docs: moved -p* options together
docs: made use of "virtual" and "secondary" sources more consistent
Added remark to clarify what "resolution" means
Removed erroneous reference to (unsupported) -n in combination with -aC
Fixed incorrect wording on -lr option
Wrote rtpict program to run rpict as if it had a -n option
Documented treatment of contrib photons as global under rpict/rtrace
Updated man pages with pmap parallelisation and ooC options
Revised -am and -ab options, the latter defaulting to 1 in pmap mode
Corrected description of -lr option.
Added backslashes in front of hyphens (thanks to Bernd Zeimetz for his effort)
Had to change new -R rendering option to -u to avoid conflict with rpiece
Added comment about -vd length being used by -pd option
Fixed RCSid specification
