| 1 |
.\" RCSid "$Id: rsplit.1,v 1.5 2019/07/20 00:57:43 greg Exp $"
| 2 |
.TH RSPLIT 1 7/8/97 RADIANCE
| 3 |
.SH NAME
| 4 |
rsplit - splits standard input into multiple output files or streams
| 5 |
.SH SYNOPSIS
| 6 |
.B rsplit
| 7 |
| 8 |
.B \-tS
| 9 |
| 10 |
.B \-ih
| 11 |
| 12 |
.B \-iH
| 13 |
| 14 |
.B \-oh
| 15 |
| 16 |
.B \-oH
| 17 |
| 18 |
.B "\-x xres \-y yres"
| 19 |
| 20 |
.B \-oaN
| 21 |
| 22 |
.B \-ofN
| 23 |
| 24 |
.B \-odN
| 25 |
| 26 |
.B \-ocN
| 27 |
| 28 |
.B \-oiN
| 29 |
| 30 |
.B \-owN
| 31 |
| 32 |
.B \-obN
| 33 |
| 34 |
.B \-f
| 35 |
| 36 |
.B \-a
| 37 |
| 38 |
.B "\-on M"
| 39 |
| 40 |
output1 [options] output2 ..
| 41 |
.SH DESCRIPTION
| 42 |
.I Rsplit
| 43 |
writes lines or fields from the standard input to one or more output
| 44 |
streams.
| 45 |
By default, fields are separated by a
| 46 |
newline character (i.e., input is distributed by lines),
| 47 |
but the terminator can be changed using the
| 48 |
.I \-t
| 49 |
option.
| 50 |
Different terminators may be given for different fields by specifying
| 51 |
additional
| 52 |
.I \-t
| 53 |
options between each output specification.
| 54 |
Note that there is no space between this option and its argument.
| 55 |
If no character is specified, the default (newline) is used.
| 56 |
.PP
| 57 |
An output is either a file or a command.
| 58 |
If an output file exists, it will not be overwritten unless the
| 59 |
.I \-f
| 60 |
option is given, or it is being appended using the
| 61 |
.I \-a
| 62 |
option.
| 63 |
Commands are given in quotes, and begin with an exclamantion point ('!').
| 64 |
.PP
| 65 |
The
| 66 |
.I \-oa
| 67 |
option may be used to specify ASCII data (the default), or the
| 68 |
.I \-of
| 69 |
option may be used to indicated binary IEEE 32-bit floats.
| 70 |
Similarly, the
| 71 |
.I \-od
| 72 |
and
| 73 |
.I \-oi
| 74 |
options may be used to indicate binary 64-bit doubles or integer words,
| 75 |
respectively.
| 76 |
The
| 77 |
.I \-ow
| 78 |
option specifies 2-byte short words, and the
| 79 |
.I \-ob
| 80 |
option specifies bytes.
| 81 |
If a number immediately follows any of these options, then it
| 82 |
indicates that multiple such values are expected for each record.
| 83 |
For example,
| 84 |
.I \-of3
| 85 |
indicates three floats per output record for the next named output.
| 86 |
In the case of the
| 87 |
.I \-oa
| 88 |
option, no number writes one line or field per stream, and numbers
| 89 |
greater than zero write multiple fields per record to the same stream.
| 90 |
If the terminating character is set to something other than newline ('\\n'),
| 91 |
a newline is added after each record (in addition to the terminator).
| 92 |
For binary output formts, no number implies one value per output.
| 93 |
The terminator is not used for binary output streams.
| 94 |
.PP
| 95 |
These options may be interspersed with output specifications,
| 96 |
indicating different data to draw from the different files.
| 97 |
.PP
| 98 |
If a
| 99 |
.I \-on
| 100 |
option is given with a positive integer argument, this will be the
| 101 |
maximum number of records that will be written by
| 102 |
.I rsplit.
| 103 |
.PP
| 104 |
A hyphen ('-') by itself can be used to indicate the standard
| 105 |
output, and may appear multiple times.
| 106 |
Results will be unpredictable if the standard output is specified
| 107 |
in this way
| 108 |
and any of the command outputs also writes to their standard output.
| 109 |
At most, one command may reliably write to its standard output.
| 110 |
.PP
| 111 |
The
| 112 |
.I \-ih
| 113 |
option tells
| 114 |
.I rsplit
| 115 |
to expect a Radiance header on its input.
| 116 |
The
| 117 |
.I \-iH
| 118 |
option says to expect a resolution string for an image or similar.
| 119 |
The
| 120 |
.I \-x
| 121 |
and
| 122 |
.I \-y
| 123 |
options may alternatively be used to specify the input dimensions.
| 124 |
The
| 125 |
.I \-oh
| 126 |
option tells
| 127 |
.I rsplit
| 128 |
to produce a Radiance header on the next output stream.
| 129 |
The
| 130 |
.I \-oH
| 131 |
option will write a resolution string.
| 132 |
These options toggle the associated mode on and off,
| 133 |
so it is possible to have one output include a header or
| 134 |
resolution string and not the next by specifying the option(s) again.
| 135 |
Neither
| 136 |
.I \-oh
| 137 |
nor
| 138 |
.I \-oH
| 139 |
may be used with the append mode ('-a'), which may also be toggled.
| 140 |
.SH EXAMPLES
| 141 |
To alternate 5 lines between two output files:
| 142 |
.IP "" .2i
| 143 |
rsplit -oa5 output1.txt output2.txt < input.txt
| 144 |
.PP
| 145 |
To send the first of each double precision triplet to one file, and the second
| 146 |
and third to a second file, stopping after 500 triplets:
| 147 |
.IP "" .2i
| 148 |
rsplit -on 500 -od firstvals.dbl -od2 followingpairs.dbl < triplets.dbl
| 149 |
.PP
| 150 |
To convey material, color and distance information from rtrace to
| 151 |
separate files:
| 152 |
.IP "" .2i
| 153 |
vwrays [viewspec] | rtrace [options] -x 1024 -y 768 -h+ -oMlv octree | rsplit -ih -iH -t^I mats.txt -of depth.zbf -oh -oH -of3 '!pvalue -r -df > image.hdr'
| 154 |
.SH AUTHOR
| 155 |
Greg Ward
| 156 |
.SH "SEE ALSO"
| 157 |
cnt(1), histo(1), neaten(1), rcalc(1), rcode_depth(1),
| 158 |
rcode_ident(1), rcode_norm(1), rlam(1), rtrace(1),
| 159 |
split(1), tabfunc(1), total(1)
