--- ray/doc/man/man1/rpict.1 2005/01/18 01:13:23 1.5 +++ ray/doc/man/man1/rpict.1 2023/11/15 19:21:54 1.30 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: rpict.1,v 1.5 2005/01/18 01:13:23 greg Exp $" +.\" RCSid "$Id: rpict.1,v 1.30 2023/11/15 19:21:54 greg Exp $" .TH RPICT 1 2/26/99 RADIANCE .SH NAME rpict - generate a RADIANCE picture @@ -18,6 +18,8 @@ rpict - generate a RADIANCE picture ] .br .B "rpict [ options ] \-defaults" +.br +.B "rpict \-features [feat1 ..]" .SH DESCRIPTION .I Rpict generates a picture from the RADIANCE scene given in @@ -41,6 +43,21 @@ In the second form shown above, the default values for the options (modified by those options present) are printed with a brief explanation. .PP +In the third form, a list of supported features is sent +to the standard output, one per line. +If additional arguments follow, they are checked for presence in +this list. +If a feature includes subfeatures, these may be checked as well by +specifying: +.nf + + rpict -features FeatName=subfeat1,subfeat2 + +.fi +If any named feature or subfeature is missing, an error is +reported and the program returns an error status. +If all of the named features are present, a zero status is returned. +.PP Most options are followed by one or more arguments, which must be separated from the option and each other by white space. The exceptions to this rule are the @@ -70,13 +87,21 @@ A cylindrical panorma may be selected by setting to the letter 'c'. This view is like a standard perspective vertically, but projected on a cylinder horizontally (like a soupcan's-eye view). -Two fisheye views are provided as well; 'h' yields a hemispherical fisheye -view and 'a' results in angular fisheye distortion. +Three fisheye views are provided as well; 'h' yields a hemispherical fisheye +view, 'a' results in angular fisheye distortion, and 's' +results in a planisphere (stereographic) projection. A hemispherical fisheye is a projection of the hemisphere onto a circle. The maximum view angle for this type is 180 degrees. An angular fisheye view is defined such that distance from the center of the image is proportional to the angle from the central view direction. An angular fisheye can display a full 360 degrees. +A planisphere fisheye view maintains angular relationships between lines, +and is commonly used for sun path analysis. +This is more commonly known as a +"stereographic projection," but we avoid the term here so as not to +confuse it with a stereoscopic pair. +A planisphere fisheye can display up to (but not including) 360 degrees, +although distortion becomes extreme as this limit is approached. Note that there is no space between the view type option and its single letter argument. .TP @@ -152,7 +177,7 @@ This is option is useful for generating skewed perspec rendering an image a piece at a time. A value of 1 means that the rendered image starts just to the right of the normal view. -A value of -1 would be to the left. +A value of \-1 would be to the left. Larger or fractional values are permitted as well. .TP .BI -vl \ val @@ -203,10 +228,10 @@ Set the pixel sample jitter to Distributed ray-tracing performs anti-aliasing by randomly sampling over pixels. A value of one will randomly distribute samples over full -pixels. +pixels, and is not really recommended due to the tendency of +samples to (nearly) coincide. A value of zero samples pixel centers only. -A value between zero and one is usually best -for low-resolution images. +A value around 0.5-0.8 is typical. .TP .BI -pm \ frac Set the pixel motion blur to @@ -246,6 +271,16 @@ to use a very small fraction with the .I \-pd option, to avoid the ghosting effect of too few samples. .TP +.BI -pc " xr yr xg yg xb yb xw yw" +Use the specified chromaticity pairs for output primaries and white +point rather than the standard RGB color space. +.TP +.BR \-pRGB +Output standard RGB values (the default). +.TP +.BR \-pXYZ +Output standard CIE XYZ tristimulus values rather than RGB. +.TP .BI -dj \ frac Set the direct jittering to .I frac. @@ -263,7 +298,7 @@ A warning about aiming failure will issued if .I frac is too large. It is usually wise to turn off image sampling when using -direct jitter by setting -ps to 1. +direct jitter by setting \-ps to 1. .TP .BI -ds \ frac Set the direct sampling ratio to @@ -302,21 +337,21 @@ change greater than the specification will be calculated. .TP .BI -dr \ N -Set the number of relays for secondary sources to +Set the number of relays for virtual