m light1 -m light2 scene.oct < test.dat
175 .PP
176 To generate a pair of images corresponding to these two lights'
177 contributions:
178 .IP "" .2i
179 vwrays -ff -x 1024 -y 1024 -vf best.vf |
180 rtcontrib -ffc `vwrays -d -x 1024 -y 1024 -vf best.vf`
181 @render.opt -o c_%s.pic -m light1 -m light2 scene.oct
182 .PP
183 These images may then be recombined using the desired outputs
184 of light1 and light2:
185 .IP "" .2i
186 pcomb -c 100 90 75 c_light1.pic -c 50 55 57 c_light2.pic > combined.pic
187 .PP
188 To compute an array of illuminance contributions according to a Tregenza sky:
189 .IP "" .2i
190 rtcontrib -b tbin -o sky.dat -m skyglow -b 0 -o ground.dat -m groundglow
191 @render.opt -f tregenza.cal scene.oct < test.dat
192 .SH ENVIRONMENT
193 RAYPATH path to search for -f files
194 .SH AUTHOR
195 Greg Ward
196 .SH "SEE ALSO"
197 cnt(1), getinfo(1), pcomb(1), pfilt(1), ra_rgbe(1),
198 rcalc(1), rpict(1), rtrace(1), vwrays(1), ximage(1)
