root/radiance/ray/doc/man/man1/rpict.1
Revision: 1.28
Committed: Wed Oct 19 21:25:20 2022 UTC (2 years, 8 months ago) by greg
Changes since 1.27: +18 -1 lines
1 .\" RCSid "$Id: rpict.1,v 1.27 2022/10/19 18:23:14 greg Exp $"
2 .TH RPICT 1 2/26/99 RADIANCE
3 .SH NAME
4 rpict - generate a RADIANCE picture
5 .SH SYNOPSIS
6 .B rpict
7 [
8 .B options
9 ]
10 [
11 .B $EVAR
12 ]
13 [
14 .B @file
15 ]
16 [
17 .B octree
18 ]
19 .br
20 .B "rpict [ options ] \-defaults"
21 .br
22 .B "rpict \-features [feat1 ..]"
23 .SH DESCRIPTION
24 .I Rpict
25 generates a picture from the RADIANCE scene given in
26 .I octree
27 and sends it to the standard output.
28 If no
29 .I octree
30 is given, the standard input is read.
31 (The octree may also be specified as the output of a command
32 enclosed in quotes and preceded by a `!'.)\0
33 Options specify the viewing parameters as well as
34 giving some control over the calculation.
35 Options may be given on the command line and/or read from the
36 environment and/or read from a file.
37 A command argument beginning with a dollar sign ('$') is immediately
38 replaced by the contents of the given environment variable.
39 A command argument beginning with an at sign ('@') is immediately
40 replaced by the contents of the given file.
41 .PP
42 In the second form shown above, the default values
43 for the options (modified by those options present)
44 are printed with a brief explanation.
45 .PP
46 In the third form, a list of supported features is sent
47 to the standard output, one per line.
48 If additional arguments follow, they are checked for presence in
49 this list.
50 If a feature includes subfeatures, these may be checked as well by
51 specifying:
52 .nf
53
54 rpict -features FeatName=subfeat1,subfeat2
55
56 .fi
57 If any named feature or subfeature is missing, an error is
58 reported and the program returns an error status.
59 If all of the named features are present, a zero status is returned.
60 .PP
61 Most options are followed by one or more arguments, which must be
62 separated from the option and each other by white space.
63 The exceptions to this rule are the
64 .I \-vt
65 option and the boolean options.
66 Normally, the appearance of a boolean option causes a feature to
67 be "toggled", that is switched from off to on or on to off
68 depending on its previous state.
69 Boolean options may also be set
70 explicitly by following them immediately with a '+' or '-', meaning
71 on or off, respectively.
72 Synonyms for '+' are any of the characters "yYtT1", and synonyms
73 for '-' are any of the characters "nNfF0".
74 All other characters will generate an error.
75 .TP 10n
76 .BI -vt t
77 Set view type to
78 .I t.
79 If
80 .I t
81 is 'v', a perspective view is selected.
82 If
83 .I t
84 is 'l', a parallel view is used.
85 A cylindrical panorma may be selected by setting
86 .I t
87 to the letter 'c'.
88 This view is like a standard perspective vertically, but projected
89 on a cylinder horizontally (like a soupcan's-eye view).
90 Three fisheye views are provided as well; 'h' yields a hemispherical fisheye
91 view, 'a' results in angular fisheye distortion, and 's'
92 results in a planisphere (stereographic) projection.
93 A hemispherical fisheye is a projection of the hemisphere onto a circle.
94 The maximum view angle for this type is 180 degrees.
95 An angular fisheye view is defined such that distance from the center of
96 the image is proportional to the angle from the central view direction.
97 An angular fisheye can display a full 360 degrees.
98 A planisphere fisheye view maintains angular relationships between lines,
99 and is commonly used for sun path analysis.
100 This is more commonly known as a
101 "stereographic projection," but we avoid the term here so as not to
102 confuse it with a stereoscopic pair.
103 A planisphere fisheye can display up to (but not including) 360 degrees,
104 although distortion becomes extreme as this limit is approached.
105 Note that there is no space between the view type
106 option and its single letter argument.
