root/Development/ray/doc/man/man1/rsensor.1
Revision: 1.4
Committed: Sun Sep 26 15:41:46 2010 UTC (15 years, 2 months ago) by greg
Changes since 1.3: +26 -2 lines
Added ability to output sample rays rather than compute results
1 .\" RCSid "$Id: rsensor.1,v 1.3 2008/12/13 00:44:05 greg Exp $"
2 .TH RSENSOR 1 4/11/2008 RADIANCE
3 .SH NAME
4 rsensor - compute sensor signal from a RADIANCE scene
5 .SH SYNOPSIS
6 .B rsensor
7 [
8 .B -n nprocs
9 ][
10 .B -h
11 ][
12 .B render options
13 ]
14 [
15 .B $EVAR
16 ]
17 [
18 .B @file
19 ]
20 {
21 [
22 .B -rd nrays
23 ][
24 .B -dn nsrc
25 ][
26 .B sensor_view
27 ]
28 .B sensor_file ..
29 }
30 .B octree
31 .br
32 .B rsensor
33 [
34 .B -h
35 ]
36 {
37 [
38 .B -rd nrays
39 ][
40 .B sensor_view
41 ]
42 .B sensor_file ..
43 }
44 .B "."
45 .br
46 .B "rsensor [ options ] \-defaults"
47 .SH DESCRIPTION
48 .I Rsensor
49 traces rays outward from one or more specified illumination
50 sensors into the RADIANCE scene given by
51 .I octree,
52 sending the computed sensor value to the standard output.
53 (The octree may be given as the output of a command enclosed in quotes
54 and preceded by a `!'.)\0
55 In the second form, a single period ('.') is given in place of an
56 octree, and the origin and directions of the specified
57 number of rays will be printed on the standard output.
58 If these rays are later traced and added together, the results
59 will sum to a signal proportional to the given sensor distribution.
60 In the third form, the default values
61 for the options (modified by those options present)
62 are printed with a brief explanation.
63 .PP
64 Options may be given on the command line and/or read from the
65 environment and/or read from a file.
66 A command argument beginning with a dollar sign ('$') is immediately
67 replaced by the contents of the given environment variable.
68 A command argument beginning with an at sign ('@') is immediately
69 replaced by the contents of the given file.
70 .PP
71 The sensor files themselves will be searched for in the path
72 locations specified by the
73 .I RAYPATH
74 environment variable, similar to other types of Radiance
75 auxiliary files.
76 If the sensor file path begins with '/', '.' or '~', no search
77 will take place.
78 Before each sensor file, a separate view may be specified.
79 In this case, the view origin and direction will correspond to
80 the position and orientation of the sensor, and the view up
81 vector will determine the zero azimuthal direction of the sensor.
82 The fore clipping distance may be used as well, but other view
83 options will be ignored.
84 (See
85 .I rpict(1)
86 for details on how to specify a view.)\0
87 The actual data contained in the sensor file corresponds to the
88 .I SPOT
89 tab-separated matrix specification, where the
90 column header has "degrees" in the leftmost column, followed
91 by evenly-spaced azimuthal angles.
92 Each row begins with the polar angle, and is followed by the
93 relative sensitivity values for each direction.
94 A low-resolution example of a sensor file is given below:
95 .sp
96 .nf
97 degrees 0 90 180 270
98 0 .02 .04 .02 .04
99 45 .01 .02 .01 .02
100 90 .001 .002 .001 .002
101 .fi
102 .sp
103 As well as different views, the number of samples may be changed between
104 sensors, where the
105 .I \-rd
106 option controls the number of ray samples sent at random, and the
107 .I \-dn
108 option controls the number of rays sent to each light source per sensor.
109 .PP
110 The
111 .I \-h
112 option toggles header output, which defaults to "on."
113 The
114 .I \-n
115 option may be used to specify multiple calculation processes on
116 systems with more than one CPU.
117 For additional options, consult the
118 .I rtrace(1)
119 man page.
120 The final
121 .I octree
122 argument must be given, as the octree cannot be read from the
123 standard input.
124 .SH EXAMPLES
125 To compute values for the same sensor with two different positions:
126 .IP "" .2i
127 rsensor -ab 2 -vf posA.vf mysens.dat -vf posB.vf mysens.dat scene.oct
128 .PP
129 To generate a set of rays corresponding to a given sensor and compute
130 the resulting signal with rtrace:
131 .IP "" .2i
132 rsensor -h -vf posC.vf mysens.dat . | rtrace -h scene.oct | total -m
133 .SH ENVIRONMENT
134 RAYPATH the directories to check for auxiliary files.
135 .SH AUTHOR
136 Greg Ward for Architectural Energy Corporation
137 .SH "SEE ALSO"
138 oconv(1), rpict(1), rtcontrib(1), rtrace(1)
