| 1 |
.\" RCSid "$Id$"
| 2 |
.TH RPIECE 1 5/25/05 RADIANCE
| 3 |
.SH NAME
| 4 |
rtcontrib - compute contributions in a RADIANCE scene
| 5 |
.SH SYNOPSIS
| 6 |
.B rtcontrib
| 7 |
| 8 |
.B "\-n nprocs"
| 9 |
| 10 |
.B "\-e expr"
| 11 |
| 12 |
.B "\-f source"
| 13 |
| 14 |
.B "\-o fspec"
| 15 |
| 16 |
.B "\-b binv"
| 17 |
| 18 |
| 19 |
.B $EVAR
| 20 |
| 21 |
| 22 |
.B @file
| 23 |
| 24 |
| 25 |
rtrace options
| 26 |
| 27 |
.B "\-m mod .."
| 28 |
.B octree
| 29 |
.SH DESCRIPTION
| 30 |
.I Rtcontrib
| 31 |
computes ray contributions (i.e., color coefficients)
| 32 |
for objects whose modifiers are named in one or more
| 33 |
.I \-m
| 34 |
settings.
| 35 |
These modifiers are usually materials associated with specific
| 36 |
light sources, though they could correspond to intermediate objects as well.
| 37 |
The resulting contributions may then be used in linear combination to
| 38 |
reproduce any desired variation, e.g., simulating lighting controls or
| 39 |
changing sky conditions via daylight coefficients.
| 40 |
More generally,
| 41 |
.I rtcontrib
| 42 |
can compute general input-output relationships in optical
| 43 |
systems, such as light pipes and shading devices.
| 44 |
.PP
| 45 |
.I Rtrace(1)
| 46 |
is called to calculate the contributions for each input ray,
| 47 |
and the output tallies are sent to one or more files according to the
| 48 |
.I \-o
| 49 |
specification.
| 50 |
If the output file specification contains a "%s" format, this will be
| 51 |
replaced by the modifier name.
| 52 |
The
| 53 |
.I \-b
| 54 |
option may be used to further define
| 55 |
a "bin number" within each object if finer resolution is desired, and
| 56 |
will be applied to a "%d" format in the output file
| 57 |
specification if present.
| 58 |
(The actual bin number is computed at run time based on ray direction
| 59 |
and surface intersection, as described below.)\0
| 60 |
The most recent
| 61 |
.I \-b
| 62 |
and
| 63 |
.I \-o
| 64 |
options (to the left) of each
| 65 |
.I \-m
| 66 |
setting affect only that modifier, and the ordering
| 67 |
of other options is unimportant.
| 68 |
.PP
| 69 |
Input and output format defaults to plain text, where each ray's
| 70 |
origin and direction (6 real values) must appear together per
| 71 |
line of input, and one line of output is produced per output file
| 72 |
file per ray.
| 73 |
Alternative input and output formats may be specified using the
| 74 |
.I \-f[io]
| 75 |
option, which is explained in the
| 76 |
.I rtrace
| 77 |
man page along with the associated
| 78 |
.I \-x
| 79 |
and
| 80 |
.I \-y
| 81 |
resolution settings.
| 82 |
In particular, the 'c' output setting
| 83 |
together with positive dimensions for
| 84 |
.I \-x
| 85 |
and
| 86 |
.I \-y
| 87 |
will produce an uncompressed RADIANCE picture,
| 88 |
suitable for manipulation with
| 89 |
.I pcomb(1)
| 90 |
and related tools.
| 91 |
.PP
| 92 |
If no
| 93 |
.I \-o
| 94 |
specification is given, results are written on the standard output in order
| 95 |
of modifier (as given on the command line) then bin number.
| 96 |
The same format is used for a simple file name specification
| 97 |
without any embedded "%s" or "%d" formats.
| 98 |
If a "%s" format appears but no "%d" in the
| 99 |
.I \-o
| 100 |
specification, then each modifier will have its own output file, with
| 101 |
multiple values per record in the case of a non-zero
| 102 |
.I \-b
| 103 |
definition.
| 104 |
If a "%d" format appears but no "%s", then each bin will get its own
| 105 |
output file, with modifiers output in order in each record.
| 106 |
For text output, each RGB coefficient triple is separated by a tab,
| 107 |
with a newline at the end of each ray record.
| 108 |
For binary output formats, there is no such delimiter to mark
| 109 |
the end of each record.
| 110 |
.PP
| 111 |
If a
| 112 |
.I \-b
| 113 |
expression is defined for a particular modifier,
| 114 |
the bin number will be evaluated at run time for each
| 115 |
ray contribution from
| 116 |
.I rtrace.
| 117 |
Specifically, each ray's world intersection point will be assigned to
| 118 |
the variables Px, Py, and Pz, and the normalized ray direction
| 119 |
will be assigned to Dx, Dy, and Dz.