107 .TP
108 .BI -vp " x y z"
109 Set the view point to
110 .I "x y z".
111 This is the focal point of a perspective view or the
112 center of a parallel projection.
113 .TP
114 .BI -vd " xd yd zd"
115 Set the view direction vector to
116 .I "xd yd zd".
117 The length of this vector indicates the focal distance as needed by the
118 .I \-pd
119 option, described below.
120 .TP
121 .BI -vu " xd yd zd"
122 Set the view up vector (vertical direction) to
123 .I "xd yd zd".
124 .TP
125 .BI -vh \ val
126 Set the view horizontal size to
127 .I val.
128 For a perspective projection (including fisheye views),
129 .I val
130 is the horizontal field of view (in degrees).
131 For a parallel projection,
132 .I val
133 is the view width in world coordinates.
134 .TP
135 .BI -vv \ val
136 Set the view vertical size to
137 .I val.
138 .TP
139 .BI -vo \ val
140 Set the view fore clipping plane at a distance of
141 .I val
142 from the view point.
143 The plane will be perpendicular to the view direction for
144 perspective and parallel view types.
145 For fisheye view types, the clipping plane is actually a clipping
146 sphere, centered on the view point with radius
147 .I val.
148 Objects in front of this imaginary surface will not be visible.
149 This may be useful for seeing through walls (to get a longer
150 perspective from an exterior view point) or for incremental
151 rendering.
152 A value of zero implies no foreground clipping.
153 A negative value produces some interesting effects, since it creates an
154 inverted image for objects behind the viewpoint.
155 This possibility is provided mostly for the purpose of rendering
156 stereographic holograms.
157 .TP
158 .BI -va \ val
159 Set the view aft clipping plane at a distance of
160 .I val
161 from the view point.
162 Like the view fore plane, it will be perpendicular to the view
163 direction for perspective and parallel view types.
164 For fisheye view types, the clipping plane is actually a clipping
165 sphere, centered on the view point with radius
166 .I val.
167 Objects behind this imaginary surface will not be visible.
168 A value of zero means no aft clipping, and is the only way to see
169 infinitely distant objects such as the sky.
170 .TP
171 .BI -vs \ val
172 Set the view shift to
173 .I val.
174 This is the amount the actual image will be shifted to the right of
175 the specified view.
176 This is option is useful for generating skewed perspectives or
177 rendering an image a piece at a time.
178 A value of 1 means that the rendered image starts just to the right of
179 the normal view.
180 A value of \-1 would be to the left.
181 Larger or fractional values are permitted as well.
182 .TP
183 .BI -vl \ val
184 Set the view lift to
185 .I val.
186 This is the amount the actual image will be lifted up from the
187 specified view, similar to the
188 .I \-vs
189 option.
190 .TP
191 .BI -vf \ file
192 Get view parameters from
193 .I file,
194 which may be a picture or a file created by rvu (with the "view" command).
195 .TP
196 .BI -x \ res
197 Set the maximum x resolution to
198 .I res.
199 .TP
200 .BI -y \ res
201 Set the maximum y resolution to
202 .I res.
203 .TP
204 .BI -pa \ rat
205 Set the pixel aspect ratio (height over width) to
206 .I rat.
207 Either the x or the y resolution will be reduced so that the pixels have
208 this ratio for the specified view.
209 If
210 .I rat
211 is zero, then the x and y resolutions will adhere to the given maxima.
212 .TP
213 .BI -ps \ size
214 Set the pixel sample spacing to the integer
215 .I size.
216 This specifies the sample spacing (in pixels) for adaptive subdivision
217 on the image plane.
218 .TP
219 .BI -pt \ frac
220 Set the pixel sample tolerance to
221 .I frac.
222 If two samples differ by more than this amount, a third
223 sample is taken between them.
224 .TP
225 .BI -pj \ frac
226 Set the pixel sample jitter to
227 .I frac.
228 Distributed ray-tracing performs anti-aliasing by randomly sampling
229 over pixels.
230 A value of one will randomly distribute samples over full
231 pixels, and is not really recommended due to the tendency of
232 samples to (nearly) coincide.
