root/radiance/ray/doc/man/man1/rpict.1
Revision: 1.10
Committed: Tue Jun 14 03:34:14 2005 UTC (18 years, 11 months ago) by greg
CVS Tags: rad3R7P2, rad3R7P1, rad3R8
Had to change new -R rendering option to -u to avoid conflict with rpiece
# User Rev Content
1 greg 1.10 .\" RCSid "$Id: rpict.1,v 1.9 2005/06/13 20:07:55 greg Exp $"
2 greg 1.1 .TH RPICT 1 2/26/99 RADIANCE
3     .SH NAME
4     rpict - generate a RADIANCE picture
5     .SH SYNOPSIS
6     .B rpict
7     [
8     .B options
9     ]
10     [
11     .B $EVAR
12     ]
13     [
14     .B @file
15     ]
16     [
17     .B octree
18     ]
19     .br
20     .B "rpict [ options ] \-defaults"
21     .SH DESCRIPTION
22     .I Rpict
23     generates a picture from the RADIANCE scene given in
24     .I octree
25     and sends it to the standard output.
26     If no
27     .I octree
28     is given, the standard input is read.
29     (The octree may also be specified as the output of a command
30     enclosed in quotes and preceded by a `!'.)\0
31     Options specify the viewing parameters as well as
32     giving some control over the calculation.
33     Options may be given on the command line and/or read from the
34     environment and/or read from a file.
35     A command argument beginning with a dollar sign ('$') is immediately
36     replaced by the contents of the given environment variable.
37     A command argument beginning with an at sign ('@') is immediately
38     replaced by the contents of the given file.
39     .PP
40     In the second form shown above, the default values
41     for the options (modified by those options present)
42     are printed with a brief explanation.
43     .PP
44     Most options are followed by one or more arguments, which must be
45     separated from the option and each other by white space.
46     The exceptions to this rule are the
47     .I \-vt
48     option and the boolean options.
49     Normally, the appearance of a boolean option causes a feature to
50     be "toggled", that is switched from off to on or on to off
51     depending on its previous state.
52     Boolean options may also be set
53     explicitly by following them immediately with a '+' or '-', meaning
54     on or off, respectively.
55     Synonyms for '+' are any of the characters "yYtT1", and synonyms
56     for '-' are any of the characters "nNfF0".
57     All other characters will generate an error.
58     .TP 10n
59     .BI -vt t
60     Set view type to
61     .I t.
62     If
63     .I t
64     is 'v', a perspective view is selected.
65     If
66     .I t
67     is 'l', a parallel view is used.
68     A cylindrical panorma may be selected by setting
69     .I t
70     to the letter 'c'.
71     This view is like a standard perspective vertically, but projected
72     on a cylinder horizontally (like a soupcan's-eye view).
73     Two fisheye views are provided as well; 'h' yields a hemispherical fisheye
74     view and 'a' results in angular fisheye distortion.
75     A hemispherical fisheye is a projection of the hemisphere onto a circle.
76     The maximum view angle for this type is 180 degrees.
77     An angular fisheye view is defined such that distance from the center of
78     the image is proportional to the angle from the central view direction.
79     An angular fisheye can display a full 360 degrees.
80     Note that there is no space between the view type
81     option and its single letter argument.
82     .TP
83     .BI -vp " x y z"
84     Set the view point to
85     .I "x y z".
86     This is the focal point of a perspective view or the
87     center of a parallel projection.
88     .TP
89     .BI -vd " xd yd zd"
90     Set the view direction vector to
91     .I "xd yd zd".
92 greg 1.5 The length of this vector indicates the focal distance as needed by the
93     .I \-pd
94     option, described below.
95 greg 1.1 .TP
96     .BI -vu " xd yd zd"
97     Set the view up vector (vertical direction) to
98     .I "xd yd zd".
99     .TP
100     .BI -vh \ val
101     Set the view horizontal size to
102     .I val.
103     For a perspective projection (including fisheye views),
104     .I val
105     is the horizontal field of view (in degrees).
106     For a parallel projection,
107     .I val
108     is the view width in world coordinates.
109     .TP
110     .BI -vv \ val
111     Set the view vertical size to
112     .I val.
113     .TP
114     .BI -vo \ val
115     Set the view fore clipping plane at a distance of
116     .I val
117     from the view point.
118     The plane will be perpendicular to the view direction for
119     perspective and parallel view types.
120     For fisheye view types, the clipping plane is actually a clipping
121     sphere, centered on the view point with radius
122     .I val.
123     Objects in front of this imaginary surface will not be visible.
124     This may be useful for seeing through walls (to get a longer
125     perspective from an exterior view point) or for incremental
126     rendering.
127     A value of zero implies no foreground clipping.
128     A negative value produces some interesting effects, since it creates an
129     inverted image for objects behind the viewpoint.
130     This possibility is provided mostly for the purpose of rendering
131     stereographic holograms.
132     .TP
133     .BI -va \ val
134     Set the view aft clipping plane at a distance of
135     .I val
136     from the view point.
