root/radiance/ray/doc/man/man1/rtcontrib.1
Revision: 1.16
Committed: Tue Sep 4 17:36:41 2007 UTC (17 years, 9 months ago) by greg
Changes since 1.15: +10 -10 lines
Added backslashes in front of hyphens (thanks to Bernd Zeimetz for his effort)
1 .\" RCSid "$Id: rtcontrib.1,v 1.15 2006/02/05 22:22:20 greg Exp $"
2 .TH RTCONTRIB 1 5/25/05 RADIANCE
3 .SH NAME
4 rtcontrib - compute contribution coefficients in a RADIANCE scene
5 .SH SYNOPSIS
6 .B rtcontrib
7 [
8 .B "\-n nprocs"
9 ][
10 .B \-V
11 ][
12 .B \-fo
13 |
14 .B \-r
15 ][
16 .B "\-e expr"
17 ][
18 .B "\-f source"
19 ][
20 .B "\-o ospec"
21 ][
22 .B "\-b binv"
23 ][
24 .B "\-bn nbins"
25 ]
26 {
27 .B "\-m mod | \-M file"
28 }
29 ..
30 [
31 .B $EVAR
32 ]
33 [
34 .B @file
35 ]
36 [
37 rtrace options
38 ]
39 .B octree
40 .br
41 .B "rtcontrib [ options ] \-defaults"
42 .SH DESCRIPTION
43 .I Rtcontrib
44 computes ray coefficients
45 for objects whose modifiers are named in one or more
46 .I \-m
47 settings.
48 These modifiers are usually materials associated with
49 light sources or sky domes, and must directly modify some geometric
50 primitives to be considered in the output.
51 A modifier list may also be read from a file using the
52 .I \-M
53 option.
54 The RAYPATH environment variable determines directories to search for
55 this file.
56 (No search takes place if a file name begins with a '.', '/' or '~'
57 character.)\0
58 .PP
59 By setting the boolean
60 .I \-V
61 option, you may instruct
62 .I rtcontrib
63 to report the contribution from each material rather than the ray
64 coefficient.
65 This is particularly useful for light sources with directional output
66 distributions, whose value would otherwise be lost in the shuffle.
67 With the default
68 .I -V-
69 setting, the output of rtcontrib is a coefficient that must be multiplied
70 by the radiance of each material to arrive at a final contribution.
71 This is more convenient for computing daylight coefficeints, or cases
72 where the actual radiance is not desired.
73 Use the
74 .I -V+
75 setting when you wish to simply sum together contributions
76 (with possible adjustment factors) to obtain a final radiance value.
77 Combined with the
78 .I \-i
79 or
80 .I \-I
81 option, irradiance contributions are reported by
82 .I \-V+
83 rather than radiance, and
84 .I \-V-
85 coefficients contain an additonal factor of PI.
86 .PP
87 The output of
88 .I rtcontrib
89 has many potential uses.
90 Source contributions can be used as components in linear combination to
91 reproduce any desired variation, e.g., simulating lighting controls or
92 changing sky conditions via daylight coefficients.
93 More generally,
94 .I rtcontrib
95 can be used to compute arbitrary input-output relationships in optical
96 systems, such as luminaires, light pipes, and shading devices.
97 .PP
98 .I Rtcontrib
99 calls
100 .I rtrace(1)
101 with the \-oTW (or \-oTV) option to calculate the daughter ray
102 contributions for each input ray, and the output tallies
103 are sent to one or more destinations according to the given
104 .I \-o
105 specification.
106 If a destination begins with an exclamation mark ('!'), then
107 a pipe is opened to a command and data is sent to its standard input.
108 Otherwise, the destination is treated as a file.
109 An existing file of the same name will not be clobbered, unless the
110 .I \-fo
111 option is given.
112 If instead the
113 .I \-r
114 option is specified, data recovery is attempted on existing files.
115 If an output specification contains a "%s" format, this will be
116 replaced by the modifier name.
117 The
118 .I \-b
119 option may be used to further define
120 a "bin number" within each object if finer resolution is needed, and
121 this will be applied to a "%d" format in the output file
122 specification if present.
123 The actual bin number is computed at run time based on ray direction
124 and surface intersection, as described below.
125 If the number of bins is known in advance, it should be specified with the
126 .I \-bn
127 option, and this is critical for output files containing multiple values
128 per record.
129 Since bin numbers start from 0, the bin count is always equal to
130 the last bin plus 1.
131 Set the this value to 0 if the bin count is unknown (the default).
132 The most recent
133 .I \-b,
134 .I \-bn
135 and
136 .I \-o
137 options to the left of each
138 .I \-m
139 setting affect only that modifier.
