--- ray/doc/man/man1/rpict.1 2003/12/09 15:59:07 1.2 +++ ray/doc/man/man1/rpict.1 2005/05/31 18:01:08 1.8 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: rpict.1,v 1.2 2003/12/09 15:59:07 greg Exp $" +.\" RCSid "$Id: rpict.1,v 1.8 2005/05/31 18:01:08 greg Exp $" .TH RPICT 1 2/26/99 RADIANCE .SH NAME rpict - generate a RADIANCE picture @@ -89,6 +89,9 @@ center of a parallel projection. .BI -vd " xd yd zd" Set the view direction vector to .I "xd yd zd". +The length of this vector indicates the focal distance as needed by the +.I \-pd +option, described below. .TP .BI -vu " xd yd zd" Set the view up vector (vertical direction) to @@ -163,7 +166,7 @@ option. .BI -vf \ file Get view parameters from .I file, -which may be a picture or a file created by rview (with the "view" command). +which may be a picture or a file created by rvu (with the "view" command). .TP .BI -x \ res Set the maximum x resolution to @@ -226,6 +229,23 @@ to use a very small fraction with the .I \-pm option, to avoid the ghosting effect of too few time samples. .TP +.BI -pd \ dia +Set the pixel depth-of-field aperture to a diameter of +.I dia +(in world coordinates). +This will be used in conjunction with the view focal distance, indicated +by the length of the view direction vector given in the +.I \-vd +option. +It is not advisable to use this option in combination with the +.I pdfblur(1) +program, since one takes the place of the other. +However, it may improve results with +.I pdfblur +to use a very small fraction with the +.I \-pd +option, to avoid the ghosting effect of too few samples. +.TP .BI -dj \ frac Set the direct jittering to .I frac. @@ -452,23 +472,23 @@ header of the ambient file. .I Getinfo(1) may be used to print out this information. .TP -.BI -ae \ mat +.BI -ae \ mod Append -.I mat +.I mod to the ambient exclude list, so that it will not be considered during the indirect calculation. This is a hack for speeding the indirect computation by ignoring certain objects. Any object having -.I mat +.I mod as its modifier will get the default ambient level rather than a calculated value. -Any number of excluded materials may be given, but each +Any number of excluded modifiers may be given, but each must appear in a separate option. .TP -.BI -ai \ mat +.BI -ai \ mod Add -.I mat +.I mod to the ambient include list, so that it will be considered during the indirect calculation. The program can use either an include list or an exclude @@ -477,16 +497,16 @@ list, but not both. .BI -aE \ file Same as .I \-ae, -except read materials to be excluded from +except read modifiers to be excluded from .I file. The RAYPATH environment variable determines which directories are searched for this file. -The material names are separated by white space in the file. +The modifier names are separated by white space in the file. .TP .BI -aI \ file Same as .I \-ai, -except read materials to be included from +except read modifiers to be included from .I file. .TP .BI -me " rext gext bext" @@ -538,13 +558,29 @@ option (above) may be used to override this. .BI -lr \ N Limit reflections to a maximum of .I N. +If +.I N +is zero, then Russian roulette is used for ray +termination, and the +.I -lw +setting (below) must be positive. +If N is a negative integer, then this sets the upper limit +of reflections past which Russian roulette will not be used. +In scenes with dielectrics and total internal reflection, +a setting of 0 (no limit) may cause a stack overflow. .TP .BI -lw \ frac Limit the weight of each ray to a minimum of .I frac. -During ray-tracing, a record is kept of the final contribution -a ray would have to the image. -If it is less then the specified minimum, the ray is not traced. +During ray-tracing, a record is kept of the estimated contribution +(weight) a ray would have in the image. +If this weight is less than the specified minimum and the +.I -lr +setting (above) is positive, the ray is not traced. +Otherwise, Russian roulette is used to +continue rays with a probability equal to the ray weight +divided by the given +.I frac. .TP .BI -S \ seqstart Instead of generating a single picture based only on the view @@ -752,7 +788,7 @@ rpict -S 1 -o frame%02d.pic scene.oct < keyframes.vf .SH ENVIRONMENT RAYPATH the directories to check for auxiliary files. .SH FILES -/usr/tmp/rtXXXXXX common header information for picture sequence +/tmp/rtXXXXXX common header information for picture sequence .br rfXXXXXX temporary name for recover file .SH DIAGNOSTICS @@ -768,5 +804,5 @@ option. .SH AUTHOR Greg Ward .SH "SEE ALSO" -getinfo(1), lookamb(1), oconv(1), pfilt(1), pinterp(1), pmblur(1), -printf(3), ra_rgbe(1), rad(1), rtrace(1), rview(1) +getinfo(1), lookamb(1), oconv(1), pdfblur(1), pfilt(1), pinterp(1), pmblur(1), +printf(3), ra_rgbe(1), rad(1), rtrace(1), rvu(1)