233 A value of zero samples pixel centers only.
234 A value around 0.5-0.8 is typical.
235 .TP
236 .BI -pm \ frac
237 Set the pixel motion blur to
238 .I frac.
239 In an animated sequence, the exact view will be blurred between the previous
240 view and the next view as though a shutter were open this fraction of a
241 frame time.
242 (See the
243 .I \-S
244 option regarding animated sequences.)\0
245 The first view will be blurred according to the difference between the
246 initial view set on the command line and the first view taken from the
247 standard input.
248 It is not advisable to use this option in combination with the
249 .I pmblur(1)
250 program, since one takes the place of the other.
251 However, it may improve results with
252 .I pmblur
253 to use a very small fraction with the
254 .I \-pm
255 option, to avoid the ghosting effect of too few time samples.
256 .TP
257 .BI -pd \ dia
258 Set the pixel depth-of-field aperture to a diameter of
259 .I dia
260 (in world coordinates).
261 This will be used in conjunction with the view focal distance, indicated
262 by the length of the view direction vector given in the
263 .I \-vd
264 option.
265 It is not advisable to use this option in combination with the
266 .I pdfblur(1)
267 program, since one takes the place of the other.
268 However, it may improve results with
269 .I pdfblur
270 to use a very small fraction with the
271 .I \-pd
272 option, to avoid the ghosting effect of too few samples.
273 .TP
274 .BI -dj \ frac
275 Set the direct jittering to
276 .I frac.
277 A value of zero samples each source at specific sample points
278 (see the
279 .I \-ds
280 option below), giving a smoother but somewhat less accurate
281 rendering.
282 A positive value causes rays to be distributed over each
283 source sample according to its size, resulting in more accurate
284 penumbras.
285 This option should never be greater than 1, and may even
286 cause problems (such as speckle) when the value is smaller.
287 A warning about aiming failure will issued if
288 .I frac
289 is too large.
290 It is usually wise to turn off image sampling when using
291 direct jitter by setting \-ps to 1.
292 .TP
293 .BI -ds \ frac
294 Set the direct sampling ratio to
295 .I frac.
296 A light source will be subdivided until
297 the width of each sample area divided by the distance
298 to the illuminated point is below this ratio.
299 This assures accuracy in regions close to large area sources
300 at a slight computational expense.
301 A value of zero turns source subdivision off, sending at most one
302 shadow ray to each light source.
303 .TP
304 .BI -dt \ frac
305 Set the direct threshold to
306 .I frac.
307 Shadow testing will stop when the potential contribution of at least
308 the next and at most all remaining light source samples is less than
309 this fraction of the accumulated value.
310 (See the
311 .I \-dc
312 option below.)\0
313 The remaining light source contributions are approximated
314 statistically.
315 A value of zero means that all light source samples will be tested for shadow.
316 .TP
317 .BI \-dc \ frac
318 Set the direct certainty to
319 .I frac.
320 A value of one guarantees that the absolute accuracy of the direct calculation
321 will be equal to or better than that given in the
322 .I \-dt
323 specification.
324 A value of zero only insures that all shadow lines resulting in a contrast
325 change greater than the
326 .I \-dt
327 specification will be calculated.
328 .TP
329 .BI -dr \ N
330 Set the number of relays for virtual sources to
331 .I N.
332 A value of 0 means that virtual sources will be ignored.
333 A value of 1 means that sources will be made into first generation
334 virtual sources; a value of 2 means that first generation
335 virtual sources will also be made into second generation virtual
336 sources, and so on.
337 .TP
338 .BI -dp \ D
339 Set the virtual source presampling density to D.
340 This is the number of samples per steradian
341 that will be used to determine ahead of time whether or not
342 it is worth following shadow rays through all the reflections and/or
343 transmissions associated with a virtual source path.
344 A value of 0 means that the full virtual source path will always
345 be tested for shadows if it is tested at all.
346 .TP
347 .BR \-dv
348 Boolean switch for light source visibility.
349 With this switch off, sources will be black when viewed directly
350 although they will still participate in the direct calculation.
