root/radiance/ray/doc/man/man1/rsplit.1
Sun Apr 5 15:07:09 2020 UTC (5 years, 2 months ago) by greg
Changes since 1.10: +16 -15 lines
Diff to previous 1.10 , to selected 1.8
Added check for duplicate output file(s)
Sun Apr 5 02:25:22 2020 UTC (5 years, 2 months ago) by greg
Changes since 1.9: +5 -3 lines
Diff to previous 1.9 , to selected 1.8
Fixed issue with duplicate, incorrect headers if '-' used more than once
Sat Apr 4 16:23:00 2020 UTC (5 years, 2 months ago) by greg
Changes since 1.8: +4 -1 lines
Diff to previous 1.8
Added '.' for discarding output
Revision 1.8 - (view) (download) (annotate) - [selected]
Thu Nov 7 23:13:12 2019 UTC (5 years, 7 months ago) by greg
Changes since 1.7: +7 -2 lines
Diff to previous 1.7
Made it so a space separator matches all white space
Thu Aug 22 21:54:46 2019 UTC (5 years, 10 months ago) by greg
Changes since 1.6: +2 -6 lines
Diff to previous 1.6 , to selected 1.8
Wording improvements
Mon Jul 22 18:01:03 2019 UTC (5 years, 11 months ago) by greg
Diff to previous 1.5 , to selected 1.8
Made option behavior more consistent
Sat Jul 20 00:57:43 2019 UTC (5 years, 11 months ago) by greg
Diff to previous 1.4 , to selected 1.8
Added mention of rsplit(1)
Tue Jul 16 15:59:49 2019 UTC (5 years, 11 months ago) by greg
Changes since 1.3: +2 -1 lines
Diff to previous 1.3 , to selected 1.8
Made it so -t option sets newline if no character follows
Fri Jul 5 15:04:20 2019 UTC (5 years, 11 months ago) by greg
Changes since 1.2: +11 -7 lines
Diff to previous 1.2 , to selected 1.8
Improved error reporting and added newline after ASCII records
Fri Jul 5 00:42:56 2019 UTC (5 years, 11 months ago) by greg
Diff to previous 1.1 , to selected 1.8
Fixes
Fri Jul 5 00:20:57 2019 UTC (5 years, 11 months ago) by greg
Diff to selected 1.8
