root/radiance/ray/doc/man/man1/rsensor.1
Revision: 1.6
Committed: Tue Jun 9 21:34:14 2015 UTC (9 years, 10 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R0, rad5R1, rad5R3, HEAD
Changes since 1.5: +7 -1 lines
Added checks for extra and missing angles and documented behavior
1 .\" RCSid "$Id: rsensor.1,v 1.5 2012/06/14 22:42:21 greg Exp $"
2 .TH RSENSOR 1 4/11/2008 RADIANCE
3 .SH NAME
4 rsensor - compute sensor signal from a RADIANCE scene
5 .SH SYNOPSIS
6 .B rsensor
7 [
8 .B -n nprocs
9 ][
10 .B -h
11 ][
12 .B render options
13 ]
14 [
15 .B $EVAR
16 ]
17 [
18 .B @file
19 ]
20 {
21 [
22 .B -rd nrays
23 ][
24 .B -dn nsrc
25 ][
26 .B sensor_view
27 ]
28 .B sensor_file ..
29 }
30 .B octree
31 .br
32 .B rsensor
33 [
34 .B -h
35 ]
36 {
37 [
38 .B -rd nrays
39 ][
40 .B sensor_view
41 ]
42 .B sensor_file ..
43 }
44 .B "."
45 .br
46 .B "rsensor [ options ] \-defaults"
47 .SH DESCRIPTION
48 .I Rsensor
49 traces rays outward from one or more specified illumination
50 sensors into the RADIANCE scene given by
51 .I octree,
52 sending the computed sensor value to the standard output.
53 (The octree may be given as the output of a command enclosed in quotes
54 and preceded by a `!'.)\0
55 In the second form, a single period ('.') is given in place of an
56 octree, and the origin and directions of the specified
57 number of rays will be printed on the standard output.
58 If these rays are later traced and added together, the results
59 will sum to a signal proportional to the given sensor distribution.
60 In the third form, the default values
61 for the options (modified by those options present)
62 are printed with a brief explanation.
63 .PP
64 Options may be given on the command line and/or read from the
65 environment and/or read from a file.
66 A command argument beginning with a dollar sign ('$') is immediately
67 replaced by the contents of the given environment variable.
68 A command argument beginning with an at sign ('@') is immediately
69 replaced by the contents of the given file.
70 .PP
71 The sensor files themselves will be searched for in the path
72 locations specified by the
73 .I RAYPATH
74 environment variable, similar to other types of Radiance
75 auxiliary files.
76 If the sensor file path begins with '/', '.' or '~', no search
77 will take place.
78 Before each sensor file, a separate view may be specified.
79 In this case, the view origin and direction will correspond to
80 the position and orientation of the sensor, and the view up
81 vector will determine the zero azimuthal direction of the sensor.
82 The fore clipping distance may be used as well, but other view
83 options will be ignored.
84 (See
85 .I rpict(1)
86 for details on how to specify a view.)\0
87 The actual data contained in the sensor file corresponds to the
88 .I SPOT
89 tab-separated matrix specification, where the
90 column header has "degrees" in the leftmost column, followed
91 by evenly-spaced azimuthal angles.
92 Azimuth angles must start at 0 and proceed to at least 270 degrees.
93 No symmetry is applied to missing values.
94 Each row begins with the polar angle, and is followed by the
95 relative sensitivity values for each direction.
96 Polar angles must start from 0 and continue to the edge of
97 the sensor's view.
98 Polar angles above the last row listed are assumed to have
99 zero sensitivity.
100 A low-resolution example of a sensor file is given below:
101 .sp
102 .nf
103 degrees 0 90 180 270
104 0 .02 .04 .02 .04
105 45 .01 .02 .01 .02
106 90 .001 .002 .001 .002
107 .fi
108 .sp
109 As well as different views, the number of samples may be changed between
110 sensors, where the
111 .I \-rd
112 option controls the number of ray samples sent at random, and the
113 .I \-dn
114 option controls the number of rays sent to each light source per sensor.
115 .PP
116 The
117 .I \-h
118 option toggles header output, which defaults to "on."
119 The
120 .I \-n
121 option may be used to specify multiple calculation processes on
122 systems with more than one CPU.
123 For additional options, consult the
124 .I rtrace(1)
125 man page.
126 The final
127 .I octree
128 argument must be given, as the octree cannot be read from the
129 standard input.
130 .SH EXAMPLES
131 To compute values for the same sensor with two different positions:
132 .IP "" .2i
133 rsensor -ab 2 -vf posA.vf mysens.dat -vf posB.vf mysens.dat scene.oct
134 .PP
135 To generate a set of rays corresponding to a given sensor and compute
136 the resulting signal with rtrace:
137 .IP "" .2i
138 rsensor -h -vf posC.vf mysens.dat . | rtrace -h scene.oct | total -m
139 .SH ENVIRONMENT
140 RAYPATH the directories to check for auxiliary files.
141 .SH AUTHOR
142 Greg Ward for Architectural Energy Corporation
143 .SH "SEE ALSO"
144 oconv(1), rpict(1), rcontrib(1), rtrace(1)