351 This option may be desirable in conjunction with the
352 .I \-i
353 option so that light sources do not appear in the output.
354 .TP
355 .BI -ss \ samp
356 Set the specular sampling to
357 .I samp.
358 For values less than 1, this is the degree to which the highlights
359 are sampled for rough specular materials.
360 A value greater than one causes multiple ray samples to be sent
361 to reduce noise at a commmesurate cost.
362 A value of zero means that no jittering will take place, and all
363 reflections will appear sharp even when they should be diffuse.
364 This may be desirable when used in combination with image sampling
365 (see
366 .I \-ps
367 option above) to obtain faster renderings.
368 .TP
369 .BI -st \ frac
370 Set the specular sampling threshold to
371 .I frac.
372 This is the minimum fraction of reflection or transmission, under which
373 no specular sampling is performed.
374 A value of zero means that highlights will always be sampled by
375 tracing reflected or transmitted rays.
376 A value of one means that specular sampling is never used.
377 Highlights from light sources will always be correct, but
378 reflections from other surfaces will be approximated using an
379 ambient value.
380 A sampling threshold between zero and one offers a compromise between image
381 accuracy and rendering time.
382 .TP
383 .BR -bv
384 Boolean switch for back face visibility.
385 With this switch off, back faces of all objects will be invisible
386 to view rays.
387 This is dangerous unless the model was constructed such that
388 all surface normals face outward.
389 Although turning off back face visibility does not save much
390 computation time under most circumstances, it may be useful as a
391 tool for scene debugging, or for seeing through one-sided walls from
392 the outside.
393 .TP
394 .BI -av " red grn blu"
395 Set the ambient value to a radiance of
396 .I "red grn blu".
397 This is the final value used in place of an
398 indirect light calculation.
399 If the number of ambient bounces is one or greater and the ambient
400 value weight is non-zero (see
401 .I -aw
402 and
403 .I -ab
404 below), this value may be modified by the computed indirect values
405 to improve overall accuracy.
406 .TP
407 .BI -aw \ N
408 Set the relative weight of the ambient value given with the
409 .I -av
410 option to
411 .I N.
412 As new indirect irradiances are computed, they will modify the
413 default ambient value in a moving average, with the specified weight
414 assigned to the initial value given on the command and all other
415 weights set to 1.
416 If a value of 0 is given with this option, then the initial ambient
417 value is never modified.
418 This is the safest value for scenes with large differences in
419 indirect contributions, such as when both indoor and outdoor
420 (daylight) areas are visible.
421 .TP
422 .BI -ab \ N
423 Set the number of ambient bounces to
424 .I N.
425 This is the maximum number of diffuse bounces computed by the indirect
426 calculation. A value of zero implies no indirect calculation.
427 .IP
428 This value defaults to 1 in photon mapping mode (see
429 .I -ap
430 below), implying that global photon irradiance is always computed via
431 .I one
432 ambient bounce; this behaviour applies to any positive number of ambient
433 bounces, regardless of the actual value specified. A negative value enables
434 a preview mode that directly visualises the irradiance from the global
435 photon map without any ambient bounces.
436 .TP
437 .BI -ar \ res
438 Set the ambient resolution to
439 .I res.
440 This number will determine the maximum density of ambient values
441 used in interpolation.
442 Error will start to increase on surfaces spaced closer than
443 the scene size divided by the ambient resolution.
444 The maximum ambient value density is the scene size times the
445 ambient accuracy (see the
446 .I \-aa
447 option below) divided by the ambient resolution.
448 The scene size can be determined using
449 .I getinfo(1)
450 with the
451 .I \-d
452 option on the input octree.
453 A value of zero is interpreted as unlimited resolution.
454 .TP
455 .BI -aa \ acc
456 Set the ambient accuracy to
457 .I acc.
458 This value will approximately equal the error
459 from indirect irradiance interpolation.
460 A value of zero implies no interpolation.
461 .TP
462 .BI -ad \ N
463 Set the number of ambient divisions to
464 .I N.
