| 1 |
greg |
1.4 |
.\" RCSid "$Id: rpiece.1,v 1.3 2007/09/04 17:36:41 greg Exp $"
| 2 |
greg |
1.1 |
.TH RPIECE 1 10/1/98 RADIANCE
| 3 |
.SH NAME
| 4 |
rpiece - render pieces of a RADIANCE picture
| 5 |
.SH SYNOPSIS
| 6 |
.B rpiece
| 7 |
| 8 |
.B \-v
| 9 |
| 10 |
.B "\-x xres"
| 11 |
| 12 |
.B "\-y yres"
| 13 |
| 14 |
.B "\-X xdiv"
| 15 |
| 16 |
.B "\-Y ydiv"
| 17 |
| 18 |
.B "\-F|R syncfile"
| 19 |
| 20 |
.B "\-T timelim"
| 21 |
| 22 |
| 23 |
.B $EVAR
| 24 |
| 25 |
| 26 |
.B @file
| 27 |
| 28 |
| 29 |
rpict options
| 30 |
| 31 |
.B "\-o picture"
| 32 |
.B octree
| 33 |
.SH DESCRIPTION
| 34 |
.I Rpiece
| 35 |
renders a RADIANCE picture a piece at a time, calling
| 36 |
.I rpict(1)
| 37 |
to do the actual work.
| 38 |
This is useful for running multiple
| 39 |
.I rpict
| 40 |
processes on cooperating machines to render a single picture,
| 41 |
which is a shared file specified with the
| 42 |
.I \-o
| 43 |
option.
| 44 |
The overall picture dimensions will be
| 45 |
.I xres
| 46 |
| 47 |
.I yres
| 48 |
(or smaller, depending on the
| 49 |
.I \-pa
| 50 |
option and other view options), and the picture will be rendered in
| 51 |
.I xdiv
| 52 |
| 53 |
.I ydiv
| 54 |
pieces.
| 55 |
.PP
| 56 |
There are two basic methods for telling
| 57 |
.I rpiece
| 58 |
which piece(s) of a picture to render.
| 59 |
The explicit method is to write on the standard input the
| 60 |
.I X
| 61 |
and
| 62 |
.I Y
| 63 |
position of the desired piece(s), where
| 64 |
.I X
| 65 |
runs from zero to
| 66 |
.I xdiv\-\1
| 67 |
and
| 68 |
.I Y
| 69 |
runs from zero to
| 70 |
.I ydiv\-\1.
| 71 |
(The lower left piece of a picture corresponds to (0,0) in this
| 72 |
system.)\0
| 73 |
Alternatively, the implicit specification method uses a
| 74 |
synchronization file to
| 75 |
determine which piece is to be rendered next.
| 76 |
Specified with the
| 77 |
.I \-F
| 78 |
option,
| 79 |
.I syncfile
| 80 |
initially contains the values for
| 81 |
.I xdiv
| 82 |
and
| 83 |
.I ydiv,
| 84 |
so the
| 85 |
.I \-X
| 86 |
and
| 87 |
.I \-Y
| 88 |
options are unnecessary.
| 89 |
(However, they are used if
| 90 |
.I syncfile
| 91 |
does not exist.)\0
| 92 |
The first
| 93 |
.I rpiece
| 94 |
process puts a lock on
| 95 |
.I syncfile
| 96 |
and modifies its contents before
| 97 |
starting work on the first piece of the image.
| 98 |
It writes the
| 99 |
.I X
| 100 |
and
| 101 |
.I Y
| 102 |
position of the piece it will work on, so the next
| 103 |
.I rpiece
| 104 |
process to modify
| 105 |
.I syncfile
| 106 |
will start on the next piece.
| 107 |
(When it finishes with its piece, it appends the index to the end of
| 108 |
.I syncfile.)
| 109 |
This procedure continues until all the pieces are done, at which point all
| 110 |
of the
| 111 |
.I rpiece
| 112 |
processes will terminate.
| 113 |
.PP
| 114 |
The
| 115 |
.I \-R
| 116 |
option may be used instead of
| 117 |
.I \-F
| 118 |
if some of the pieces were not properly finished by previous (killed)
| 119 |
runs of
| 120 |
.I rpiece.
| 121 |
This option should be used by at most one
| 122 |
.I rpiece
| 123 |
process, which must be started first and with
| 124 |
.I "no other rpiece processes running"
| 125 |
or else it will rerender the same pieces other processes have begun.
| 126 |
Once the recover process is started, you may start other
| 127 |
.I rpiece
| 128 |
processes using the
| 129 |
.I \-F
| 130 |
option to run simultaneously.
