root/radiance/ray/doc/man/man1/rsplit.1
Revision: 1.2
Committed: Fri Jul 5 00:42:56 2019 UTC (5 years, 11 months ago) by greg
Fixes
1 .\" RCSid "$Id: rsplit.1,v 1.1 2019/07/05 00:20:57 greg Exp $"
2 .TH RSPLIT 1 7/8/97 RADIANCE
3 .SH NAME
4 rsplit - splits standard input into multiple output files or streams
5 .SH SYNOPSIS
6 .B rsplit
7 [
8 .B \-tS
9 ][
10 .B \-ih
11 ][
12 .B \-iH
13 ][
14 .B \-oh
15 ][
16 .B \-oH
17 ][
18 .B \-oaN
19 |
20 .B \-ofN
21 |
22 .B \-odN
23 |
24 .B \-ocN
25 |
26 .B \-oiN
27 |
28 .B \-owN
29 |
30 .B \-obN
31 ][
32 .B \-f
33 ][
34 .B \-a
35 ][
36 .B "\-on M"
37 ]
38 output1 [options] output2 ..
39 .SH DESCRIPTION
40 .I Rsplit
41 writes lines or fields from the standard input to one or more output
42 streams.
43 By default, fields are separated by a
44 newline character, but the terminator can be changed using the
45 .I \-t
46 option.
47 Different separators may be given for different fields by specifying
48 additional
49 .I \-t
50 options in between each output.
51 Note that there is no space between this option and its argument.
52 .PP
53 An output is either a file or a command.
54 If an output file exists, it will not be overwritten unless the
55 .I \-f
56 option is given, or it is being appended using the
57 .I \-a
58 option.
59 Commands are given in quotes, and begin with an exclamantion point ('!').
60 .PP
61 The
62 .I \-oa
63 option may be used to specify ASCII data (the default), or the
64 .I \-of
65 option may be used to indicated binary IEEE 32-bit floats.
66 Similarly, the
67 .I \-od
68 and
69 .I \-oi
70 options may be used to indicate binary 64-bit doubles or integer words,
71 respectively.
72 The
73 .I \-ow
74 option specifies 2-byte short words, and the
75 .I \-ob
76 option specifies bytes.
77 If a number immediately follows any of these options, then it
78 indicates that multiple such values are expected for each record.
79 For example,
80 .I \-of3
81 indicates three floats per output record for the next named output.
82 In the case of the
83 .I \-oa
84 option, no number writes one line or field per stream, and numbers
85 greater than zero write multiple fields at a time to the same stream.
86 For binary output formts, no number implies one value per output.
87 The default tab separator
88 is set to the empty string for binary output streams.
89 .PP
90 These options may be interspersed with output specifications,
91 indicating different data to draw from the different files.
92 .PP
93 If a
94 .I \-on
95 option is given with a positive integer argument, this will be the
96 maximum number of records that will be written by
97 .I rsplit.
98 .PP
99 A hyphen ('-') by itself can be used to indicate the standard
100 output, and may appear multiple times.
101 Results will be unpredictable if the standard output is specified
102 in this way
103 and any of the command outputs also writes to their standard output.
104 At most, one command may reliably write to its standard output.
105 .PP
106 The
107 .I \-ih
108 option tells
109 .I rsplit
110 to expect a Radiance header on its input.
111 The
112 .I \-iH
113 option says to expect a resolution string for an image or similar.
114 The
115 .I \-x
116 and
117 .I \-y
118 options may alternatively be used to specify the input dimensions.
119 The
120 .I \-oh
121 option tells
122 .I rsplit
123 to produce a Radiance header on the next output stream.
124 The
125 .I \-oH
126 option will write a resolution string.
127 These options toggle the associated mode on and off,
128 so it is possible to have one output include a header or
129 resolution string and not the next by specifying the option(s) again.
130 Neither
131 .I \-oh
132 nor
133 .I \-oH
134 may be used with the append mode ('-a').
135 .SH EXAMPLE
136 To alternate 5 lines between two output files:
137 .IP "" .2i
138 rsplit -oa5 output1.txt output2.txt < input.txt
139 .PP
140 To send the first of each double precision triplet to one file, and the second
141 and third to a second file, stopping after 500 triplets:
142 .IP "" .2i
143 rsplit -on 500 -od firstvals.dbl -od2 followingpairs.dbl < triplets.dbl
144 .PP
145 To convey material, color and distance information from rtrace to
146 separate files:
147 .IP "" .2i
148 vwrays [viewspec] | rtrace [options] -x 1024 -y 768 -h+ -oMlv octree | rsplit -ih -iH -t^I mats.txt -of depth.zbf -oh -oH -of3 '!pvalue -r -df > image.hdr'
149 .SH AUTHOR
150 Greg Ward
151 .SH "SEE ALSO"
152 cnt(1), histo(1), neaten(1), rcalc(1), rlam(1), rtrace(1),
153 split(1), tabfunc(1), total(1)