465 The error in the Monte Carlo calculation of indirect
466 irradiance will be inversely proportional to the square
467 root of this number.
468 A value of zero implies no indirect calculation.
469 .TP
470 .BI -as \ N
471 Set the number of ambient super-samples to
472 .I N.
473 Super-samples are applied only to the ambient divisions which
474 show a significant change.
475 .TP
476 .BI -af \ fname
477 Set the ambient file to
478 .I fname.
479 This is where indirect irradiance will be stored and retrieved.
480 Normally, indirect irradiance values are kept in memory and
481 lost when the program finishes or dies.
482 By using a file, different invocations can share irradiance
483 values, saving time in the computation.
484 Also, by creating an ambient file during a low-resolution rendering,
485 better results can be obtained in a second high-resolution pass.
486 (It is a good idea to keep all of the calculation parameters the same,
487 changing only the dimensions of the output picture.)\0
488 The ambient file is in a machine-independent binary format
489 which may be examined with
490 .I lookamb(1).
491 .IP
492 The ambient file may also be used as a means of communication and
493 data sharing between simultaneously executing processes.
494 The same file may be used by multiple processes, possibly running on
495 different machines and accessing the file via the network (ie.
496 .I nfs(4)).
497 The network lock manager
498 .I lockd(8)
499 is used to insure that this information is used consistently.
500 .IP
501 If any calculation parameters are changed or the scene
502 is modified, the old ambient file should be removed so that
503 the calculation can start over from scratch.
504 For convenience, the original ambient parameters are listed in the
505 header of the ambient file.
506 .I Getinfo(1)
507 may be used to print out this information.
508 .TP
509 .BI -ae \ mod
510 Append
511 .I mod
512 to the ambient exclude list,
513 so that it will not be considered during the indirect calculation.
514 This is a hack for speeding the indirect computation by
515 ignoring certain objects.
516 Any object having
517 .I mod
518 as its modifier will get the default ambient
519 level rather than a calculated value.
520 Any number of excluded modifiers may be given, but each
521 must appear in a separate option.
522 .TP
523 .BI -ai \ mod
524 Add
525 .I mod
526 to the ambient include list,
527 so that it will be considered during the indirect calculation.
528 The program can use either an include list or an exclude
529 list, but not both.
530 .TP
531 .BI -aE \ file
532 Same as
533 .I \-ae,
534 except read modifiers to be excluded from
535 .I file.
536 The RAYPATH environment variable determines which directories are
537 searched for this file.
538 The modifier names are separated by white space in the file.
539 .TP
540 .BI -aI \ file
541 Same as
542 .I \-ai,
543 except read modifiers to be included from
544 .I file.
545 .TP
546 .BI -ap " file [bwidth1 [bwidth2]]"
547 Enable photon mapping mode. Loads a photon map generated with
548 .I mkpmap(1)
549 from
550 .I file,
551 and evaluates the indirect irradiance depending on the photon type
552 (automagically detected) using density estimates with a bandwidth of
553 .I bwidth1
554 photons, or the default bandwidth if none is specified (a warning will be
555 issued in this case).
556 .IP
557 Global photon irradiance is evaluated as part of the ambient calculation (see
558 .I \-ab
559 above), caustic photon irradiance is evaluated at primary rays, and
560 indirect inscattering in
561 .I mist
562 is accounted for by volume photons. Contribution photons are treated as
563 global photons by
564 .I rpict.
565 .IP
566 Additionally specifying
567 .I bwidth2
568 enables bias compensation for the density estimates with a
569 minimum and maximum bandwidth of
570 .I bwidth1
571 and
572 .I bwidth2,
573 respectively.
574 .IP
575 Global photon irradiance may be optionally precomputed by
576 .I mkpmap(1),
577 in which case the bandwidth, if specified, is ignored, as the nearest photon
578 is invariably looked up.
579 .IP
580 Using direct photons replaces the direct calculation with density estimates
581 for debugging and validation of photon emission.
