| 1 |
.\" RCSid "$Id: rtcontrib.1,v 1.6 2005/06/01 16:11:01 greg Exp $"
| 2 |
.TH RTCONTRIB 1 5/25/05 RADIANCE
| 3 |
.SH NAME
| 4 |
rtcontrib - compute contribution coefficients in a RADIANCE scene
| 5 |
.SH SYNOPSIS
| 6 |
.B rtcontrib
| 7 |
| 8 |
.B "\-n nprocs"
| 9 |
| 10 |
.B "\-e expr"
| 11 |
| 12 |
.B "\-f source"
| 13 |
| 14 |
.B "\-o ospec"
| 15 |
| 16 |
.B "\-b binv"
| 17 |
| 18 |
.B "\-m mod .."
| 19 |
| 20 |
.B $EVAR
| 21 |
| 22 |
| 23 |
.B @file
| 24 |
| 25 |
| 26 |
rtrace options
| 27 |
| 28 |
.B octree
| 29 |
.br
| 30 |
.B "rtcontrib [ options ] \-defaults"
| 31 |
.SH DESCRIPTION
| 32 |
.I Rtcontrib
| 33 |
computes ray contributions (i.e., color coefficients)
| 34 |
for objects whose modifiers are named in one or more
| 35 |
.I \-m
| 36 |
settings.
| 37 |
These modifiers are usually materials associated with
| 38 |
light sources or sky domes, and must directly modify some geometric
| 39 |
primitives to be considered in the output.
| 40 |
The output of
| 41 |
.I rtcontrib
| 42 |
has many potential uses.
| 43 |
Source contributions can be used as components in linear combination to
| 44 |
reproduce any desired variation, e.g., simulating lighting controls or
| 45 |
changing sky conditions via daylight coefficients.
| 46 |
More generally,
| 47 |
.I rtcontrib
| 48 |
can be used to compute arbitrary input-output relationships in optical
| 49 |
systems, such as luminaires, light pipes, and shading devices.
| 50 |
.PP
| 51 |
.I Rtcontrib
| 52 |
calls
| 53 |
.I rtrace(1)
| 54 |
with the -oTW option to calculate the daughter ray
| 55 |
contributions for each input ray, and the output tallies
| 56 |
are sent to one or more destinations according to the given
| 57 |
.I \-o
| 58 |
specification.
| 59 |
If a destination begins with an exclamation mark ('!'), then
| 60 |
a pipe is opened to a command and data is sent to its standard input.
| 61 |
Otherwise, the destination is treated as a file.
| 62 |
(An existing file of the same name is clobbered.)\0
| 63 |
If an output specification contains a "%s" format, this will be
| 64 |
replaced by the modifier name.
| 65 |
The
| 66 |
.I \-b
| 67 |
option may be used to further define
| 68 |
a "bin number" within each object if finer resolution is needed, and
| 69 |
this will be applied to a "%d" format in the output file
| 70 |
specification if present.
| 71 |
The actual bin number is computed at run time based on ray direction
| 72 |
and surface intersection, as described below.
| 73 |
The most recent
| 74 |
.I \-b
| 75 |
and
| 76 |
.I \-o
| 77 |
options to the left of each
| 78 |
.I \-m
| 79 |
setting affect only that modifier.
| 80 |
(The ordering of other options is unimportant.)\0
| 81 |
.PP
| 82 |
If a
| 83 |
.I \-b
| 84 |
expression is defined for a particular modifier,
| 85 |
the bin number will be evaluated at run time for each
| 86 |
ray contribution from
| 87 |
.I rtrace.
| 88 |
Specifically, each ray's world intersection point will be assigned to
| 89 |
the variables Px, Py, and Pz, and the normalized ray direction
| 90 |
will be assigned to Dx, Dy, and Dz.
| 91 |
These parameters may be combined with definitions given in
| 92 |
.I \-e
| 93 |
arguments and files read using the
| 94 |
.I \-f
| 95 |
option.
| 96 |
The computed bin value will be
| 97 |
rounded to the nearest whole number.
| 98 |
This mechanism allows the user to define precise regions or directions
| 99 |
they wish to accumulate, such as the Tregenza sky discretization,
| 100 |
which would be otherwise impossible to specify
| 101 |
as a set of RADIANCE primitives.
| 102 |
The rules and predefined functions available for these expressions are
| 103 |
described in the
| 104 |
.I rcalc(1)
| 105 |
man page.
| 106 |
Unlike
| 107 |
.I rcalc,
| 108 |
.I rtcontrib
| 109 |
will search the RADIANCE library directories for each file given in a
| 110 |
.I \-f
| 111 |
option.
