--- ray/doc/man/man1/rpict.1 2015/02/24 19:39:26 1.18 +++ ray/doc/man/man1/rpict.1 2020/05/19 16:00:58 1.26 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: rpict.1,v 1.18 2015/02/24 19:39:26 greg Exp $" +.\" RCSid "$Id: rpict.1,v 1.26 2020/05/19 16:00:58 greg Exp $" .TH RPICT 1 2/26/99 RADIANCE .SH NAME rpict - generate a RADIANCE picture @@ -211,10 +211,10 @@ Set the pixel sample jitter to Distributed ray-tracing performs anti-aliasing by randomly sampling over pixels. A value of one will randomly distribute samples over full -pixels. +pixels, and is not really recommended due to the tendency of +samples to (nearly) coincide. A value of zero samples pixel centers only. -A value between zero and one is usually best -for low-resolution images. +A value around 0.5-0.8 is typical. .TP .BI -pm \ frac Set the pixel motion blur to @@ -408,14 +408,14 @@ Set the number of ambient bounces to This is the maximum number of diffuse bounces computed by the indirect calculation. A value of zero implies no indirect calculation. .IP -In photon mapping mode (see +This value defaults to 1 in photon mapping mode (see .I -ap -below), a positive value implies that global photon irradiance is -always computed via +below), implying that global photon irradiance is always computed via .I one -ambient bounce. A negative value enables a preview mode that directly -visualises the irradiance from the global photon map without any ambient -bounces. +ambient bounce; this behaviour applies to any positive number of ambient +bounces, regardless of the actual value specified. A negative value enables +a preview mode that directly visualises the irradiance from the global +photon map without any ambient bounces. .TP .BI -ar \ res Set the ambient resolution to @@ -464,8 +464,10 @@ Normally, indirect illuminance values are kept in memo lost when the program finishes or dies. By using a file, different invocations can share illuminance values, saving time in the computation. -Also, by creating an ambient file during a low resolution rendering, -better results can be obtained in a second high resolution pass. +Also, by creating an ambient file during a low-resolution rendering, +better results can be obtained in a second high-resolution pass. +(It is a good idea to keep all of the calculation parameters the same, +changing only the dimensions of the output picture.)\0 The ambient file is in a machine-independent binary format which may be examined with .I lookamb(1). @@ -540,7 +542,9 @@ Global photon irradiance is evaluated as part of the a above), caustic photon irradiance is evaluated at primary rays, and indirect inscattering in .I mist -is accounted for by volume photons. +is accounted for by volume photons. Contribution photons are treated as +global photons by +.I rpict. .IP Additionally specifying .I bwidth2 @@ -557,14 +561,47 @@ in which case the bandwidth, if specified, is ignored, is invariably looked up. .IP Using direct photons replaces the direct calculation with density estimates -for debugging and validation of photon emission. +for debugging and validation of photon emission. .TP .BI -am " frac" -Coefficient for maximum search radius for photon map lookups. The search -radius is automatically determined based on the average photon distance to the -distribution's centre of gravity, and scaled by this coefficient. Increase this -value if multiple warnings about short photon lookups are issued. +Maximum search radius for photon map lookups. Without this option, an +initial maximum search radius is estimated for each photon map from the +average photon distance to the distribution's centre of gravity. It is then +adapted to the photon density in subsequent lookups. This option imposes a +global fixed maximum search radius for +.I all +photon maps, thus defeating the automatic adaptation. It is useful when +multiple warnings about short photon lookups are issued. Note that this +option does not conflict with the bandwidth specified with the +.I \-ap +option; the number of photons found will not exceed the latter, but may be +lower if the maximum search radius contains fewer photons, thus resulting in +short lookups. Setting this radius too large, on the other hand, may +degrade performance. .TP +.BI -ac " pagesize" +Set the photon cache page size when using out-of-core photon mapping. The +photon cache reduces disk I/O incurred by on-demand loading (paging) of +photons, and thus increases performance. This +is expressed as a (float) multiple of the density estimate bandwidth +specified with +.I \-ap +under the assumption that photon lookups are local to a cache page. Cache +performance is sensitive to this parameter: larger pagesizes will reduce the +paging frequency at the expense of higher latency when paging does occur. +Sensible values are in the range 4 (default) to 16. +.TP +.BI -aC " cachesize" +Set the total number of photons cached when using out-of-core photon +mapping, taking into account the pagesize specified by +.I \-ac. +Note that this is approximate as the number of cache pages is rounded to +the nearest prime. This allows adapting the cache to the available physical +memory. Cache performance is less sensitive to this parameter, and reasonable +performance can obtained with as few as 10k photons. The default is 1M. This +option recognises multiplier suffixes (k = 1e3, M = 1e6), both in upper and +lower case. +.TP .BI -me " rext gext bext" Set the global medium extinction coefficient to the indicated color, in units of 1/distance (distance in world coordinates). @@ -627,8 +664,8 @@ is zero, then Russian roulette is used for ray termination, and the .I -lw setting (below) must be positive. -If N is a negative integer, then this sets the upper limit -of reflections past which Russian roulette will be used. +If N is a negative integer, then this limits the maximum +number of reflections even with Russian roulette. In scenes with dielectrics and total internal reflection, a setting of 0 (no limit) may cause a stack overflow. .TP @@ -875,5 +912,4 @@ option. Greg Ward .SH "SEE ALSO" getinfo(1), lookamb(1), mkpmap(1), oconv(1), pdfblur(1), pfilt(1), -pinterp(1), pmblur(1), printf(3), ra_rgbe(1), rad(1), rtrace(1), rvu(1) - +pinterp(1), pmblur(1), printf(3), ra_rgbe(1), rad(1), rpiece(1), rtpict(1), rtrace(1), rvu(1)