582 .TP
583 .BI -am " frac"
584 Maximum search radius for photon map lookups. Without this option, an
585 initial maximum search radius is estimated for each photon map from the
586 average photon distance to the distribution's centre of gravity. It is then
587 adapted to the photon density in subsequent lookups. This option imposes a
588 global fixed maximum search radius for
589 .I all
590 photon maps, thus defeating the automatic adaptation. It is useful when
591 multiple warnings about short photon lookups are issued. Note that this
592 option does not conflict with the bandwidth specified with the
593 .I \-ap
594 option; the number of photons found will not exceed the latter, but may be
595 lower if the maximum search radius contains fewer photons, thus resulting in
596 short lookups. Setting this radius too large, on the other hand, may
597 degrade performance.
598 .TP
599 .BI -ac " pagesize"
600 Set the photon cache page size when using out-of-core photon mapping. The
601 photon cache reduces disk I/O incurred by on-demand loading (paging) of
602 photons, and thus increases performance. This
603 is expressed as a (float) multiple of the density estimate bandwidth
604 specified with
605 .I \-ap
606 under the assumption that photon lookups are local to a cache page. Cache
607 performance is sensitive to this parameter: larger pagesizes will reduce the
608 paging frequency at the expense of higher latency when paging does occur.
609 Sensible values are in the range 4 (default) to 16.
610 .TP
611 .BI -aC " cachesize"
612 Set the total number of photons cached when using out-of-core photon
613 mapping, taking into account the pagesize specified by
614 .I \-ac.
615 Note that this is approximate as the number of cache pages is rounded to
616 the nearest prime. This allows adapting the cache to the available physical
617 memory. Cache performance is less sensitive to this parameter, and reasonable
618 performance can obtained with as few as 10k photons. The default is 1M. This
619 option recognises multiplier suffixes (k = 1e3, M = 1e6), both in upper and
620 lower case.
621 .TP
622 .BI -me " rext gext bext"
623 Set the global medium extinction coefficient to the indicated color,
624 in units of 1/distance (distance in world coordinates).
625 Light will be scattered or absorbed over distance according to
626 this value.
627 The ratio of scattering to total scattering plus absorption is set
628 by the albedo parameter, described below.
629 .TP
630 .BI -ma " ralb galb balb"
631 Set the global medium albedo to the given value between 0\00\00
632 and 1\01\01.
633 A zero value means that all light not transmitted by the medium
634 is absorbed.
635 A unitary value means that all light not transmitted by the medium
636 is scattered in some new direction.
637 The isotropy of scattering is determined by the Heyney-Greenstein
638 parameter, described below.
639 .TP
640 .BI \-mg \ gecc
641 Set the medium Heyney-Greenstein eccentricity parameter to
642 .I gecc.
643 This parameter determines how strongly scattering favors the forward
644 direction.
645 A value of 0 indicates perfectly isotropic scattering.
646 As this parameter approaches 1, scattering tends to prefer the
647 forward direction.
648 .TP
649 .BI \-ms \ sampdist
650 Set the medium sampling distance to
651 .I sampdist,
652 in world coordinate units.
653 During source scattering, this will be the average distance between
654 adjacent samples.
655 A value of 0 means that only one sample will be taken per light
656 source within a given scattering volume.
657 .TP
658 .BR \-i
659 Boolean switch to compute irradiance rather than radiance values.
660 This only affects the final result, substituting a Lambertian
661 surface and multiplying the radiance by pi.
662 Glass and other transparent surfaces are ignored during this stage.
663 Light sources still appear with their original radiance values,
664 though the
665 .I \-dv
666 option (above) may be used to override this.
667 .TP
668 .BR \-u
669 Boolean switch to control uncorrelated random sampling.
670 When "off", a low-discrepancy sequence is used, which reduces
671 variance but can result in a dithered appearance in specular highlights.
672 When "on", pure Monte Carlo sampling is used in all calculations.
673 .TP
674 .BI -lr \ N
675 Limit reflections to a maximum of
676 .I N,
677 if N is a positive integer.
678 If
679 .I N
680 is zero, then Russian roulette is used for ray
681 termination, and the
682 .I -lw
683 setting (below) must be positive.
