root/radiance/ray/doc/man/man1/rtcontrib.1
Revision: 1.14
Committed: Tue Oct 11 16:54:26 2005 UTC (19 years, 8 months ago) by greg
Changes since 1.13: +8 -3 lines
Added rtcontrib -fo option to override new reluctance to clobber existing files
1 .\" RCSid "$Id: rtcontrib.1,v 1.13 2005/10/06 16:28:59 greg Exp $"
2 .TH RTCONTRIB 1 5/25/05 RADIANCE
3 .SH NAME
4 rtcontrib - compute contribution coefficients in a RADIANCE scene
5 .SH SYNOPSIS
6 .B rtcontrib
7 [
8 .B "\-n nprocs"
9 ][
10 .B \-fo
11 |
12 .B \-r
13 ][
14 .B "\-e expr"
15 ][
16 .B "\-f source"
17 ][
18 .B "\-o ospec"
19 ][
20 .B "\-b binv"
21 ][
22 .B "\-bn nbins"
23 ]
24 {
25 .B "\-m mod | \-M file"
26 }
27 ..
28 [
29 .B $EVAR
30 ]
31 [
32 .B @file
33 ]
34 [
35 rtrace options
36 ]
37 .B octree
38 .br
39 .B "rtcontrib [ options ] \-defaults"
40 .SH DESCRIPTION
41 .I Rtcontrib
42 computes ray contributions (i.e., color coefficients)
43 for objects whose modifiers are named in one or more
44 .I \-m
45 settings.
46 These modifiers are usually materials associated with
47 light sources or sky domes, and must directly modify some geometric
48 primitives to be considered in the output.
49 A modifier list may also be read from a file using the
50 .I \-M
51 option.
52 The RAYPATH environment variable determines directories to search for
53 this file.
54 (No search takes place if a file name begins with a '.', '/' or '~'
55 character.)\0
56 .PP
57 The output of
58 .I rtcontrib
59 has many potential uses.
60 Source contributions can be used as components in linear combination to
61 reproduce any desired variation, e.g., simulating lighting controls or
62 changing sky conditions via daylight coefficients.
63 More generally,
64 .I rtcontrib
65 can be used to compute arbitrary input-output relationships in optical
66 systems, such as luminaires, light pipes, and shading devices.
67 .PP
68 .I Rtcontrib
69 calls
70 .I rtrace(1)
71 with the -oTW option to calculate the daughter ray
72 contributions for each input ray, and the output tallies
73 are sent to one or more destinations according to the given
74 .I \-o
75 specification.
76 If a destination begins with an exclamation mark ('!'), then
77 a pipe is opened to a command and data is sent to its standard input.
78 Otherwise, the destination is treated as a file.
79 An existing file of the same name will not be clobbered, unless the
80 .I \-fo
81 option is given.
82 If instead the
83 .I \-r
84 option is specified, data recovery is attempted on existing files.
85 If an output specification contains a "%s" format, this will be
86 replaced by the modifier name.
87 The
88 .I \-b
89 option may be used to further define
90 a "bin number" within each object if finer resolution is needed, and
91 this will be applied to a "%d" format in the output file
92 specification if present.
93 The actual bin number is computed at run time based on ray direction
94 and surface intersection, as described below.
95 If the number of bins is known in advance, it should be specified with the
96 .I \-bn
97 option, and this is critical for output files containing multiple values
98 per record.
99 Since bin numbers start from 0, the bin count is always equal to
100 the last bin plus 1.
101 Set the this value to 0 if the bin count is unknown (the default).
102 The most recent
103 .I \-b,
104 .I \-bn
105 and
106 .I \-o
107 options to the left of each
108 .I \-m
109 setting affect only that modifier.
110 (The ordering of other options is unimportant.)\0
111 .PP
112 If a
113 .I \-b
114 expression is defined for a particular modifier,
115 the bin number will be evaluated at run time for each
116 ray contribution from
117 .I rtrace.
118 Specifically, each ray's world intersection point will be assigned to
119 the variables Px, Py, and Pz, and the normalized ray direction
120 will be assigned to Dx, Dy, and Dz.
121 These parameters may be combined with definitions given in
122 .I \-e
123 arguments and files read using the
124 .I \-f
125 option.