| 131 |
If some processes die during execution, leaving one or more half-finished
| 132 |
pieces in the picture even though the other processes think the
| 133 |
work is done, you may run a single
| 134 |
.I rpiece
| 135 |
with the
| 136 |
.I \-R
| 137 |
option by itself to repair the holes.
| 138 |
.PP
| 139 |
The
| 140 |
.I \-v
| 141 |
flag switches on verbose mode, where
| 142 |
.I rpiece
| 143 |
reports to the standard output after each piece begins and
| 144 |
after each piece is finished.
| 145 |
.PP
| 146 |
Options may be given on the command line and/or read from the
| 147 |
environment and/or read from a file.
| 148 |
A command argument beginning with a dollar sign ('$') is immediately
| 149 |
replaced by the contents of the given environment variable.
| 150 |
A command argument beginning with an at sign ('@') is immediately
| 151 |
replaced by the contents of the given file.
| 152 |
.SH EXAMPLE
| 153 |
First
| 154 |
.I rpiece
| 155 |
process is started on the machine "goober":
| 156 |
.IP "" .2i
| 157 |
goober% echo 1 8 > syncfile
| 158 |
.br
| 159 |
greg |
1.3 |
goober% echo \-F syncfile \-x 1024 \-y 1024 \-vf view \-o picture octree > args
| 160 |
greg |
1.1 |
.br
| 161 |
goober% rpiece @args &
| 162 |
.PP
| 163 |
Second
| 164 |
.I rpiece
| 165 |
processes is started on the machine "sucker":
| 166 |
.IP "" .2i
| 167 |
sucker% rpiece @args &
| 168 |
.SH NOTES
| 169 |
Due to NFS file buffering, the network lock manager is employed to
| 170 |
guarantee consistency in the output file even though non-overlapping
| 171 |
writes are used.
| 172 |
This would tend to slow the process down if
| 173 |
.I rpiece
| 174 |
were to wait for this I/O to complete before starting on the next
| 175 |
piece, so
| 176 |
.I rpiece
| 177 |
forks separate processes to hang around waiting for I/O completion.
| 178 |
The number of processes thus designated is set by the MAXFORK macro
| 179 |
in the program (compiled in the src/util directory).
| 180 |
If the fork call is slow on a system, it may actually be better to
| 181 |
set MAXFORK to zero.
| 182 |
In other cases, the network lock manager may be so slow that this
| 183 |
value should be increased to get the best utilization.
| 184 |
.PP
| 185 |
The output picture is not run-length encoded, and can be quite
| 186 |
large.
| 187 |
The approximate size (in kilobytes) can be computed by the simple
| 188 |
formula:
| 189 |
.IP "" .2i
| 190 |
filesize = xres*yres/256
| 191 |
.PP
| 192 |
Make sure that there is enough space on the filesystem to hold the
| 193 |
entire picture before beginning.
| 194 |
Once the picture is finished, the
| 195 |
.I ra_rgbe(1)
| 196 |
greg |
1.3 |
program with the \-r option may be used to convert to a run\-length
| 197 |
greg |
1.1 |
encoded picture for more efficient storage, although
| 198 |
.I pfilt(1)
| 199 |
or any of the other Radiance picture filters will do the same
| 200 |
thing.
| 201 |
.PP
| 202 |
The ALRM signal may be used to gracefully terminate an
| 203 |
.I rpiece
| 204 |
process after it finishes the current piece.
| 205 |
This permits other currently running or subsequently started
| 206 |
.I rpiece
| 207 |
process(es) to continue rendering the picture without loss.
| 208 |
The
| 209 |
.I \-T
| 210 |
option will send the ALRM signal to
| 211 |
.I rpiece
| 212 |
after the specified number of (decimal) hours.
| 213 |
This is the best way to force a time limit on the computation,
| 214 |
since information will not be lost, though the process may continue
| 215 |
for some time afterwards to finish its current piece.
| 216 |
.SH BUGS
| 217 |
This program may not work on some systems whose NFS lock manager is
| 218 |
unreliable.
| 219 |
In particular, some System V derivative UNIX systems often have
| 220 |
problems with the network lock manager.
| 221 |
If the output is scrambled or rpict aborts with some ambient file
| 222 |
related problem, you should just remove the ambient file and go
| 223 |
back to normal rendering.
| 224 |
.SH AUTHOR
| 225 |
Greg Ward
| 226 |
.SH "SEE ALSO"
| 227 |
greg |
1.4 |
getinfo(1), pfilt(1), ra_rgbe(1), rpict(1), rtpict(1), ximage(1)