sources to .I N. -A value of 0 means that secondary sources will be ignored. +A value of 0 means that virtual sources will be ignored. A value of 1 means that sources will be made into first generation -secondary sources; a value of 2 means that first generation -secondary sources will also be made into second generation secondary +virtual sources; a value of 2 means that first generation +virtual sources will also be made into second generation virtual sources, and so on. .TP .BI -dp \ D -Set the secondary source presampling density to D. +Set the virtual source presampling density to D. This is the number of samples per steradian that will be used to determine ahead of time whether or not it is worth following shadow rays through all the reflections and/or -transmissions associated with a secondary source path. -A value of 0 means that the full secondary source path will always +transmissions associated with a virtual source path. +A value of 0 means that the full virtual source path will always be tested for shadows if it is tested at all. .TP .BR \-dv @@ -327,13 +362,13 @@ This option may be desirable in conjunction with the .I \-i option so that light sources do not appear in the output. .TP -.BI -sj \ frac -Set the specular sampling jitter to -.I frac. -This is the degree to which the highlights are sampled -for rough specular materials. -A value of one means that all highlights will be fully sampled -using distributed ray tracing. +.BI -ss \ samp +Set the specular sampling to +.I samp. +For values less than 1, this is the degree to which the highlights +are sampled for rough specular materials. +A value greater than one causes multiple ray samples to be sent +to reduce noise at a commmesurate cost. A value of zero means that no jittering will take place, and all reflections will appear sharp even when they should be diffuse. This may be desirable when used in combination with image sampling @@ -357,15 +392,14 @@ accuracy and rendering time. .TP .BR -bv Boolean switch for back face visibility. -With this switch off, back faces of opaque objects will be invisible -to all rays. +With this switch off, back faces of all objects will be invisible +to view rays. This is dangerous unless the model was constructed such that -all surface normals on opaque objects face outward. +all surface normals face outward. Although turning off back face visibility does not save much computation time under most circumstances, it may be useful as a tool for scene debugging, or for seeing through one-sided walls from the outside. -This option has no effect on transparent or translucent materials. .TP .BI -av " red grn blu" Set the ambient value to a radiance of @@ -398,9 +432,17 @@ indirect contributions, such as when both indoor and o .BI -ab \ N Set the number of ambient bounces to .I N. -This is the maximum number of diffuse bounces -computed by the indirect calculation. -A value of zero implies no indirect calculation. +This is the maximum number of diffuse bounces computed by the indirect +calculation. A value of zero implies no indirect calculation. +.IP +This value defaults to 1 in photon mapping mode (see +.I -ap +below), implying that global photon irradiance is always computed via +.I one +ambient bounce; this behaviour applies to any positive number of ambient +bounces, regardless of the actual value specified. A negative value enables +a preview mode that directly visualises the irradiance from the global +photon map without any ambient bounces. .TP .BI -ar \ res Set the ambient resolution to @@ -424,14 +466,14 @@ A value of zero is interpreted as unlimited resolution Set the ambient accuracy to .I acc. This value will approximately equal the error -from indirect illuminance interpolation. +from indirect irradiance interpolation. A value of zero implies no interpolation. .TP .BI -ad \ N Set the number of ambient divisions to .I N. The error in the Monte Carlo calculation of indirect -illuminance will be inversely proportional to the square +irradiance will be inversely proportional to the square root of this number. A value of zero implies no indirect calculation. .TP @@ -444,13 +486,15 @@ show a significant change. .BI -af \ fname Set the ambient file to .I fname. -This is where indirect illuminance will be stored and retrieved. -Normally, indirect illuminance values are kept in memory and +This is where indirect irradiance will be stored and retrieved. +Normally, indirect irradiance values are kept in memory and lost when the program finishes or dies. -By using a file, different invocations can share illuminance +By using a file, different invocations can share irradiance values, saving time in the computation. -Also, by creating an ambient file during a low resolution rendering, -better results can be obtained in a second high resolution pass. +Also, by creating an ambient file during a low-resolution rendering, +better results can be obtained in a second high-resolution pass. +(It is a good idea to keep all of the calculation parameters the same, +changing only the dimensions of the output picture.)