126 The computed bin value will be
127 rounded to the nearest whole number.
128 This mechanism allows the user to define precise regions or directions
129 they wish to accumulate, such as the Tregenza sky discretization,
130 which would be otherwise impossible to specify
131 as a set of RADIANCE primitives.
132 The rules and predefined functions available for these expressions are
133 described in the
134 .I rcalc(1)
135 man page.
136 Unlike
137 .I rcalc,
138 .I rtcontrib
139 will search the RADIANCE library directories for each file given in a
140 .I \-f
141 option.
142 .PP
143 If no
144 .I \-o
145 specification is given, results are written on the standard output in order
146 of modifier (as given on the command line) then bin number.
147 Concatenated data is also sent to a single destination (i.e., an initial
148 .I \-o
149 specification without formatting strings).
150 If a "%s" format appears but no "%d" in the
151 .I \-o
152 specification, then each modifier will have its own output file, with
153 multiple values per record in the case of a non-zero
154 .I \-b
155 definition.
156 If a "%d" format appears but no "%s", then each bin will get its own
157 output file, with modifiers output in order in each record.
158 For text output, each RGB coefficient triple is separated by a tab,
159 with a newline at the end of each ray record.
160 For binary output formats, there is no such delimiter to mark
161 the end of each record.
162 .PP
163 Input and output format defaults to plain text, where each ray's
164 origin and direction (6 real values) are given on input,
165 and one line is produced per output file per ray.
166 Alternative data representations may be specified by the
167 .I \-f[io]
168 option, which is described in the
169 .I rtrace
170 man page along with the associated
171 .I \-x
172 and
173 .I \-y
174 resolution settings.
175 In particular, the color ('c') output data representation
176 together with positive dimensions for
177 .I \-x
178 and
179 .I \-y
180 will produce an uncompressed RADIANCE picture,
181 suitable for manipulation with
182 .I pcomb(1)
183 and related tools.
184 .PP
185 If the
186 .I \-n
187 option is specified with a value greater than 1, multiple
188 .I rtrace
189 processes will be used to accelerate computation on a shared
190 memory machine.
191 Note that there is no benefit to using more processes
192 than there are local CPUs available to do the work, and the
193 .I rtcontrib
194 process itself may use a considerable amount of CPU time.
195 .PP
196 Options may be given on the command line and/or read from the
197 environment and/or read from a file.
198 A command argument beginning with a dollar sign ('$') is immediately
199 replaced by the contents of the given environment variable.
200 A command argument beginning with an at sign ('@') is immediately
201 replaced by the contents of the given file.
202 .SH EXAMPLES
203 To compute the proportional contributions from sources modified
204 by "light1" vs. "light2" on a set of illuminance values:
205 .IP "" .2i
206 rtcontrib -I+ @render.opt -o c_%s.dat -m light1 -m light2 scene.oct < test.dat
207 .PP
208 To generate a pair of images corresponding to these two lights'
209 contributions:
210 .IP "" .2i
211 vwrays -ff -x 1024 -y 1024 -vf best.vf |
212 rtcontrib -ffc `vwrays -d -x 1024 -y 1024 -vf best.vf`
213 @render.opt -o c_%s.pic -m light1 -m light2 scene.oct
214 .PP
215 These images may then be recombined using the desired outputs
216 of light1 and light2:
217 .IP "" .2i
218 pcomb -c 100 90 75 c_light1.pic -c 50 55 57 c_light2.pic > combined.pic
219 .PP
220 To compute an array of illuminance contributions according to a Tregenza sky:
221 .IP "" .2i
222 rtcontrib -I+ -b tbin -o sky.dat -m skyglow -b 0 -o ground.dat -m groundglow
223 @render.opt -f tregenza.cal scene.oct < test.dat
224 .SH ENVIRONMENT
225 RAYPATH path to search for -f and -M files
226 .SH AUTHOR
227 Greg Ward
228 .SH "SEE ALSO"
229 cnt(1), getinfo(1), pcomb(1), pfilt(1), ra_rgbe(1),
230 rcalc(1), rpict(1), rtrace(1), vwrays(1), ximage(1)
