--- ray/doc/man/man1/rpict.1 2004/01/01 19:31:45 1.3 +++ ray/doc/man/man1/rpict.1 2010/10/08 22:08:26 1.15 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: rpict.1,v 1.3 2004/01/01 19:31:45 greg Exp $" +.\" RCSid "$Id: rpict.1,v 1.15 2010/10/08 22:08:26 greg Exp $" .TH RPICT 1 2/26/99 RADIANCE .SH NAME rpict - generate a RADIANCE picture @@ -70,13 +70,21 @@ A cylindrical panorma may be selected by setting to the letter 'c'. This view is like a standard perspective vertically, but projected on a cylinder horizontally (like a soupcan's-eye view). -Two fisheye views are provided as well; 'h' yields a hemispherical fisheye -view and 'a' results in angular fisheye distortion. +Three fisheye views are provided as well; 'h' yields a hemispherical fisheye +view, 'a' results in angular fisheye distortion, and 's' +results in a planisphere (stereographic) projection. A hemispherical fisheye is a projection of the hemisphere onto a circle. The maximum view angle for this type is 180 degrees. An angular fisheye view is defined such that distance from the center of the image is proportional to the angle from the central view direction. An angular fisheye can display a full 360 degrees. +A planisphere fisheye view maintains angular relationships between lines, +and is commonly used for sun path analysis. +This is more commonly known as a +"stereographic projection," but we avoid the term here so as not to +confuse it with a stereoscopic pair. +A planisphere fisheye can display up to (but not including) 360 degrees, +although distortion becomes extreme as this limit is approached. Note that there is no space between the view type option and its single letter argument. .TP @@ -89,6 +97,9 @@ center of a parallel projection. .BI -vd " xd yd zd" Set the view direction vector to .I "xd yd zd". +The length of this vector indicates the focal distance as needed by the +.I \-pd +option, described below. .TP .BI -vu " xd yd zd" Set the view up vector (vertical direction) to @@ -149,7 +160,7 @@ This is option is useful for generating skewed perspec rendering an image a piece at a time. A value of 1 means that the rendered image starts just to the right of the normal view. -A value of -1 would be to the left. +A value of \-1 would be to the left. Larger or fractional values are permitted as well. .TP .BI -vl \ val @@ -226,6 +237,23 @@ to use a very small fraction with the .I \-pm option, to avoid the ghosting effect of too few time samples. .TP +.BI -pd \ dia +Set the pixel depth-of-field aperture to a diameter of +.I dia +(in world coordinates). +This will be used in conjunction with the view focal distance, indicated +by the length of the view direction vector given in the +.I \-vd +option. +It is not advisable to use this option in combination with the +.I pdfblur(1) +program, since one takes the place of the other. +However, it may improve results with +.I pdfblur +to use a very small fraction with the +.I \-pd +option, to avoid the ghosting effect of too few samples. +.TP .BI -dj \ frac Set the direct jittering to .I frac. @@ -243,7 +271,7 @@ A warning about aiming failure will issued if .I frac is too large. It is usually wise to turn off image sampling when using -direct jitter by setting -ps to 1. +direct jitter by setting \-ps to 1. .TP .BI -ds \ frac Set the direct sampling ratio to @@ -307,13 +335,13 @@ This option may be desirable in conjunction with the .I \-i option so that light sources do not appear in the output. .TP -.BI -sj \ frac -Set the specular sampling jitter to -.I frac. -This is the degree to which the highlights are sampled -for rough specular materials. -A value of one means that all highlights will be fully sampled -using distributed ray tracing. +.BI -ss \ samp +Set the specular sampling to +.I samp. +For values less than 1, this is the degree to which the highlights +are sampled for rough specular materials. +A value greater than one causes multiple ray samples to be sent +to reduce noise at a commmesurate cost. A value of zero means that no jittering will take place, and all reflections will appear sharp even when they should be diffuse. This may be desirable when used in combination with image sampling @@ -452,23 +480,23 @@ header of the ambient file. .I Getinfo(1) may be used to print out this information. .TP -.BI -ae \ mat +.BI -ae \ mod Append -.I mat +.I mod to the ambient exclude list, so that it will not be considered during the indirect calculation. This is a hack for speeding the indirect computation by ignoring certain objects. Any object having -.I mat +.I mod as its modifier will get the default ambient level rather than a calculated value. -Any number of excluded materials may be given, but each +Any number of excluded modifiers may be given, but each must appear in a separate option. .TP -.BI -ai \ mat +.BI -ai \ mod Add -.I mat +.I mod to the ambient include list, so that it will be considered during the indirect calculation. The program can use either an include list or an exclude @@ -477,16 +505,16 @@ list, but not both. .BI -aE \ file Same as .I \-ae, -except read materials to be excluded from +except read modifiers to be excluded from .I file. The RAYPATH environment variable determines which directories are searched for this file. -The material names are separated by white space in the file. +The modifier names are separated by white space in the file. .TP .BI -aI \ file Same as .I \-ai, -except read materials to be included from +except read modifiers to be included from .I file. .TP .BI -me " rext gext bext" @@ -535,16 +563,39 @@ though the .I \-dv option (above) may be used to override this. .TP +.BR \-u +Boolean switch to control uncorrelated random sampling. +When "off", a low-discrepancy sequence is used, which reduces +variance but can result in a brushed appearance in specular highlights. +When "on", pure Monte Carlo sampling is used in all calculations. +.TP .BI -lr \ N Limit reflections to a maximum of -.I N. +.I N, +if N is a positive integer. +If +.I N +is zero, then Russian roulette is used for ray +termination, and the +.I -lw +setting (below) must be positive. +If N is a negative integer, then this sets the upper limit +of reflections past which Russian roulette will be used. +In scenes with dielectrics and total internal reflection, +a setting of 0 (no limit) may cause a stack overflow. .TP .BI -lw \ frac Limit the weight of each ray to a minimum of .I frac. -During ray-tracing, a record is kept of the final contribution -a ray would have to the image. -If it is less then the specified minimum, the ray is not traced. +During ray-tracing, a record is kept of the estimated contribution +(weight) a ray would have in the image. +If this weight is less than the specified minimum and the +.I -lr +setting (above) is positive, the ray is not traced. +Otherwise, Russian roulette is used to +continue rays with a probability equal to the ray weight +divided by the given +.I frac. .TP .BI -S \ seqstart Instead of generating a single picture based only on the view @@ -732,7 +783,7 @@ Set the time between progress reports to A progress report writes the number of rays traced, the percentage completed, and the CPU usage to the standard error. Reports are given either automatically after the specified interval, -or when the process receives a continue (-CONT) signal (see +or when the process receives a continue (\-CONT) signal (see .I kill(1)). A value of zero turns automatic reporting off. .TP @@ -746,13 +797,13 @@ Boolean switch for warning messages. The default is to print warnings, so the first appearance of this option turns them off. .SH EXAMPLE -rpict -vp 10 5 3 -vd 1 -.5 0 scene.oct > scene.pic +rpict \-vp 10 5 3 \-vd 1 \-.5 0 scene.oct > scene.hdr .PP -rpict -S 1 -o frame%02d.pic scene.oct < keyframes.vf +rpict \-S 1 \-o frame%02d.hdr scene.oct < keyframes.vf .SH ENVIRONMENT RAYPATH the directories to check for auxiliary files. .SH FILES -/usr/tmp/rtXXXXXX common header information for picture sequence +/tmp/rtXXXXXX common header information for picture sequence .br rfXXXXXX temporary name for recover file .SH DIAGNOSTICS @@ -768,5 +819,5 @@ option. .SH AUTHOR Greg Ward .SH "SEE ALSO" -getinfo(1), lookamb(1), oconv(1), pfilt(1), pinterp(1), pmblur(1), +getinfo(1), lookamb(1), oconv(1), pdfblur(1), pfilt(1), pinterp(1), pmblur(1), printf(3), ra_rgbe(1), rad(1), rtrace(1), rvu(1)
