root/radiance/ray/doc/man/man1/rtcontrib.1
Revision: 1.1
Committed: Thu May 26 06:55:22 2005 UTC (20 years, 1 month ago) by greg
1 .\" RCSid "$Id$"
2 .TH RPIECE 1 5/25/05 RADIANCE
3 .SH NAME
4 rtcontrib - compute contributions in a RADIANCE scene
5 .SH SYNOPSIS
6 .B rtcontrib
7 [
8 .B "\-n nprocs"
9 ][
10 .B "\-e expr"
11 ][
12 .B "\-f source"
13 ][
14 .B "\-o fspec"
15 ][
16 .B "\-b binv"
17 ]
18 [
19 .B $EVAR
20 ]
21 [
22 .B @file
23 ]
24 [
25 rtrace options
26 ]
27 .B "\-m mod .."
28 .B octree
29 .SH DESCRIPTION
30 .I Rtcontrib
31 computes ray contributions (i.e., color coefficients)
32 for objects whose modifiers are named in one or more
33 .I \-m
34 settings.
35 These modifiers are usually materials associated with specific
36 light sources, though they could correspond to intermediate objects as well.
37 The resulting contributions may then be used in linear combination to
38 reproduce any desired variation, e.g., simulating lighting controls or
39 changing sky conditions via daylight coefficients.
40 More generally,
41 .I rtcontrib
42 can compute general input-output relationships in optical
43 systems, such as light pipes and shading devices.
44 .PP
45 .I Rtrace(1)
46 is called to calculate the contributions for each input ray,
47 and the output tallies are sent to one or more files according to the
48 .I \-o
49 specification.
50 If the output file specification contains a "%s" format, this will be
51 replaced by the modifier name.
52 The
53 .I \-b
54 option may be used to further define
55 a "bin number" within each object if finer resolution is desired, and
56 will be applied to a "%d" format in the output file
57 specification if present.
58 (The actual bin number is computed at run time based on ray direction
59 and surface intersection, as described below.)\0
60 The most recent
61 .I \-b
62 and
63 .I \-o
64 options (to the left) of each
65 .I \-m
66 setting affect only that modifier, and the ordering
67 of other options is unimportant.
68 .PP
69 Input and output format defaults to plain text, where each ray's
70 origin and direction (6 real values) must appear together per
71 line of input, and one line of output is produced per output file
72 file per ray.
73 Alternative input and output formats may be specified using the
74 .I \-f[io]
75 option, which is explained in the
76 .I rtrace
77 man page along with the associated
78 .I \-x
79 and
80 .I \-y
81 resolution settings.
82 In particular, the 'c' output setting
83 together with positive dimensions for
84 .I \-x
85 and
86 .I \-y
87 will produce an uncompressed RADIANCE picture,
88 suitable for manipulation with
89 .I pcomb(1)
90 and related tools.
91 .PP
92 If no
93 .I \-o
94 specification is given, results are written on the standard output in order
95 of modifier (as given on the command line) then bin number.
96 The same format is used for a simple file name specification
97 without any embedded "%s" or "%d" formats.
98 If a "%s" format appears but no "%d" in the
99 .I \-o
100 specification, then each modifier will have its own output file, with
101 multiple values per record in the case of a non-zero
102 .I \-b
103 definition.
104 If a "%d" format appears but no "%s", then each bin will get its own
105 output file, with modifiers output in order in each record.
106 For text output, each RGB coefficient triple is separated by a tab,
107 with a newline at the end of each ray record.
108 For binary output formats, there is no such delimiter to mark
109 the end of each record.
110 .PP
111 If a
112 .I \-b
113 expression is defined for a particular modifier,
114 the bin number will be evaluated at run time for each
115 ray contribution from
116 .I rtrace.
117 Specifically, each ray's world intersection point will be assigned to
118 the variables Px, Py, and Pz, and the normalized ray direction
119 will be assigned to Dx, Dy, and Dz.
120 These ray parameters may be combined with any definitions given in
121 .I \-e
122 options, or any files read in from
123 .I \-f
124 options, to compute the bin, which will be
125 rounded to the closest whole number.
126 This mechanism allows the user to define precise regions (or directions)
127 they wish to accumulate, such as the Tregenza sky grid, which would be
128 otherwise impossible to specify as a set of RADIANCE primitives.
129 .PP
130 If the
131 .I \-n
132 option is specified with a value greater than 1, multiple
133 .I rtrace(1)
134 processes will be used to accelerate computation on a shared
135 memory machine.
136 Note that there is no benefit to using more processes
137 than there are local CPUs available to do the work.
138 .PP
139 Options may be given on the command line and/or read from the
140 environment and/or read from a file.
141 A command argument beginning with a dollar sign ('$') is immediately
142 replaced by the contents of the given environment variable.
143 A command argument beginning with an at sign ('@') is immediately
144 replaced by the contents of the given file.
145 .SH EXAMPLE
146 First
147 .I rpiece
148 process is started on the machine "goober":
149 .IP "" .2i
150 goober% echo 1 8 > syncfile
151 .br
152 goober% echo -F syncfile -x 1024 -y 1024 -vf view -o picture octree > args
153 .br
154 goober% rpiece @args &
155 .PP
156 Second
157 .I rpiece
158 processes is started on the machine "sucker":
159 .IP "" .2i
160 sucker% rpiece @args &
161 .SH NOTES
162 Due to NFS file buffering, the network lock manager is employed to
163 guarantee consistency in the output file even though non-overlapping
164 writes are used.
165 This would tend to slow the process down if
166 .I rpiece
167 were to wait for this I/O to complete before starting on the next
168 piece, so
169 .I rpiece
170 forks separate processes to hang around waiting for I/O completion.
171 The number of processes thus designated is set by the MAXFORK macro
172 in the program (compiled in the src/util directory).
173 If the fork call is slow on a system, it may actually be better to
174 set MAXFORK to zero.
175 In other cases, the network lock manager may be so slow that this
176 value should be increased to get the best utilization.
177 .PP
178 The output picture is not run-length encoded, and can be quite
179 large.
180 The approximate size (in kilobytes) can be computed by the simple
181 formula:
182 .IP "" .2i
183 filesize = xres*yres/256
184 .PP
185 Make sure that there is enough space on the filesystem to hold the
186 entire picture before beginning.
187 Once the picture is finished, the
188 .I ra_rgbe(1)
189 program with the -r option may be used to convert to a run-length
190 encoded picture for more efficient storage, although
191 .I pfilt(1)
192 or any of the other Radiance picture filters will do the same
193 thing.
194 .PP
195 The ALRM signal may be used to gracefully terminate an
196 .I rpiece
197 process after it finishes the current piece.
198 This permits other currently running or subsequently started
199 .I rpiece
200 process(es) to continue rendering the picture without loss.
201 The
202 .I \-T
203 option will send the ALRM signal to
204 .I rpiece
205 after the specified number of (decimal) hours.
206 This is the best way to force a time limit on the computation,
207 since information will not be lost, though the process may continue
208 for some time afterwards to finish its current piece.
209 .SH BUGS
210 This program may not work on some systems whose NFS lock manager is
211 unreliable.
212 In particular, some System V derivative UNIX systems often have
213 problems with the network lock manager.
214 If the output is scrambled or rpict aborts with some ambient file
215 related problem, you should just remove the ambient file and go
216 back to normal rendering.
217 .SH AUTHOR
218 Greg Ward
219 .SH "SEE ALSO"
220 cnt(1), getinfo(1), pcomb(1), pfilt(1), ra_rgbe(1),
221 rcalc(1), rpict(1), rtrace(1), vwrays(1), ximage(1)
