root/radiance/ray/doc/man/man1/rtcontrib.1
Revision: 1.11
Committed: Sat Jul 23 19:53:36 2005 UTC (18 years, 11 months ago) by greg
Minor fix in example
1 .\" RCSid "$Id: rtcontrib.1,v 1.10 2005/06/10 20:53:55 greg Exp $"
2 .TH RTCONTRIB 1 5/25/05 RADIANCE
3 .SH NAME
4 rtcontrib - compute contribution coefficients in a RADIANCE scene
5 .SH SYNOPSIS
6 .B rtcontrib
7 [
8 .B "\-n nprocs"
9 ][
10 .B \-r
11 ][
12 .B "\-e expr"
13 ][
14 .B "\-f source"
15 ][
16 .B "\-o ospec"
17 ][
18 .B "\-b binv"
19 ]
20 {
21 .B "\-m mod | \-M file"
22 }
23 ..
24 [
25 .B $EVAR
26 ]
27 [
28 .B @file
29 ]
30 [
31 rtrace options
32 ]
33 .B octree
34 .br
35 .B "rtcontrib [ options ] \-defaults"
36 .SH DESCRIPTION
37 .I Rtcontrib
38 computes ray contributions (i.e., color coefficients)
39 for objects whose modifiers are named in one or more
40 .I \-m
41 settings.
42 These modifiers are usually materials associated with
43 light sources or sky domes, and must directly modify some geometric
44 primitives to be considered in the output.
45 A modifier list may also be read from a file using the
46 .I \-M
47 option.
48 The RAYPATH environment variable determines directories to search for
49 this file.
50 (No search takes place if a file name begins with a '.', '/' or '~'
51 character.)\0
52 .PP
53 The output of
54 .I rtcontrib
55 has many potential uses.
56 Source contributions can be used as components in linear combination to
57 reproduce any desired variation, e.g., simulating lighting controls or
58 changing sky conditions via daylight coefficients.
59 More generally,
60 .I rtcontrib
61 can be used to compute arbitrary input-output relationships in optical
62 systems, such as luminaires, light pipes, and shading devices.
63 .PP
64 .I Rtcontrib
65 calls
66 .I rtrace(1)
67 with the -oTW option to calculate the daughter ray
68 contributions for each input ray, and the output tallies
69 are sent to one or more destinations according to the given
70 .I \-o
71 specification.
72 If a destination begins with an exclamation mark ('!'), then
73 a pipe is opened to a command and data is sent to its standard input.
74 Otherwise, the destination is treated as a file.
75 An existing file of the same name is clobbered, unless the
76 .I \-r
77 option is specified, in which case data recovery is attempted.
78 If an output specification contains a "%s" format, this will be
79 replaced by the modifier name.
80 The
81 .I \-b
82 option may be used to further define
83 a "bin number" within each object if finer resolution is needed, and
84 this will be applied to a "%d" format in the output file
85 specification if present.
86 The actual bin number is computed at run time based on ray direction
87 and surface intersection, as described below.
88 The most recent
89 .I \-b
90 and
91 .I \-o
92 options to the left of each
93 .I \-m
94 setting affect only that modifier.
95 (The ordering of other options is unimportant.)\0
96 .PP
97 If a
98 .I \-b
99 expression is defined for a particular modifier,
100 the bin number will be evaluated at run time for each
101 ray contribution from
102 .I rtrace.
103 Specifically, each ray's world intersection point will be assigned to
104 the variables Px, Py, and Pz, and the normalized ray direction
105 will be assigned to Dx, Dy, and Dz.
106 These parameters may be combined with definitions given in
107 .I \-e
108 arguments and files read using the
109 .I \-f
110 option.
111 The computed bin value will be
112 rounded to the nearest whole number.
113 This mechanism allows the user to define precise regions or directions
114 they wish to accumulate, such as the Tregenza sky discretization,
115 which would be otherwise impossible to specify
116 as a set of RADIANCE primitives.
