--- ray/doc/man/man1/rpict.1 2015/06/05 08:49:01 1.20 +++ ray/doc/man/man1/rpict.1 2018/03/20 02:40:38 1.23 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: rpict.1,v 1.20 2015/06/05 08:49:01 rschregle Exp $" +.\" RCSid "$Id: rpict.1,v 1.23 2018/03/20 02:40:38 greg Exp $" .TH RPICT 1 2/26/99 RADIANCE .SH NAME rpict - generate a RADIANCE picture @@ -540,7 +540,9 @@ Global photon irradiance is evaluated as part of the a above), caustic photon irradiance is evaluated at primary rays, and indirect inscattering in .I mist -is accounted for by volume photons. +is accounted for by volume photons. Contribution photons are treated as +global photons by +.I rpict. .IP Additionally specifying .I bwidth2 @@ -557,7 +559,7 @@ in which case the bandwidth, if specified, is ignored, is invariably looked up. .IP Using direct photons replaces the direct calculation with density estimates -for debugging and validation of photon emission. +for debugging and validation of photon emission. .TP .BI -am " frac" Maximum search radius for photon map lookups. Without this option, an @@ -575,6 +577,33 @@ lower if the maximum search radius contains fewer phot short lookups. Setting this radius too large, on the other hand, may degrade performance. .TP +.BI -ac " pagesize" +Set the photon cache page size when using out-of-core photon mapping. The +photon cache reduces disk I/O incurred by on-demand loading (paging) of +photons, and thus increases performance. This +is expressed as a (float) multiple of the density estimate bandwidth +specified with +.I \-ap +under the assumption that photon lookups are local to a cache page. Cache +performance is sensitive to this parameter: larger pagesizes will reduce the +paging frequency at the expense of higher latency when paging does occur. +Sensible values are in the range 4 (default) to 16. +.TP +.BI -aC " cachesize" +Set the total number of photons cached when using out-of-core photon +mapping, taking into account the pagesize specified by +.I \-ac. +Note that this is approximate as the number of cache pages is rounded to +the nearest prime. This allows adapting the cache to the available physical +memory. In conjunction with the +.I \-n +option, this is the cache size +.I per parallel process. +Cache performance is less sensitive to this parameter, +and reasonable performance can obtained with as few as 10k photons. The +default is 1M. This option recognises multiplier suffixes (k = 1e3, M = +1e6), both in upper and lower case. +.TP .BI -me " rext gext bext" Set the global medium extinction coefficient to the indicated color, in units of 1/distance (distance in world coordinates). @@ -885,4 +914,4 @@ option. Greg Ward .SH "SEE ALSO" getinfo(1), lookamb(1), mkpmap(1), oconv(1), pdfblur(1), pfilt(1), -pinterp(1), pmblur(1), printf(3), ra_rgbe(1), rad(1), rtrace(1), rvu(1) +pinterp(1), pmblur(1), printf(3), ra_rgbe(1), rad(1), rpiece(1), rtpict(1), rtrace(1), rvu(1)
