--- ray/doc/man/man1/rpict.1 2025/04/22 17:12:25 1.31 +++ ray/doc/man/man1/rpict.1 2025/04/23 15:09:03 1.32 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: rpict.1,v 1.31 2025/04/22 17:12:25 greg Exp $" +.\" RCSid "$Id: rpict.1,v 1.32 2025/04/23 15:09:03 greg Exp $" .TH RPICT 1 2/26/99 RADIANCE .SH NAME rpict - generate a RADIANCE picture @@ -282,9 +282,12 @@ Output standard RGB values (the default). Output standard CIE XYZ tristimulus values rather than RGB. .TP .BI -f \ source -Load definitions from +Load definitions from the file .I source -and assign at global level. +and assign at the global level. +The usual set of library directories is searched based on the +.I RAYPATH +environment variable. .TP .BI -e \ expr Set additional definitions from