117 The rules and predefined functions available for these expressions are
118 described in the
119 .I rcalc(1)
120 man page.
121 Unlike
122 .I rcalc,
123 .I rtcontrib
124 will search the RADIANCE library directories for each file given in a
125 .I \-f
126 option.
127 .PP
128 If no
129 .I \-o
130 specification is given, results are written on the standard output in order
131 of modifier (as given on the command line) then bin number.
132 Concatenated data is also sent to a single destination (i.e., an initial
133 .I \-o
134 specification without formatting strings).
135 If a "%s" format appears but no "%d" in the
136 .I \-o
137 specification, then each modifier will have its own output file, with
138 multiple values per record in the case of a non-zero
139 .I \-b
140 definition.
141 If a "%d" format appears but no "%s", then each bin will get its own
142 output file, with modifiers output in order in each record.
143 For text output, each RGB coefficient triple is separated by a tab,
144 with a newline at the end of each ray record.
145 For binary output formats, there is no such delimiter to mark
146 the end of each record.
147 .PP
148 Input and output format defaults to plain text, where each ray's
149 origin and direction (6 real values) are given on input,
150 and one line is produced per output file per ray.
151 Alternative data representations may be specified by the
152 .I \-f[io]
153 option, which is described in the
154 .I rtrace
155 man page along with the associated
156 .I \-x
157 and
158 .I \-y
159 resolution settings.
160 In particular, the color ('c') output data representation
161 together with positive dimensions for
162 .I \-x
163 and
164 .I \-y
165 will produce an uncompressed RADIANCE picture,
166 suitable for manipulation with
167 .I pcomb(1)
168 and related tools.
169 .PP
170 If the
171 .I \-n
172 option is specified with a value greater than 1, multiple
173 .I rtrace
174 processes will be used to accelerate computation on a shared
175 memory machine.
176 Note that there is no benefit to using more processes
177 than there are local CPUs available to do the work, and the
178 .I rtcontrib
179 process itself may use a considerable amount of CPU time.
180 .PP
181 Options may be given on the command line and/or read from the
182 environment and/or read from a file.
183 A command argument beginning with a dollar sign ('$') is immediately
184 replaced by the contents of the given environment variable.
185 A command argument beginning with an at sign ('@') is immediately
186 replaced by the contents of the given file.
187 .SH EXAMPLES
188 To compute the proportional contributions from sources modified
189 by "light1" vs. "light2" on a set of illuminance values:
190 .IP "" .2i
191 rtcontrib -I+ @render.opt -o c_%s.dat -m light1 -m light2 scene.oct < test.dat
192 .PP
193 To generate a pair of images corresponding to these two lights'
194 contributions:
195 .IP "" .2i
196 vwrays -ff -x 1024 -y 1024 -vf best.vf |
197 rtcontrib -ffc `vwrays -d -x 1024 -y 1024 -vf best.vf`
198 @render.opt -o c_%s.pic -m light1 -m light2 scene.oct
199 .PP
200 These images may then be recombined using the desired outputs
201 of light1 and light2:
202 .IP "" .2i
203 pcomb -c 100 90 75 c_light1.pic -c 50 55 57 c_light2.pic > combined.pic
204 .PP
205 To compute an array of illuminance contributions according to a Tregenza sky:
206 .IP "" .2i
207 rtcontrib -I+ -b tbin -o sky.dat -m skyglow -b 0 -o ground.dat -m groundglow
208 @render.opt -f tregenza.cal scene.oct < test.dat
209 .SH ENVIRONMENT
210 RAYPATH path to search for -f and -M files
211 .SH AUTHOR
212 Greg Ward
213 .SH "SEE ALSO"
214 cnt(1), getinfo(1), pcomb(1), pfilt(1), ra_rgbe(1),
215 rcalc(1), rpict(1), rtrace(1), vwrays(1), ximage(1)