\0 The ambient file is in a machine-independent binary format which may be examined with .I lookamb(1). @@ -472,23 +516,23 @@ header of the ambient file. .I Getinfo(1) may be used to print out this information. .TP -.BI -ae \ mat +.BI -ae \ mod Append -.I mat +.I mod to the ambient exclude list, so that it will not be considered during the indirect calculation. This is a hack for speeding the indirect computation by ignoring certain objects. Any object having -.I mat +.I mod as its modifier will get the default ambient level rather than a calculated value. -Any number of excluded materials may be given, but each +Any number of excluded modifiers may be given, but each must appear in a separate option. .TP -.BI -ai \ mat +.BI -ai \ mod Add -.I mat +.I mod to the ambient include list, so that it will be considered during the indirect calculation. The program can use either an include list or an exclude @@ -497,18 +541,94 @@ list, but not both. .BI -aE \ file Same as .I \-ae, -except read materials to be excluded from +except read modifiers to be excluded from .I file. The RAYPATH environment variable determines which directories are searched for this file. -The material names are separated by white space in the file. +The modifier names are separated by white space in the file. .TP .BI -aI \ file Same as .I \-ai, -except read materials to be included from +except read modifiers to be included from .I file. .TP +.BI -ap " file [bwidth1 [bwidth2]]" +Enable photon mapping mode. Loads a photon map generated with +.I mkpmap(1) +from +.I file, +and evaluates the indirect irradiance depending on the photon type +(automagically detected) using density estimates with a bandwidth of +.I bwidth1 +photons, or the default bandwidth if none is specified (a warning will be +issued in this case). +.IP +Global photon irradiance is evaluated as part of the ambient calculation (see +.I \-ab +above), caustic photon irradiance is evaluated at primary rays, and +indirect inscattering in +.I mist +is accounted for by volume photons. Contribution photons are treated as +global photons by +.I rpict. +.IP +Additionally specifying +.I bwidth2 +enables bias compensation for the density estimates with a +minimum and maximum bandwidth of +.I bwidth1 +and +.I bwidth2, +respectively. +.IP +Global photon irradiance may be optionally precomputed by +.I mkpmap(1), +in which case the bandwidth, if specified, is ignored, as the nearest photon +is invariably looked up. +.IP +Using direct photons replaces the direct calculation with density estimates +for debugging and validation of photon emission. +.TP +.BI -am " frac" +Maximum search radius for photon map lookups. Without this option, an +initial maximum search radius is estimated for each photon map from the +average photon distance to the distribution's centre of gravity. It is then +adapted to the photon density in subsequent lookups. This option imposes a +global fixed maximum search radius for +.I all +photon maps, thus defeating the automatic adaptation. It is useful when +multiple warnings about short photon lookups are issued. Note that this +option does not conflict with the bandwidth specified with the +.I \-ap +option; the number of photons found will not exceed the latter, but may be +lower if the maximum search radius contains fewer photons, thus resulting in +short lookups. Setting this radius too large, on the other hand, may +degrade performance. +.TP +.BI -ac " pagesize" +Set the photon cache page size when using out-of-core photon mapping. The +photon cache reduces disk I/O incurred by on-demand loading (paging) of +photons, and thus increases performance. This +is expressed as a (float) multiple of the density estimate bandwidth +specified with +.I \-ap +under the assumption that photon lookups are local to a cache page. Cache +performance is sensitive to this parameter: larger pagesizes will reduce