684 If N is a negative integer, then this limits the maximum
685 number of reflections even with Russian roulette.
686 In scenes with dielectrics and total internal reflection,
687 a setting of 0 (no limit) may cause a stack overflow.
688 .TP
689 .BI -lw \ frac
690 Limit the weight of each ray to a minimum of
691 .I frac.
692 During ray-tracing, a record is kept of the estimated contribution
693 (weight) a ray would have in the image.
694 If this weight is less than the specified minimum and the
695 .I -lr
696 setting (above) is positive, the ray is not traced.
697 Otherwise, Russian roulette is used to
698 continue rays with a probability equal to the ray weight
699 divided by the given
700 .I frac.
701 .TP
702 .BI -S \ seqstart
703 Instead of generating a single picture based only on the view
704 parameters given on the command line, this option causes
705 .I rpict
706 to read view options from the standard input and for each line
707 containing a valid view specification, generate a corresponding
708 picture.
709 This option is most useful for generating animated sequences, though
710 it may also be used to control rpict from a remote process for
711 network-distributed rendering.
712 .I Seqstart
713 is a positive integer that will be associated with the first output
714 frame, and incremented for successive output frames.
715 By default, each frame is concatenated to the output stream, but it
716 is possible to change this action using the
717 .I \-o
718 option (described below).
719 Multiple frames may be later extracted from the output using
720 .I ra_rgbe(1).
721 .IP
722 Note that the octree may not be read from the standard input when
723 using this option.
724 .TP
725 .BI -o \ fspec
726 Send the picture(s) to the file(s) given by
727 .I fspec
728 instead of the standard output.
729 If this option is used in combination with
730 .I \-S
731 and
732 .I fspec
733 contains an integer field for
734 .I printf(3)
735 (eg. "%03d") then the actual output file name will include
736 the current frame number.
737 .I Rpict
738 will not allow a picture file to be clobbered (overwritten)
739 with this option.
740 If an image in a sequence already exists
741 .I (\-S
742 option),
743 .I rpict
744 will skip until it reaches an image that doesn't, or the end of
745 the sequence.
746 This is useful for running rpict on multiple machines or processors
747 to render the same sequence, as each process will skip to the next
748 frame that needs rendering.
749 .TP
750 .BI -r \ fn
751 Recover pixel information from the file
752 .I fn.
753 If the program gets killed during picture generation, the information
754 may be recovered using this option.
755 The view parameters and picture dimensions are also recovered from
756 .I fn
757 if possible.
758 The other options should be identical to those which created
759 .I fn,
760 or an inconsistent picture may result.
761 If
762 .I fn
763 is identical to the file specification given with the
764 .I \-o
765 option,
766 .I rpict
767 will rename the file prior to copying its contents.
768 This insures that the old file is not overwritten accidentally.
769 (See also the
770 .I \-ro
771 option, below.)\0
772 .IP
773 If
774 .I fn
775 is an integer and the recover option is used in combination with the
776 .I \-S
777 option, then
778 .I rpict
779 skips a number of view specifications on its input equal to the
780 difference between
781 .I fn
782 and
783 .I seqstart.
784 .I Rpict
785 then performs a recovery operation on the file constructed from the
786 frame number
787 .I fn
788 and the output file specification given with the
789 .I \-o
790 option.
791 This provides a convenient mechanism for recovering in the middle of
792 an aborted picture sequence.
793 .IP
794 The recovered file
795 will be removed if the operation is successful.
796 If the recover operation fails (due to lack of disk space)
797 and the output file and recover file specifications
798 are the same, then the original information may be left in a
799 renamed temporary file.
800 (See FILES section, below.)\0
801 .TP
802 .BI -ro \ fspec
803 This option causes pixel information to be recovered from and
804 subsequently returned to the picture file
805 .I fspec.
806 The effect is the same as specifying identical recover and output
807 file names with the
808 .I \-r
809 and
810 .I \-o
811 options.
812 .TP
813 .BI -z \ fspec
814 Write pixel distances out to the file
815 .I fspec.
