| 1 |
.\" RCSid "$Id: rsensor.1,v 1.1 2008/04/15 00:14:22 greg Exp $"
| 2 |
.TH RSENSOR 1 4/11/2008 RADIANCE
| 3 |
.SH NAME
| 4 |
rsensor - compute sensor signal from a RADIANCE scene
| 5 |
.SH SYNOPSIS
| 6 |
.B rsensor
| 7 |
| 8 |
.B -n nprocs
| 9 |
| 10 |
.B -h
| 11 |
| 12 |
.B render options
| 13 |
| 14 |
| 15 |
.B $EVAR
| 16 |
| 17 |
| 18 |
.B @file
| 19 |
| 20 |
| 21 |
| 22 |
.B -rd nrays
| 23 |
| 24 |
.B -dn nsrc
| 25 |
| 26 |
.B sensor_view
| 27 |
| 28 |
.B sensor_file ..
| 29 |
| 30 |
.B octree
| 31 |
.br
| 32 |
.B "rsensor [ options ] \-defaults"
| 33 |
.SH DESCRIPTION
| 34 |
.I Rsensor
| 35 |
traces rays outward from one or more specified illumination
| 36 |
sensors into the RADIANCE scene given by
| 37 |
.I octree,
| 38 |
sending the computed sensor value to the standard output.
| 39 |
(The octree may be given as the output of a command enclosed in quotes
| 40 |
and preceded by a `!'.)\0
| 41 |
In the second form, the default values
| 42 |
for the options (modified by those options present)
| 43 |
are printed with a brief explanation.
| 44 |
.PP
| 45 |
Options may be given on the command line and/or read from the
| 46 |
environment and/or read from a file.
| 47 |
A command argument beginning with a dollar sign ('$') is immediately
| 48 |
replaced by the contents of the given environment variable.
| 49 |
A command argument beginning with an at sign ('@') is immediately
| 50 |
replaced by the contents of the given file.
| 51 |
.PP
| 52 |
The sensor files themselves will be searched for in the path
| 53 |
locations specified by the
| 54 |
.I RAYPATH
| 55 |
environment variable, similar to other types of Radiance
| 56 |
auxiliary files.
| 57 |
If the sensor file path begins with '/', '.' or '~', no search
| 58 |
will take place.
| 59 |
Before each sensor file, a separate view may be specified.
| 60 |
In this case, the view origin and direction will correspond to
| 61 |
the position and orientation of the sensor, and the view up
| 62 |
vector will determine the zero azimuthal direction of the sensor.
| 63 |
The fore clipping distance may be used as well, but other view
| 64 |
options will be ignored.
| 65 |
(See
| 66 |
.I rpict\.1
| 67 |
for details on how to specify a view.)\0
| 68 |
The actual data contained in the sensor file corresponds to the
| 69 |
.I SPOT
| 70 |
tab-separated matrix specification, where the
| 71 |
column header has "degrees" in the leftmost column, followed
| 72 |
by evenly-spaced azimuthal angles.
| 73 |
Each row begins with the polar angle, and is followed by the
| 74 |
relative sensitivity values for each direction.
| 75 |
A low-resolution example of a sensor file is given below:
| 76 |
.sp
| 77 |
.nf
| 78 |
degrees 0 90 180 270
| 79 |
0 .02 .04 .02 .04
| 80 |
45 .01 .02 .01 .02
| 81 |
90 .001 .002 .001 .002
| 82 |
.fi
| 83 |
.sp
| 84 |
As well as different views, the number of samples may be changed between
| 85 |
sensors, where the
| 86 |
.I \-rd
| 87 |
option controls the number of ray samples sent at random, and the
| 88 |
.I \-dn
| 89 |
option controls the number of rays sent to light sources per sensor.
| 90 |
.PP
| 91 |
The
| 92 |
.I \-h
| 93 |
option toggles header output, which defaults to "on."
| 94 |
The
| 95 |
.I \-n
| 96 |
option may be used to specify multiple calculation processes on
| 97 |
systems with more than one CPU.
| 98 |
For additional options, consult the
| 99 |
.I rtrace\.1
| 100 |
man page.
| 101 |
The final
| 102 |
.I octree
| 103 |
argument must be given, as the octree cannot be read from the
| 104 |
standard input.
| 105 |
.SH EXAMPLES
| 106 |
To compute values for the same sensor with two different positions:
| 107 |
.IP "" .2i
| 108 |
rsensor -ab 2 -vf posA.vf mysens.dat -vf posB.vf mysens.dat scene.oct
| 109 |
.SH ENVIRONMENT
| 110 |
RAYPATH the directories to check for auxiliary files.
| 111 |
.SH AUTHOR
| 112 |
Greg Ward for Architectural Energy Corporation
| 113 |
.SH "SEE ALSO"
| 114 |
oconv(1), rpict(1), rtcontrib(1), rtrace(1)
