1 |
.\" RCSid "$Id: rsensor.1,v 1.1 2008/04/15 00:14:22 greg Exp $" |
2 |
.TH RSENSOR 1 4/11/2008 RADIANCE |
3 |
.SH NAME |
4 |
rsensor - compute sensor signal from a RADIANCE scene |
5 |
.SH SYNOPSIS |
6 |
.B rsensor |
7 |
8 |
.B -n nprocs |
9 |
10 |
.B -h |
11 |
12 |
.B render options |
13 |
14 |
15 |
.B $EVAR |
16 |
17 |
18 |
.B @file |
19 |
20 |
21 |
22 |
.B -rd nrays |
23 |
24 |
.B -dn nsrc |
25 |
26 |
.B sensor_view |
27 |
28 |
.B sensor_file .. |
29 |
30 |
.B octree |
31 |
.br |
32 |
.B "rsensor [ options ] \-defaults" |
33 |
.SH DESCRIPTION |
34 |
.I Rsensor |
35 |
traces rays outward from one or more specified illumination |
36 |
sensors into the RADIANCE scene given by |
37 |
.I octree, |
38 |
sending the computed sensor value to the standard output. |
39 |
(The octree may be given as the output of a command enclosed in quotes |
40 |
and preceded by a `!'.)\0 |
41 |
In the second form, the default values |
42 |
for the options (modified by those options present) |
43 |
are printed with a brief explanation. |
44 |
.PP |
45 |
Options may be given on the command line and/or read from the |
46 |
environment and/or read from a file. |
47 |
A command argument beginning with a dollar sign ('$') is immediately |
48 |
replaced by the contents of the given environment variable. |
49 |
A command argument beginning with an at sign ('@') is immediately |
50 |
replaced by the contents of the given file. |
51 |
.PP |
52 |
The sensor files themselves will be searched for in the path |
53 |
locations specified by the |
54 |
.I RAYPATH |
55 |
environment variable, similar to other types of Radiance |
56 |
auxiliary files. |
57 |
If the sensor file path begins with '/', '.' or '~', no search |
58 |
will take place. |
59 |
Before each sensor file, a separate view may be specified. |
60 |
In this case, the view origin and direction will correspond to |
61 |
the position and orientation of the sensor, and the view up |
62 |
vector will determine the zero azimuthal direction of the sensor. |
63 |
The fore clipping distance may be used as well, but other view |
64 |
options will be ignored. |
65 |
(See |
66 |
.I rpict\.1 |
67 |
for details on how to specify a view.)\0 |
68 |
The actual data contained in the sensor file corresponds to the |
69 |
.I SPOT |
70 |
tab-separated matrix specification, where the |
71 |
column header has "degrees" in the leftmost column, followed |
72 |
by evenly-spaced azimuthal angles. |
73 |
Each row begins with the polar angle, and is followed by the |
74 |
relative sensitivity values for each direction. |
75 |
A low-resolution example of a sensor file is given below: |
76 |
.sp |
77 |
.nf |
78 |
degrees 0 90 180 270 |
79 |
0 .02 .04 .02 .04 |
80 |
45 .01 .02 .01 .02 |
81 |
90 .001 .002 .001 .002 |
82 |
.fi |
83 |
.sp |
84 |
As well as different views, the number of samples may be changed between |
85 |
sensors, where the |
86 |
.I \-rd |
87 |
option controls the number of ray samples sent at random, and the |
88 |
.I \-dn |
89 |
option controls the number of rays sent to light sources per sensor. |
90 |
.PP |
91 |
The |
92 |
.I \-h |
93 |
option toggles header output, which defaults to "on." |
94 |
The |
95 |
.I \-n |
96 |
option may be used to specify multiple calculation processes on |
97 |
systems with more than one CPU. |
98 |
For additional options, consult the |
99 |
.I rtrace\.1 |
100 |
man page. |
101 |
The final |
102 |
.I octree |
103 |
argument must be given, as the octree cannot be read from the |
104 |
standard input. |
105 |
.SH EXAMPLES |
106 |
To compute values for the same sensor with two different positions: |
107 |
.IP "" .2i |
108 |
rsensor -ab 2 -vf posA.vf mysens.dat -vf posB.vf mysens.dat scene.oct |
109 |
.SH ENVIRONMENT |
110 |
RAYPATH the directories to check for auxiliary files. |
111 |
.SH AUTHOR |
112 |
Greg Ward for Architectural Energy Corporation |
113 |
.SH "SEE ALSO" |
114 |
oconv(1), rpict(1), rtcontrib(1), rtrace(1) |
