root/Development/ray/doc/man/man1/rtcontrib.1
Revision: 1.9
Committed: Fri Jun 10 16:42:10 2005 UTC (20 years, 6 months ago) by greg
Changes since 1.8: +9 -2 lines
Added rtcontrib -M option to read modifier list from a file
1 .\" RCSid "$Id: rtcontrib.1,v 1.8 2005/06/09 17:27:27 greg Exp $"
2 .TH RTCONTRIB 1 5/25/05 RADIANCE
3 .SH NAME
4 rtcontrib - compute contribution coefficients in a RADIANCE scene
5 .SH SYNOPSIS
6 .B rtcontrib
7 [
8 .B "\-n nprocs"
9 ][
10 .B \-r
11 ][
12 .B "\-e expr"
13 ][
14 .B "\-f source"
15 ][
16 .B "\-o ospec"
17 ][
18 .B "\-b binv"
19 ]
20 {
21 .B "\-m mod | \-M file"
22 }
23 ..
24 [
25 .B $EVAR
26 ]
27 [
28 .B @file
29 ]
30 [
31 rtrace options
32 ]
33 .B octree
34 .br
35 .B "rtcontrib [ options ] \-defaults"
36 .SH DESCRIPTION
37 .I Rtcontrib
38 computes ray contributions (i.e., color coefficients)
39 for objects whose modifiers are named in one or more
40 .I \-m
41 settings.
42 These modifiers are usually materials associated with
43 light sources or sky domes, and must directly modify some geometric
44 primitives to be considered in the output.
45 A modifier list may also be read from a file using the
46 .I \-M
47 option.
48 .PP
49 The output of
50 .I rtcontrib
51 has many potential uses.
52 Source contributions can be used as components in linear combination to
53 reproduce any desired variation, e.g., simulating lighting controls or
54 changing sky conditions via daylight coefficients.
55 More generally,
56 .I rtcontrib
57 can be used to compute arbitrary input-output relationships in optical
58 systems, such as luminaires, light pipes, and shading devices.
59 .PP
60 .I Rtcontrib
61 calls
62 .I rtrace(1)
63 with the -oTW option to calculate the daughter ray
64 contributions for each input ray, and the output tallies
65 are sent to one or more destinations according to the given
66 .I \-o
67 specification.
68 If a destination begins with an exclamation mark ('!'), then
69 a pipe is opened to a command and data is sent to its standard input.
70 Otherwise, the destination is treated as a file.
71 An existing file of the same name is clobbered, unless the
72 .I \-r
73 option is specified, in which case data recovery is attempted.
74 If an output specification contains a "%s" format, this will be
75 replaced by the modifier name.
76 The
77 .I \-b
78 option may be used to further define
79 a "bin number" within each object if finer resolution is needed, and
80 this will be applied to a "%d" format in the output file
81 specification if present.
82 The actual bin number is computed at run time based on ray direction
83 and surface intersection, as described below.
84 The most recent
85 .I \-b
86 and
87 .I \-o
88 options to the left of each
89 .I \-m
90 setting affect only that modifier.
91 (The ordering of other options is unimportant.)\0
92 .PP
93 If a
94 .I \-b
95 expression is defined for a particular modifier,
96 the bin number will be evaluated at run time for each
97 ray contribution from
98 .I rtrace.
99 Specifically, each ray's world intersection point will be assigned to
100 the variables Px, Py, and Pz, and the normalized ray direction
101 will be assigned to Dx, Dy, and Dz.
102 These parameters may be combined with definitions given in
103 .I \-e
104 arguments and files read using the
105 .I \-f
106 option.
107 The computed bin value will be
108 rounded to the nearest whole number.
109 This mechanism allows the user to define precise regions or directions
110 they wish to accumulate, such as the Tregenza sky discretization,
111 which would be otherwise impossible to specify
112 as a set of RADIANCE primitives.
