root/radiance/ray/doc/man/man1/rsensor.1
Revision: 1.2
Committed: Tue Apr 22 02:08:02 2008 UTC (17 years, 1 month ago) by greg
Changes since 1.1: +9 -2 lines
Added a few details
1 .\" RCSid "$Id: rsensor.1,v 1.1 2008/04/15 00:14:22 greg Exp $"
2 .TH RSENSOR 1 4/11/2008 RADIANCE
3 .SH NAME
4 rsensor - compute sensor signal from a RADIANCE scene
5 .SH SYNOPSIS
6 .B rsensor
7 [
8 .B -n nprocs
9 ][
10 .B -h
11 ][
12 .B render options
13 ]
14 [
15 .B $EVAR
16 ]
17 [
18 .B @file
19 ]
20 {
21 [
22 .B -rd nrays
23 ][
24 .B -dn nsrc
25 ][
26 .B sensor_view
27 ]
28 .B sensor_file ..
29 }
30 .B octree
31 .br
32 .B "rsensor [ options ] \-defaults"
33 .SH DESCRIPTION
34 .I Rsensor
35 traces rays outward from one or more specified illumination
36 sensors into the RADIANCE scene given by
37 .I octree,
38 sending the computed sensor value to the standard output.
39 (The octree may be given as the output of a command enclosed in quotes
40 and preceded by a `!'.)\0
41 In the second form, the default values
42 for the options (modified by those options present)
43 are printed with a brief explanation.
44 .PP
45 Options may be given on the command line and/or read from the
46 environment and/or read from a file.
47 A command argument beginning with a dollar sign ('$') is immediately
48 replaced by the contents of the given environment variable.
49 A command argument beginning with an at sign ('@') is immediately
50 replaced by the contents of the given file.
51 .PP
52 The sensor files themselves will be searched for in the path
53 locations specified by the
54 .I RAYPATH
55 environment variable, similar to other types of Radiance
56 auxiliary files.
57 If the sensor file path begins with '/', '.' or '~', no search
58 will take place.
59 Before each sensor file, a separate view may be specified.
60 In this case, the view origin and direction will correspond to
61 the position and orientation of the sensor, and the view up
62 vector will determine the zero azimuthal direction of the sensor.
63 The fore clipping distance may be used as well, but other view
64 options will be ignored.
65 (See
66 .I rpict\.1
67 for details on how to specify a view.)\0
68 The actual data contained in the sensor file corresponds to the
69 .I SPOT
70 tab-separated matrix specification, where the
71 column header has "degrees" in the leftmost column, followed
72 by evenly-spaced azimuthal angles.
73 Each row begins with the polar angle, and is followed by the
74 relative sensitivity values for each direction.
75 A low-resolution example of a sensor file is given below:
76 .sp
77 .nf
78 degrees 0 90 180 270
79 0 .02 .04 .02 .04
80 45 .01 .02 .01 .02
81 90 .001 .002 .001 .002
82 .fi
83 .sp
84 As well as different views, the number of samples may be changed between
85 sensors, where the
86 .I \-rd
87 option controls the number of ray samples sent at random, and the
88 .I \-dn
89 option controls the number of rays sent to light sources per sensor.
90 .PP
91 The
92 .I \-h
93 option toggles header output, which defaults to "on."
94 The
95 .I \-n
96 option may be used to specify multiple calculation processes on
97 systems with more than one CPU.
98 For additional options, consult the
99 .I rtrace\.1
100 man page.
101 The final
102 .I octree
103 argument must be given, as the octree cannot be read from the
104 standard input.
105 .SH EXAMPLES
106 To compute values for the same sensor with two different positions:
107 .IP "" .2i
108 rsensor -ab 2 -vf posA.vf mysens.dat -vf posB.vf mysens.dat scene.oct
109 .SH ENVIRONMENT
110 RAYPATH the directories to check for auxiliary files.
111 .SH AUTHOR
112 Greg Ward for Architectural Energy Corporation
113 .SH "SEE ALSO"
114 oconv(1), rpict(1), rtcontrib(1), rtrace(1)
