1 |
.\" RCSid "$Id: rsplit.1,v 1.6 2019/07/22 18:01:03 greg Exp $" |
2 |
.TH RSPLIT 1 7/8/97 RADIANCE |
3 |
.SH NAME |
4 |
rsplit - splits standard input into multiple output files or streams |
5 |
.SH SYNOPSIS |
6 |
.B rsplit |
7 |
8 |
.B \-tS |
9 |
10 |
.B \-ih |
11 |
12 |
.B \-iH |
13 |
14 |
.B \-oh |
15 |
16 |
.B \-oH |
17 |
18 |
.B "\-x xres \-y yres" |
19 |
20 |
.B \-oaN |
21 |
22 |
.B \-ofN |
23 |
24 |
.B \-odN |
25 |
26 |
.B \-ocN |
27 |
28 |
.B \-oiN |
29 |
30 |
.B \-owN |
31 |
32 |
.B \-obN |
33 |
34 |
.B \-f |
35 |
36 |
.B \-a |
37 |
38 |
.B "\-on M" |
39 |
40 |
output1 [options] output2 .. |
41 |
.SH DESCRIPTION |
42 |
.I Rsplit |
43 |
writes lines or fields from the standard input to one or more output |
44 |
streams. |
45 |
By default, fields are separated by a |
46 |
newline character (i.e., input is distributed by lines), |
47 |
but the terminator can be changed using the |
48 |
.I \-t |
49 |
option. |
50 |
Different terminators may be given for different fields by specifying |
51 |
additional |
52 |
.I \-t |
53 |
options between each output specification. |
54 |
Note that there is no space between this option and its argument. |
55 |
.PP |
56 |
An output is either a file or a command. |
57 |
If an output file exists, it will not be overwritten unless the |
58 |
.I \-f |
59 |
option is given, or it is being appended using the |
60 |
.I \-a |
61 |
option. |
62 |
Commands are given in quotes, and begin with an exclamantion point ('!'). |
63 |
.PP |
64 |
The |
65 |
.I \-oa |
66 |
option may be used to specify ASCII data (the default), or the |
67 |
.I \-of |
68 |
option may be used to indicated binary IEEE 32-bit floats. |
69 |
Similarly, the |
70 |
.I \-od |
71 |
and |
72 |
.I \-oi |
73 |
options may be used to indicate binary 64-bit doubles or integer words, |
74 |
respectively. |
75 |
The |
76 |
.I \-ow |
77 |
option specifies 2-byte short words, and the |
78 |
.I \-ob |
79 |
option specifies bytes. |
80 |
If a number immediately follows any of these options, then it |
81 |
indicates that multiple such values are expected for each record. |
82 |
For example, |
83 |
.I \-of3 |
84 |
indicates three floats per output record for the next named output. |
85 |
In the case of the |
86 |
.I \-oa |
87 |
option, no number writes one line or field per stream, and numbers |
88 |
greater than zero write multiple fields per record to the same stream. |
89 |
If the terminating character is set to something other than newline ('\\n'), |
90 |
a newline is added after each record (in addition to the terminator). |
91 |
For binary output formts, no number implies one value per output. |
92 |
No terminator characters are expected or written for binary outputs. |
93 |
.PP |
94 |
If a |
95 |
.I \-on |
96 |
option is given with a positive integer argument, this will be the |
97 |
maximum number of records that will be written by |
98 |
.I rsplit. |
99 |
.PP |
100 |
A hyphen ('-') by itself can be used to indicate the standard |
101 |
output, and may appear multiple times. |
102 |
Results will be unpredictable if the standard output is specified |
103 |
in this way |
104 |
and any of the command outputs also writes to their standard output. |
105 |
At most, one command may reliably write to its standard output. |
106 |
.PP |
107 |
The |
108 |
.I \-ih |
109 |
option tells |
110 |
.I rsplit |
111 |
to expect a Radiance header on its input. |
112 |
The |
113 |
.I \-iH |
114 |
option says to expect a resolution string for an image or similar. |
115 |
The |
116 |
.I \-x |
117 |
and |
118 |
.I \-y |
119 |
options may alternatively be used to specify the input dimensions. |
120 |
The |
121 |
.I \-oh |
122 |
option tells |
123 |
.I rsplit |
124 |
to produce a Radiance header on the next output stream. |
125 |
The |
126 |
.I \-oH |
127 |
option will write a resolution string. |
128 |
These options toggle the associated mode on and off, |
129 |
so it is possible to have one output include a header or |
130 |
resolution string and not the next by specifying the option(s) again. |
131 |
Neither |
132 |
.I \-oh |
133 |
nor |
134 |
.I \-oH |
135 |
may be used with the append mode ('-a'), which may also be toggled. |
136 |
.SH EXAMPLES |
137 |
To alternate 5 lines between two output files: |
138 |
.IP "" .2i |
139 |
rsplit -oa5 output1.txt output2.txt < input.txt |
140 |
.PP |
141 |
To send the first of each double precision triplet to one file, and the second |
142 |
and third to a second file, stopping after 500 triplets: |
143 |
.IP "" .2i |
144 |
rsplit -on 500 -od firstvals.dbl -od2 followingpairs.dbl < triplets.dbl |
145 |
.PP |
146 |
To convey material, color and distance information from rtrace to |
147 |
separate files: |
148 |
.IP "" .2i |
149 |
vwrays [viewspec] | rtrace [options] -x 1024 -y 768 -h+ -oMlv octree | rsplit -ih -iH -t^I mats.txt -of depth.zbf -oh -oH -of3 '!pvalue -r -df > image.hdr' |
150 |
.SH AUTHOR |
151 |
Greg Ward |
152 |
.SH "SEE ALSO" |
153 |
cnt(1), histo(1), neaten(1), rcalc(1), rcode_depth(1), |
154 |
rcode_ident(1), rcode_norm(1), rlam(1), rtrace(1), |
155 |
split(1), tabfunc(1), total(1) |