140 (The ordering of other options is unimportant.)\0
141 .PP
142 If a
143 .I \-b
144 expression is defined for a particular modifier,
145 the bin number will be evaluated at run time for each
146 ray contribution from
147 .I rtrace.
148 Specifically, each ray's world intersection point will be assigned to
149 the variables Px, Py, and Pz, and the normalized ray direction
150 will be assigned to Dx, Dy, and Dz.
151 These parameters may be combined with definitions given in
152 .I \-e
153 arguments and files read using the
154 .I \-f
155 option.
156 The computed bin value will be
157 rounded to the nearest whole number.
158 This mechanism allows the user to define precise regions or directions
159 they wish to accumulate, such as the Tregenza sky discretization,
160 which would be otherwise impossible to specify
161 as a set of RADIANCE primitives.
162 The rules and predefined functions available for these expressions are
163 described in the
164 .I rcalc(1)
165 man page.
166 Unlike
167 .I rcalc,
168 .I rtcontrib
169 will search the RADIANCE library directories for each file given in a
170 .I \-f
171 option.
172 .PP
173 If no
174 .I \-o
175 specification is given, results are written on the standard output in order
176 of modifier (as given on the command line) then bin number.
177 Concatenated data is also sent to a single destination (i.e., an initial
178 .I \-o
179 specification without formatting strings).
180 If a "%s" format appears but no "%d" in the
181 .I \-o
182 specification, then each modifier will have its own output file, with
183 multiple values per record in the case of a non-zero
184 .I \-b
185 definition.
186 If a "%d" format appears but no "%s", then each bin will get its own
187 output file, with modifiers output in order in each record.
188 For text output, each RGB coefficient triple is separated by a tab,
189 with a newline at the end of each ray record.
190 For binary output formats, there is no such delimiter to mark
191 the end of each record.
192 .PP
193 Input and output format defaults to plain text, where each ray's
194 origin and direction (6 real values) are given on input,
195 and one line is produced per output file per ray.
196 Alternative data representations may be specified by the
197 .I \-f[io]
198 option, which is described in the
199 .I rtrace
200 man page along with the associated
201 .I \-x
202 and
203 .I \-y
204 resolution settings.
205 In particular, the color ('c') output data representation
206 together with positive dimensions for
207 .I \-x
208 and
209 .I \-y
210 will produce an uncompressed RADIANCE picture,
211 suitable for manipulation with
212 .I pcomb(1)
213 and related tools.
214 .PP
215 If the
216 .I \-n
217 option is specified with a value greater than 1, multiple
218 .I rtrace
219 processes will be used to accelerate computation on a shared
220 memory machine.
221 Note that there is no benefit to using more processes
222 than there are local CPUs available to do the work, and the
223 .I rtcontrib
224 process itself may use a considerable amount of CPU time.
225 .PP
226 Options may be given on the command line and/or read from the
227 environment and/or read from a file.
228 A command argument beginning with a dollar sign ('$') is immediately
229 replaced by the contents of the given environment variable.
230 A command argument beginning with an at sign ('@') is immediately
231 replaced by the contents of the given file.
232 .SH EXAMPLES
233 To compute the proportional contributions from sources modified
234 by "light1" vs. "light2" on a set of illuminance values:
235 .IP "" .2i
236 rtcontrib \-I+ @render.opt \-o c_%s.dat \-m light1 \-m light2 scene.oct < test.dat
237 .PP
238 To generate a pair of images corresponding to these two lights'
239 contributions:
240 .IP "" .2i
241 vwrays \-ff \-x 1024 \-y 1024 \-vf best.vf |
242 rtcontrib \-ffc `vwrays \-d \-x 1024 \-y 1024 \-vf best.vf`
243 @render.opt \-o c_%s.pic \-m light1 \-m light2 scene.oct
244 .PP
245 These images may then be recombined using the desired outputs
246 of light1 and light2:
247 .IP "" .2i
248 pcomb \-c 100 90 75 c_light1.pic \-c 50 55 57 c_light2.pic > combined.pic
249 .PP
250 To compute an array of illuminance contributions according to a Tregenza sky:
251 .IP "" .2i
252 rtcontrib \-I+ \-b tbin \-o sky.dat \-m skyglow \-b 0 \-o ground.dat \-m groundglow
253 @render.opt \-f tregenza.cal scene.oct < test.dat
254 .SH ENVIRONMENT
255 RAYPATH path to search for \-f and \-M files
256 .SH AUTHOR
257 Greg Ward
258 .SH "SEE ALSO"
259 cnt(1), getinfo(1), pcomb(1), pfilt(1), ra_rgbe(1),
260 rcalc(1), rpict(1), rtrace(1), vwrays(1), ximage(1)