816 The values are written as short floats, one per pixel in scanline order,
817 as required by
818 .I pinterp(1).
819 Similar to the
820 .I \-o
821 option, the actual file name will be constructed using
822 .I printf
823 and the frame number from the
824 .I \-S
825 option.
826 If used with the
827 .I \-r
828 option,
829 .I \-z
830 also recovers information from an aborted rendering.
831 .TP
832 .BI \-P \ pfile
833 Execute in a persistent mode, using
834 .I pfile
835 as the control file.
836 This option must be used together with
837 .I \-S,
838 and is incompatible with the recover option
839 .I (\-r).
840 Persistent execution means that after reaching end-of-file on
841 its input,
842 .I rpict
843 will fork a child process that will wait for another
844 .I rpict
845 command with the same
846 .I \-P
847 option to attach to it.
848 (Note that since the rest of the command line options will be those
849 of the original invocation, it is not necessary to give any arguments
850 besides
851 .I \-P
852 for subsequent calls.)
853 Killing the process is achieved with the
854 .I kill(1)
855 command.
856 (The process ID in the first line of
857 .I pfile
858 may be used to identify the waiting
859 .I rpict
860 process.)
861 This option may be less useful than the
862 .I \-PP
863 variation, explained below.
864 .TP
865 .BI \-PP \ pfile
866 Execute in continuous-forking persistent mode, using
867 .I pfile
868 as the control file.
869 The difference between this option and the
870 .I \-P
871 option described above is the creation of multiple duplicate
872 processes to handle any number of attaches.
873 This provides a simple and reliable mechanism of memory sharing
874 on most multiprocessing platforms, since the
875 .I fork(2)
876 system call will share memory on a copy-on-write basis.
877 This option may be used with
878 .I rpiece(1)
879 to efficiently render a single image using multiple processors
880 on the same host.
881 .TP
882 .BI -t \ sec
883 Set the time between progress reports to
884 .I sec.
885 A progress report writes the number of rays traced, the percentage
886 completed, and the CPU usage to the standard error.
887 Reports are given either automatically after the specified interval,
888 or when the process receives a continue (\-CONT) signal (see
889 .I kill(1)).
890 A value of zero turns automatic reporting off.
891 .TP
892 .BI -e \ efile
893 Send error messages and progress reports to
894 .I efile
895 instead of the standard error.
896 .TP
897 .BR \-w
898 Boolean switch for warning messages.
899 The default is to print warnings, so the first appearance of
900 this option turns them off.
901 .SH EXAMPLE
902 rpict \-vp 10 5 3 \-vd 1 \-.5 0 scene.oct > scene.hdr
903 .PP
904 rpict \-S 1 \-o frame%02d.hdr scene.oct < keyframes.vf
905 .PP
906 To render ambient irradiance in photon mapping mode from a global photon
907 map global.pm via one ambient bounce, and from a caustic photon map
908 caustic.pm:
909 .IP "" .2i
910 rpict -ab 1 -ap global.pm 50 -ap caustic.pm 50 -vf scene.vf scene.oct >
911 scene.hdr
912 .SH ENVIRONMENT
913 RAYPATH the directories to check for auxiliary files.
914 .SH FILES
915 /tmp/rtXXXXXX common header information for picture sequence
916 .br
917 rfXXXXXX temporary name for recover file
918 .SH DIAGNOSTICS
919 If the program terminates from an input related error, the exit status
920 will be 1.
921 A system related error results in an exit status of 2.
922 If the program receives a signal that is caught, it will exit with a status
923 of 3.
924 In each case, an error message will be printed to the standard error, or
925 to the file designated by the
926 .I \-e
927 option.
928 .SH AUTHOR
929 Greg Ward
930 .SH "SEE ALSO"
931 getinfo(1), lookamb(1), mkpmap(1), oconv(1), pdfblur(1), pfilt(1),
932 pinterp(1), pmblur(1), printf(3), ra_rgbe(1), rad(1), rpiece(1), rtpict(1), rtrace(1), rvu(1)