| 120 |
These ray parameters may be combined with any definitions given in
| 121 |
.I \-e
| 122 |
options, or any files read in from
| 123 |
.I \-f
| 124 |
options, to compute the bin, which will be
| 125 |
rounded to the closest whole number.
| 126 |
This mechanism allows the user to define precise regions (or directions)
| 127 |
they wish to accumulate, such as the Tregenza sky grid, which would be
| 128 |
otherwise impossible to specify as a set of RADIANCE primitives.
| 129 |
.PP
| 130 |
If the
| 131 |
.I \-n
| 132 |
option is specified with a value greater than 1, multiple
| 133 |
.I rtrace(1)
| 134 |
processes will be used to accelerate computation on a shared
| 135 |
memory machine.
| 136 |
Note that there is no benefit to using more processes
| 137 |
than there are local CPUs available to do the work.
| 138 |
.PP
| 139 |
Options may be given on the command line and/or read from the
| 140 |
environment and/or read from a file.
| 141 |
A command argument beginning with a dollar sign ('$') is immediately
| 142 |
replaced by the contents of the given environment variable.
| 143 |
A command argument beginning with an at sign ('@') is immediately
| 144 |
replaced by the contents of the given file.
| 145 |
.SH EXAMPLE
| 146 |
First
| 147 |
.I rpiece
| 148 |
process is started on the machine "goober":
| 149 |
.IP "" .2i
| 150 |
goober% echo 1 8 > syncfile
| 151 |
.br
| 152 |
goober% echo -F syncfile -x 1024 -y 1024 -vf view -o picture octree > args
| 153 |
.br
| 154 |
goober% rpiece @args &
| 155 |
.PP
| 156 |
Second
| 157 |
.I rpiece
| 158 |
processes is started on the machine "sucker":
| 159 |
.IP "" .2i
| 160 |
sucker% rpiece @args &
| 161 |
.SH NOTES
| 162 |
Due to NFS file buffering, the network lock manager is employed to
| 163 |
guarantee consistency in the output file even though non-overlapping
| 164 |
writes are used.
| 165 |
This would tend to slow the process down if
| 166 |
.I rpiece
| 167 |
were to wait for this I/O to complete before starting on the next
| 168 |
piece, so
| 169 |
.I rpiece
| 170 |
forks separate processes to hang around waiting for I/O completion.
| 171 |
The number of processes thus designated is set by the MAXFORK macro
| 172 |
in the program (compiled in the src/util directory).
| 173 |
If the fork call is slow on a system, it may actually be better to
| 174 |
set MAXFORK to zero.
| 175 |
In other cases, the network lock manager may be so slow that this
| 176 |
value should be increased to get the best utilization.
| 177 |
.PP
| 178 |
The output picture is not run-length encoded, and can be quite
| 179 |
large.
| 180 |
The approximate size (in kilobytes) can be computed by the simple
| 181 |
formula:
| 182 |
.IP "" .2i
| 183 |
filesize = xres*yres/256
| 184 |
.PP
| 185 |
Make sure that there is enough space on the filesystem to hold the
| 186 |
entire picture before beginning.
| 187 |
Once the picture is finished, the
| 188 |
.I ra_rgbe(1)
| 189 |
program with the -r option may be used to convert to a run-length
| 190 |
encoded picture for more efficient storage, although
| 191 |
.I pfilt(1)
| 192 |
or any of the other Radiance picture filters will do the same
| 193 |
thing.
| 194 |
.PP
| 195 |
The ALRM signal may be used to gracefully terminate an
| 196 |
.I rpiece
| 197 |
process after it finishes the current piece.
| 198 |
This permits other currently running or subsequently started
| 199 |
.I rpiece
| 200 |
process(es) to continue rendering the picture without loss.
| 201 |
The
| 202 |
.I \-T
| 203 |
option will send the ALRM signal to
| 204 |
.I rpiece
| 205 |
after the specified number of (decimal) hours.
| 206 |
This is the best way to force a time limit on the computation,
| 207 |
since information will not be lost, though the process may continue
| 208 |
for some time afterwards to finish its current piece.
| 209 |
.SH BUGS
| 210 |
This program may not work on some systems whose NFS lock manager is
| 211 |
unreliable.
| 212 |
In particular, some System V derivative UNIX systems often have
| 213 |
problems with the network lock manager.
| 214 |
If the output is scrambled or rpict aborts with some ambient file
| 215 |
related problem, you should just remove the ambient file and go
| 216 |
back to normal rendering.
| 217 |
.SH AUTHOR
| 218 |
Greg Ward
| 219 |
.SH "SEE ALSO"
| 220 |
cnt(1), getinfo(1), pcomb(1), pfilt(1), ra_rgbe(1),
| 221 |
rcalc(1), rpict(1), rtrace(1), vwrays(1), ximage(1)