| 112 |
(No search takes place if a file name begins with a '.', '/' or '~'
| 113 |
character.)\0
| 114 |
.PP
| 115 |
If no
| 116 |
.I \-o
| 117 |
specification is given, results are written on the standard output in order
| 118 |
of modifier (as given on the command line) then bin number.
| 119 |
Concatenated data is also sent to a single destination (i.e., an initial
| 120 |
.I \-o
| 121 |
specification without formatting strings).
| 122 |
If a "%s" format appears but no "%d" in the
| 123 |
.I \-o
| 124 |
specification, then each modifier will have its own output file, with
| 125 |
multiple values per record in the case of a non-zero
| 126 |
.I \-b
| 127 |
definition.
| 128 |
If a "%d" format appears but no "%s", then each bin will get its own
| 129 |
output file, with modifiers output in order in each record.
| 130 |
For text output, each RGB coefficient triple is separated by a tab,
| 131 |
with a newline at the end of each ray record.
| 132 |
For binary output formats, there is no such delimiter to mark
| 133 |
the end of each record.
| 134 |
.PP
| 135 |
Input and output format defaults to plain text, where each ray's
| 136 |
origin and direction (6 real values) are given on input,
| 137 |
and one line is produced per output file per ray.
| 138 |
Alternative data representations may be specified by the
| 139 |
.I \-f[io]
| 140 |
option, which is described in the
| 141 |
.I rtrace
| 142 |
man page along with the associated
| 143 |
.I \-x
| 144 |
and
| 145 |
.I \-y
| 146 |
resolution settings.
| 147 |
In particular, the color ('c') output data representation
| 148 |
together with positive dimensions for
| 149 |
.I \-x
| 150 |
and
| 151 |
.I \-y
| 152 |
will produce an uncompressed RADIANCE picture,
| 153 |
suitable for manipulation with
| 154 |
.I pcomb(1)
| 155 |
and related tools.
| 156 |
.PP
| 157 |
If the
| 158 |
.I \-n
| 159 |
option is specified with a value greater than 1, multiple
| 160 |
.I rtrace
| 161 |
processes will be used to accelerate computation on a shared
| 162 |
memory machine.
| 163 |
Note that there is no benefit to using more processes
| 164 |
than there are local CPUs available to do the work, and the
| 165 |
.I rtcontrib
| 166 |
process itself may use a considerable amount of CPU time.
| 167 |
.PP
| 168 |
Options may be given on the command line and/or read from the
| 169 |
environment and/or read from a file.
| 170 |
A command argument beginning with a dollar sign ('$') is immediately
| 171 |
replaced by the contents of the given environment variable.
| 172 |
A command argument beginning with an at sign ('@') is immediately
| 173 |
replaced by the contents of the given file.
| 174 |
.SH EXAMPLES
| 175 |
To compute the proportional contributions from sources modified
| 176 |
by "light1" vs. "light2" on a set of illuminance values:
| 177 |
.IP "" .2i
| 178 |
rtcontrib -I+ @render.opt -o c_%s.dat -m light1 -m light2 scene.oct < test.dat
| 179 |
.PP
| 180 |
To generate a pair of images corresponding to these two lights'
| 181 |
contributions:
| 182 |
.IP "" .2i
| 183 |
vwrays -ff -x 1024 -y 1024 -vf best.vf |
| 184 |
rtcontrib -ffc `vwrays -d -x 1024 -y 1024 -vf best.vf`
| 185 |
@render.opt -o c_%s.pic -m light1 -m light2 scene.oct
| 186 |
.PP
| 187 |
These images may then be recombined using the desired outputs
| 188 |
of light1 and light2:
| 189 |
.IP "" .2i
| 190 |
pcomb -c 100 90 75 c_light1.pic -c 50 55 57 c_light2.pic > combined.pic
| 191 |
.PP
| 192 |
To compute an array of illuminance contributions according to a Tregenza sky:
| 193 |
.IP "" .2i
| 194 |
rtcontrib -b tbin -o sky.dat -m skyglow -b 0 -o ground.dat -m groundglow
| 195 |
@render.opt -f tregenza.cal scene.oct < test.dat
| 196 |
.SH ENVIRONMENT
| 197 |
RAYPATH path to search for -f files
| 198 |
.SH AUTHOR
| 199 |
Greg Ward
| 200 |
.SH "SEE ALSO"
| 201 |
cnt(1), getinfo(1), pcomb(1), pfilt(1), ra_rgbe(1),
| 202 |
rcalc(1), rpict(1), rtrace(1), vwrays(1), ximage(1)