the +paging frequency at the expense of higher latency when paging does occur. +Sensible values are in the range 4 (default) to 16. +.TP +.BI -aC " cachesize" +Set the total number of photons cached when using out-of-core photon +mapping, taking into account the pagesize specified by +.I \-ac. +Note that this is approximate as the number of cache pages is rounded to +the nearest prime. This allows adapting the cache to the available physical +memory. Cache performance is less sensitive to this parameter, and reasonable +performance can obtained with as few as 10k photons. The default is 1M. This +option recognises multiplier suffixes (k = 1e3, M = 1e6), both in upper and +lower case. +.TP .BI -me " rext gext bext" Set the global medium extinction coefficient to the indicated color, in units of 1/distance (distance in world coordinates). @@ -555,17 +675,53 @@ though the .I \-dv option (above) may be used to override this. .TP +.BR \-u +Boolean switch to control uncorrelated random sampling. +When "off", a low-discrepancy sequence is used, which reduces +variance but can result in a dithered appearance in specular highlights. +When "on", pure Monte Carlo sampling is used in all calculations. +.TP .BI -lr \ N Limit reflections to a maximum of -.I N. +.I N, +if N is a positive integer. +If +.I N +is zero, then Russian roulette is used for ray +termination, and the +.I -lw +setting (below) must be positive. +If N is a negative integer, then this limits the maximum +number of reflections even with Russian roulette. +In scenes with dielectrics and total internal reflection, +a setting of 0 (no limit) may cause a stack overflow. .TP .BI -lw \ frac Limit the weight of each ray to a minimum of .I frac. -During ray-tracing, a record is kept of the final contribution -a ray would have to the image. -If it is less then the specified minimum, the ray is not traced. +During ray-tracing, a record is kept of the estimated contribution +(weight) a ray would have in the image. +If this weight is less than the specified minimum and the +.I -lr +setting (above) is positive, the ray is not traced. +Otherwise, Russian roulette is used to +continue rays with a probability equal to the ray weight +divided by the given +.I frac. .TP +.BI -cs \ Ns +Use +.I Ns +bands for spectral sampling rather than the default RGB calculation space. +The maximum setting is controlled by the compiler macro MAXCSAMP, and +defaults to 24. +Larger values for Ns will be reduced to MAXCSAMP. +.TP +.BI -cw " nmA nmB" +Set extrema to the given wavelengths for spectral sampling. +The default is 380 and 780 nanometers. +The order specified does not matter. +.TP .BI -S \ seqstart Instead of generating a single picture based only on the view parameters given on the command line, this option causes @@ -752,7 +908,7 @@ Set the time between progress reports to A progress report writes the number of rays traced, the percentage completed, and the CPU usage to the standard error. Reports are given either automatically after the specified interval, -or when the process receives a continue (-CONT) signal (see +or when the process receives a continue (\-CONT) signal (see .I kill(1)). A value of zero turns automatic reporting off. .TP @@ -766,13 +922,20 @@ Boolean switch for warning messages. The default is to print warnings, so the first appearance of this option turns them off. .SH EXAMPLE -rpict -vp 10 5 3 -vd 1 -.5 0 scene.oct > scene.pic +rpict \-vp 10 5 3 \-vd 1 \-.5 0 scene.oct > scene.hdr .PP -rpict -S 1 -o frame%02d.pic scene.oct < keyframes.vf +rpict \-S 1 \-o frame%02d.hdr scene.oct < keyframes.vf +.PP +To render ambient irradiance in photon mapping mode from a global photon +map global.pm via one ambient bounce, and from a caustic photon map +caustic.pm: +.IP "" .2i +rpict -ab 1 -ap global.pm 50 -ap caustic.pm 50 -vf scene.vf scene.oct > +scene.hdr .SH ENVIRONMENT RAYPATH the directories to check for auxiliary files. .SH FILES -/usr/tmp/rtXXXXXX common header information for picture sequence +/tmp/rtXXXXXX common header information for picture sequence .br rfXXXXXX temporary name for recover file .SH DIAGNOSTICS @@ -788,5 +951,5 @@ option. .SH AUTHOR Greg Ward .SH "SEE ALSO" -getinfo(1), lookamb(1), oconv(1), pdfblur(1), pfilt(1), pinterp(1), pmblur(1), -printf(3), ra_rgbe(1), rad(1), rtrace(1), rvu(1) +getinfo(1), lookamb(1), mkpmap(1), oconv(1), pdfblur(1), pfilt(1), +pinterp(1), pmblur(1), printf(3), ra_rgbe(1), rad(1), rpiece(1), rtpict(1), rtrace(1), rvu(1)
