root/radiance/ray/doc/man/man1/rpiece.1
Revision: 1.1
Committed: Tue Mar 11 19:20:21 2003 UTC (22 years, 3 months ago) by greg
Added documentation to repository
1 .\" RCSid "$Id"
2 .TH RPIECE 1 10/1/98 RADIANCE
3 .SH NAME
4 rpiece - render pieces of a RADIANCE picture
5 .SH SYNOPSIS
6 .B rpiece
7 [
8 .B \-v
9 ][
10 .B "\-x xres"
11 ][
12 .B "\-y yres"
13 ][
14 .B "\-X xdiv"
15 ][
16 .B "\-Y ydiv"
17 ][
18 .B "\-F|R syncfile"
19 ][
20 .B "\-T timelim"
21 ]
22 [
23 .B $EVAR
24 ]
25 [
26 .B @file
27 ]
28 [
29 rpict options
30 ]
31 .B "\-o picture"
32 .B octree
33 .SH DESCRIPTION
34 .I Rpiece
35 renders a RADIANCE picture a piece at a time, calling
36 .I rpict(1)
37 to do the actual work.
38 This is useful for running multiple
39 .I rpict
40 processes on cooperating machines to render a single picture,
41 which is a shared file specified with the
42 .I \-o
43 option.
44 The overall picture dimensions will be
45 .I xres
46 by
47 .I yres
48 (or smaller, depending on the
49 .I \-pa
50 option and other view options), and the picture will be rendered in
51 .I xdiv
52 by
53 .I ydiv
54 pieces.
55 .PP
56 There are two basic methods for telling
57 .I rpiece
58 which piece(s) of a picture to render.
59 The explicit method is to write on the standard input the
60 .I X
61 and
62 .I Y
63 position of the desired piece(s), where
64 .I X
65 runs from zero to
66 .I xdiv\-\1
67 and
68 .I Y
69 runs from zero to
70 .I ydiv\-\1.
71 (The lower left piece of a picture corresponds to (0,0) in this
72 system.)\0
73 Alternatively, the implicit specification method uses a
74 synchronization file to
75 determine which piece is to be rendered next.
76 Specified with the
77 .I \-F
78 option,
79 .I syncfile
80 initially contains the values for
81 .I xdiv
82 and
83 .I ydiv,
84 so the
85 .I \-X
86 and
87 .I \-Y
88 options are unnecessary.
89 (However, they are used if
90 .I syncfile
91 does not exist.)\0
92 The first
93 .I rpiece
94 process puts a lock on
95 .I syncfile
96 and modifies its contents before
97 starting work on the first piece of the image.
98 It writes the
99 .I X
100 and
101 .I Y
102 position of the piece it will work on, so the next
103 .I rpiece
104 process to modify
105 .I syncfile
106 will start on the next piece.
107 (When it finishes with its piece, it appends the index to the end of
108 .I syncfile.)
109 This procedure continues until all the pieces are done, at which point all
110 of the
111 .I rpiece
112 processes will terminate.
113 .PP
114 The
115 .I \-R
116 option may be used instead of
117 .I \-F
118 if some of the pieces were not properly finished by previous (killed)
119 runs of
120 .I rpiece.
121 This option should be used by at most one
122 .I rpiece
123 process, which must be started first and with
124 .I "no other rpiece processes running"
125 or else it will rerender the same pieces other processes have begun.
126 Once the recover process is started, you may start other
127 .I rpiece
128 processes using the
129 .I \-F
130 option to run simultaneously.
131 If some processes die during execution, leaving one or more half-finished
132 pieces in the picture even though the other processes think the
133 work is done, you may run a single
134 .I rpiece
135 with the
136 .I \-R
137 option by itself to repair the holes.
138 .PP
139 The
140 .I \-v
141 flag switches on verbose mode, where
142 .I rpiece
143 reports to the standard output after each piece begins and
144 after each piece is finished.
145 .PP
146 Options may be given on the command line and/or read from the
147 environment and/or read from a file.
148 A command argument beginning with a dollar sign ('$') is immediately
149 replaced by the contents of the given environment variable.
150 A command argument beginning with an at sign ('@') is immediately
151 replaced by the contents of the given file.
152 .SH EXAMPLE
153 First
154 .I rpiece
155 process is started on the machine "goober":
156 .IP "" .2i
157 goober% echo 1 8 > syncfile
158 .br
159 goober% echo -F syncfile -x 1024 -y 1024 -vf view -o picture octree > args
160 .br
161 goober% rpiece @args &
162 .PP
163 Second
164 .I rpiece
165 processes is started on the machine "sucker":
166 .IP "" .2i
167 sucker% rpiece @args &
168 .SH NOTES
169 Due to NFS file buffering, the network lock manager is employed to
170 guarantee consistency in the output file even though non-overlapping
171 writes are used.
172 This would tend to slow the process down if
173 .I rpiece
174 were to wait for this I/O to complete before starting on the next
175 piece, so
176 .I rpiece
177 forks separate processes to hang around waiting for I/O completion.
178 The number of processes thus designated is set by the MAXFORK macro
179 in the program (compiled in the src/util directory).
180 If the fork call is slow on a system, it may actually be better to
181 set MAXFORK to zero.
182 In other cases, the network lock manager may be so slow that this
183 value should be increased to get the best utilization.
184 .PP
185 The output picture is not run-length encoded, and can be quite
186 large.
187 The approximate size (in kilobytes) can be computed by the simple
188 formula:
189 .IP "" .2i
190 filesize = xres*yres/256
191 .PP
192 Make sure that there is enough space on the filesystem to hold the
193 entire picture before beginning.
194 Once the picture is finished, the
195 .I ra_rgbe(1)
196 program with the -r option may be used to convert to a run-length
197 encoded picture for more efficient storage, although
198 .I pfilt(1)
199 or any of the other Radiance picture filters will do the same
200 thing.
201 .PP
202 The ALRM signal may be used to gracefully terminate an
203 .I rpiece
204 process after it finishes the current piece.
205 This permits other currently running or subsequently started
206 .I rpiece
207 process(es) to continue rendering the picture without loss.
208 The
209 .I \-T
210 option will send the ALRM signal to
211 .I rpiece
212 after the specified number of (decimal) hours.
213 This is the best way to force a time limit on the computation,
214 since information will not be lost, though the process may continue
215 for some time afterwards to finish its current piece.
216 .SH BUGS
217 This program may not work on some systems whose NFS lock manager is
218 unreliable.
219 In particular, some System V derivative UNIX systems often have
220 problems with the network lock manager.
221 If the output is scrambled or rpict aborts with some ambient file
222 related problem, you should just remove the ambient file and go
223 back to normal rendering.
224 .SH AUTHOR
225 Greg Ward
226 .SH "SEE ALSO"
227 getinfo(1), pfilt(1), ra_rgbe(1), rpict(1), ximage(1)
