--- ray/doc/man/man1/rpict.1 2008/03/11 02:21:45 1.12 +++ ray/doc/man/man1/rpict.1 2010/10/08 22:08:26 1.15 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: rpict.1,v 1.12 2008/03/11 02:21:45 greg Exp $" +.\" RCSid "$Id: rpict.1,v 1.15 2010/10/08 22:08:26 greg Exp $" .TH RPICT 1 2/26/99 RADIANCE .SH NAME rpict - generate a RADIANCE picture @@ -335,13 +335,13 @@ This option may be desirable in conjunction with the .I \-i option so that light sources do not appear in the output. .TP -.BI -sj \ frac -Set the specular sampling jitter to -.I frac. -This is the degree to which the highlights are sampled -for rough specular materials. -A value of one means that all highlights will be fully sampled -using distributed ray tracing. +.BI -ss \ samp +Set the specular sampling to +.I samp. +For values less than 1, this is the degree to which the highlights +are sampled for rough specular materials. +A value greater than one causes multiple ray samples to be sent +to reduce noise at a commmesurate cost. A value of zero means that no jittering will take place, and all reflections will appear sharp even when they should be diffuse. This may be desirable when used in combination with image sampling @@ -571,7 +571,8 @@ When "on", pure Monte Carlo sampling is used in all ca .TP .BI -lr \ N Limit reflections to a maximum of -.I N. +.I N, +if N is a positive integer. If .I N is zero, then Russian roulette is used for ray @@ -579,7 +580,7 @@ termination, and the .I -lw setting (below) must be positive. If N is a negative integer, then this sets the upper limit -of reflections past which Russian roulette will not be used. +of reflections past which Russian roulette will be used. In scenes with dielectrics and total internal reflection, a setting of 0 (no limit) may cause a stack overflow. .TP @@ -796,9 +797,9 @@ Boolean switch for warning messages. The default is to print warnings, so the first appearance of this option turns them off. .SH EXAMPLE -rpict \-vp 10 5 3 \-vd 1 \-.5 0 scene.oct > scene.pic +rpict \-vp 10 5 3 \-vd 1 \-.5 0 scene.oct > scene.hdr .PP -rpict \-S 1 \-o frame%02d.pic scene.oct < keyframes.vf +rpict \-S 1 \-o frame%02d.hdr scene.oct < keyframes.vf .SH ENVIRONMENT RAYPATH the directories to check for auxiliary files. .SH FILES
