root/radiance/ray/doc/man/man1/rsplit.1
Revision: 1.7
Committed: Thu Aug 22 21:54:46 2019 UTC (5 years, 10 months ago) by greg
Changes since 1.6: +2 -6 lines
Wording improvements
1 .\" RCSid "$Id: rsplit.1,v 1.6 2019/07/22 18:01:03 greg Exp $"
2 .TH RSPLIT 1 7/8/97 RADIANCE
3 .SH NAME
4 rsplit - splits standard input into multiple output files or streams
5 .SH SYNOPSIS
6 .B rsplit
7 [
8 .B \-tS
9 ][
10 .B \-ih
11 ][
12 .B \-iH
13 ][
14 .B \-oh
15 ][
16 .B \-oH
17 ][
18 .B "\-x xres \-y yres"
19 ][
20 .B \-oaN
21 |
22 .B \-ofN
23 |
24 .B \-odN
25 |
26 .B \-ocN
27 |
28 .B \-oiN
29 |
30 .B \-owN
31 |
32 .B \-obN
33 ][
34 .B \-f
35 ][
36 .B \-a
37 ][
38 .B "\-on M"
39 ]
40 output1 [options] output2 ..
41 .SH DESCRIPTION
42 .I Rsplit
43 writes lines or fields from the standard input to one or more output
44 streams.
45 By default, fields are separated by a
46 newline character (i.e., input is distributed by lines),
47 but the terminator can be changed using the
48 .I \-t
49 option.
50 Different terminators may be given for different fields by specifying
51 additional
52 .I \-t
53 options between each output specification.
54 Note that there is no space between this option and its argument.
55 .PP
56 An output is either a file or a command.
57 If an output file exists, it will not be overwritten unless the
58 .I \-f
59 option is given, or it is being appended using the
60 .I \-a
61 option.
62 Commands are given in quotes, and begin with an exclamantion point ('!').
63 .PP
64 The
65 .I \-oa
66 option may be used to specify ASCII data (the default), or the
67 .I \-of
68 option may be used to indicated binary IEEE 32-bit floats.
69 Similarly, the
70 .I \-od
71 and
72 .I \-oi
73 options may be used to indicate binary 64-bit doubles or integer words,
74 respectively.
75 The
76 .I \-ow
77 option specifies 2-byte short words, and the
78 .I \-ob
79 option specifies bytes.
80 If a number immediately follows any of these options, then it
81 indicates that multiple such values are expected for each record.
82 For example,
83 .I \-of3
84 indicates three floats per output record for the next named output.
85 In the case of the
86 .I \-oa
87 option, no number writes one line or field per stream, and numbers
88 greater than zero write multiple fields per record to the same stream.
89 If the terminating character is set to something other than newline ('\\n'),
90 a newline is added after each record (in addition to the terminator).
91 For binary output formts, no number implies one value per output.
92 No terminator characters are expected or written for binary outputs.
93 .PP
94 If a
95 .I \-on
96 option is given with a positive integer argument, this will be the
97 maximum number of records that will be written by
98 .I rsplit.
99 .PP
100 A hyphen ('-') by itself can be used to indicate the standard
101 output, and may appear multiple times.
102 Results will be unpredictable if the standard output is specified
103 in this way
104 and any of the command outputs also writes to their standard output.
105 At most, one command may reliably write to its standard output.
106 .PP
107 The
108 .I \-ih
109 option tells
110 .I rsplit
111 to expect a Radiance header on its input.
112 The
113 .I \-iH
114 option says to expect a resolution string for an image or similar.
115 The
116 .I \-x
117 and
118 .I \-y
119 options may alternatively be used to specify the input dimensions.
120 The
121 .I \-oh
122 option tells
123 .I rsplit
124 to produce a Radiance header on the next output stream.
125 The
126 .I \-oH
127 option will write a resolution string.
128 These options toggle the associated mode on and off,
129 so it is possible to have one output include a header or
130 resolution string and not the next by specifying the option(s) again.
131 Neither
132 .I \-oh
133 nor
134 .I \-oH
135 may be used with the append mode ('-a'), which may also be toggled.
136 .SH EXAMPLES
137 To alternate 5 lines between two output files:
138 .IP "" .2i
139 rsplit -oa5 output1.txt output2.txt < input.txt
140 .PP
141 To send the first of each double precision triplet to one file, and the second
142 and third to a second file, stopping after 500 triplets:
143 .IP "" .2i
144 rsplit -on 500 -od firstvals.dbl -od2 followingpairs.dbl < triplets.dbl
145 .PP
146 To convey material, color and distance information from rtrace to
147 separate files:
148 .IP "" .2i
149 vwrays [viewspec] | rtrace [options] -x 1024 -y 768 -h+ -oMlv octree | rsplit -ih -iH -t^I mats.txt -of depth.zbf -oh -oH -of3 '!pvalue -r -df > image.hdr'
150 .SH AUTHOR
151 Greg Ward
152 .SH "SEE ALSO"
153 cnt(1), histo(1), neaten(1), rcalc(1), rcode_depth(1),
154 rcode_ident(1), rcode_norm(1), rlam(1), rtrace(1),
155 split(1), tabfunc(1), total(1)