113 The rules and predefined functions available for these expressions are
114 described in the
115 .I rcalc(1)
116 man page.
117 Unlike
118 .I rcalc,
119 .I rtcontrib
120 will search the RADIANCE library directories for each file given in a
121 .I \-f
122 option.
123 (No search takes place if a file name begins with a '.', '/' or '~'
124 character.)\0
125 .PP
126 If no
127 .I \-o
128 specification is given, results are written on the standard output in order
129 of modifier (as given on the command line) then bin number.
130 Concatenated data is also sent to a single destination (i.e., an initial
131 .I \-o
132 specification without formatting strings).
133 If a "%s" format appears but no "%d" in the
134 .I \-o
135 specification, then each modifier will have its own output file, with
136 multiple values per record in the case of a non-zero
137 .I \-b
138 definition.
139 If a "%d" format appears but no "%s", then each bin will get its own
140 output file, with modifiers output in order in each record.
141 For text output, each RGB coefficient triple is separated by a tab,
142 with a newline at the end of each ray record.
143 For binary output formats, there is no such delimiter to mark
144 the end of each record.
145 .PP
146 Input and output format defaults to plain text, where each ray's
147 origin and direction (6 real values) are given on input,
148 and one line is produced per output file per ray.
149 Alternative data representations may be specified by the
150 .I \-f[io]
151 option, which is described in the
152 .I rtrace
153 man page along with the associated
154 .I \-x
155 and
156 .I \-y
157 resolution settings.
158 In particular, the color ('c') output data representation
159 together with positive dimensions for
160 .I \-x
161 and
162 .I \-y
163 will produce an uncompressed RADIANCE picture,
164 suitable for manipulation with
165 .I pcomb(1)
166 and related tools.
167 .PP
168 If the
169 .I \-n
170 option is specified with a value greater than 1, multiple
171 .I rtrace
172 processes will be used to accelerate computation on a shared
173 memory machine.
174 Note that there is no benefit to using more processes
175 than there are local CPUs available to do the work, and the
176 .I rtcontrib
177 process itself may use a considerable amount of CPU time.
178 .PP
179 Options may be given on the command line and/or read from the
180 environment and/or read from a file.
181 A command argument beginning with a dollar sign ('$') is immediately
182 replaced by the contents of the given environment variable.
183 A command argument beginning with an at sign ('@') is immediately
184 replaced by the contents of the given file.
185 .SH EXAMPLES
186 To compute the proportional contributions from sources modified
187 by "light1" vs. "light2" on a set of illuminance values:
188 .IP "" .2i
189 rtcontrib -I+ @render.opt -o c_%s.dat -m light1 -m light2 scene.oct < test.dat
190 .PP
191 To generate a pair of images corresponding to these two lights'
192 contributions:
193 .IP "" .2i
194 vwrays -ff -x 1024 -y 1024 -vf best.vf |
195 rtcontrib -ffc `vwrays -d -x 1024 -y 1024 -vf best.vf`
196 @render.opt -o c_%s.pic -m light1 -m light2 scene.oct
197 .PP
198 These images may then be recombined using the desired outputs
199 of light1 and light2:
200 .IP "" .2i
201 pcomb -c 100 90 75 c_light1.pic -c 50 55 57 c_light2.pic > combined.pic
202 .PP
203 To compute an array of illuminance contributions according to a Tregenza sky:
204 .IP "" .2i
205 rtcontrib -b tbin -o sky.dat -m skyglow -b 0 -o ground.dat -m groundglow
206 @render.opt -f tregenza.cal scene.oct < test.dat
207 .SH ENVIRONMENT
208 RAYPATH path to search for -f files
209 .SH AUTHOR
210 Greg Ward
211 .SH "SEE ALSO"
212 cnt(1), getinfo(1), pcomb(1), pfilt(1), ra_rgbe(1),
213 rcalc(1), rpict(1), rtrace(1), vwrays(1), ximage(1)
