root/radiance/ray/doc/man/man1/rpict.1
Tue Feb 18 12:13:38 2014 UTC (10 years, 4 months ago) by greg
Diff to previous 1.16 , to selected 1.9
Sat Jan 25 18:27:39 2014 UTC (10 years, 4 months ago) by greg
Changes since 1.15: +4 -5 lines
Diff to previous 1.15 , to selected 1.9
Fri Oct 8 22:08:26 2010 UTC (13 years, 8 months ago) by greg
Changes since 1.14: +8 -8 lines
Diff to previous 1.14 , to selected 1.9
Tue Jan 26 04:42:16 2010 UTC (14 years, 4 months ago) by greg
Changes since 1.13: +4 -3 lines
Diff to previous 1.13 , to selected 1.9
Corrected description of -lr option.
Mon Nov 10 19:08:17 2008 UTC (15 years, 7 months ago) by greg
Diff to previous 1.12 , to selected 1.9
Tue Mar 11 02:21:45 2008 UTC (16 years, 3 months ago) by greg
Changes since 1.11: +11 -3 lines
Diff to previous 1.11 , to selected 1.9
Tue Sep 4 17:36:41 2007 UTC (16 years, 9 months ago) by greg
Changes since 1.10: +6 -6 lines
Diff to previous 1.10 , to selected 1.9
Added backslashes in front of hyphens (thanks to Bernd Zeimetz for his effort)
Tue Jun 14 03:34:14 2005 UTC (19 years ago) by greg
Diff to previous 1.9
Had to change new -R rendering option to -u to avoid conflict with rpiece
Revision 1.9 - (view) (download) (annotate) - [selected]
Mon Jun 13 20:07:55 2005 UTC (19 years ago) by greg
Changes since 1.8: +7 -1 lines
Diff to previous 1.8
Tue May 31 18:01:08 2005 UTC (19 years ago) by greg
Changes since 1.7: +20 -4 lines
Diff to previous 1.7 , to selected 1.9
Thu Apr 14 18:04:12 2005 UTC (19 years, 2 months ago) by greg
Changes since 1.6: +10 -10 lines
Diff to previous 1.6 , to selected 1.9
Wed Feb 16 05:40:06 2005 UTC (19 years, 4 months ago) by greg
Diff to previous 1.5 , to selected 1.9
Tue Jan 18 01:13:23 2005 UTC (19 years, 5 months ago) by greg
Changes since 1.4: +4 -1 lines
Diff to previous 1.4 , to selected 1.9
Added comment about -vd length being used by -pd option
Tue Jan 18 00:33:15 2005 UTC (19 years, 5 months ago) by greg
Changes since 1.3: +19 -2 lines
Diff to previous 1.3 , to selected 1.9
Thu Jan 1 19:31:45 2004 UTC (20 years, 5 months ago) by greg
Diff to previous 1.2 , to selected 1.9
Tue Dec 9 15:59:07 2003 UTC (20 years, 6 months ago) by greg
Diff to previous 1.1 , to selected 1.9
Fixed RCSid specification
Tue Mar 11 19:20:21 2003 UTC (21 years, 3 months ago) by greg
Diff to selected 1.9
Added documentation to repository