137     Like the view fore plane, it will be perpendicular to the view
138     direction for perspective and parallel view types.
139     For fisheye view types, the clipping plane is actually a clipping
140     sphere, centered on the view point with radius
141     .I val.
142     Objects behind this imaginary surface will not be visible.
143     A value of zero means no aft clipping, and is the only way to see
144     infinitely distant objects such as the sky.
145     .TP
146     .BI -vs \ val
147     Set the view shift to
148     .I val.
149     This is the amount the actual image will be shifted to the right of
150     the specified view.
151     This is option is useful for generating skewed perspectives or
152     rendering an image a piece at a time.
153     A value of 1 means that the rendered image starts just to the right of
154     the normal view.
155     A value of -1 would be to the left.
156     Larger or fractional values are permitted as well.
157     .TP
158     .BI -vl \ val
159     Set the view lift to
160     .I val.
161     This is the amount the actual image will be lifted up from the
162     specified view, similar to the
163     .I \-vs
164     option.
165     .TP
166     .BI -vf \ file
167     Get view parameters from
168     .I file,
169 greg 1.3 which may be a picture or a file created by rvu (with the "view" command).
170 greg 1.1 .TP
171     .BI -x \ res
172     Set the maximum x resolution to
173     .I res.
174     .TP
175     .BI -y \ res
176     Set the maximum y resolution to
177     .I res.
178     .TP
179     .BI -pa \ rat
180     Set the pixel aspect ratio (height over width) to
181     .I rat.
182     Either the x or the y resolution will be reduced so that the pixels have
183     this ratio for the specified view.
184     If
185     .I rat
186     is zero, then the x and y resolutions will adhere to the given maxima.
187     .TP
188     .BI -ps \ size
189     Set the pixel sample spacing to the integer
190     .I size.
191     This specifies the sample spacing (in pixels) for adaptive subdivision
192     on the image plane.
193     .TP
194     .BI -pt \ frac
195     Set the pixel sample tolerance to
196     .I frac.
197     If two samples differ by more than this amount, a third
198     sample is taken between them.
199     .TP
200     .BI -pj \ frac
201     Set the pixel sample jitter to
202     .I frac.
203     Distributed ray-tracing performs anti-aliasing by randomly sampling
204     over pixels.
205     A value of one will randomly distribute samples over full
206     pixels.
207     A value of zero samples pixel centers only.
208     A value between zero and one is usually best
209     for low-resolution images.
210     .TP
211     .BI -pm \ frac
212     Set the pixel motion blur to
213     .I frac.
214     In an animated sequence, the exact view will be blurred between the previous
215     view and the next view as though a shutter were open this fraction of a
216     frame time.
217     (See the
218     .I \-S
219     option regarding animated sequences.)\0
220     The first view will be blurred according to the difference between the
221     initial view set on the command line and the first view taken from the
222     standard input.
223     It is not advisable to use this option in combination with the
224     .I pmblur(1)
225     program, since one takes the place of the other.
226     However, it may improve results with
227     .I pmblur
228     to use a very small fraction with the
229     .I \-pm
230     option, to avoid the ghosting effect of too few time samples.
231     .TP
232 greg 1.4 .BI -pd \ dia
233     Set the pixel depth-of-field aperture to a diameter of
234     .I dia
235     (in world coordinates).
236     This will be used in conjunction with the view focal distance, indicated
237     by the length of the view direction vector given in the
238     .I \-vd
239     option.
240     It is not advisable to use this option in combination with the
241     .I pdfblur(1)
242     program, since one takes the place of the other.
243     However, it may improve results with
244     .I pdfblur
245     to use a very small fraction with the
246     .I \-pd
247     option, to avoid the ghosting effect of too few samples.
248     .TP
249 greg 1.1 .BI -dj \ frac
250     Set the direct jittering to
251     .I frac.
252     A value of zero samples each source at specific sample points
253     (see the
254     .I \-ds
255     option below), giving a smoother but somewhat less accurate
256     rendering.
257     A positive value causes rays to be distributed over each
258     source sample according to its size, resulting in more accurate
259     penumbras.
260     This option should never be greater than 1, and may even
261     cause problems (such as speckle) when the value is smaller.
262     A warning about aiming failure will issued if
263     .I frac
264     is too large.
265     It is usually wise to turn off image sampling when using
266     direct jitter by setting -ps to 1.
267     .TP
268     .BI -ds \ frac
269     Set the direct sampling ratio to
270     .I frac.
271     A light source will be subdivided until
272     the width of each sample area divided by the distance
273     to the illuminated point is below this ratio.
274     This assures accuracy in regions close to large area sources
275     at a slight computational expense.
276     A value of zero turns source subdivision off, sending at most one
277     shadow ray to each light source.
278     .TP
279     .BI -dt \ frac
280     Set the direct threshold to
281     .I frac.
282     Shadow testing will stop when the potential contribution of at least
283     the next and at most all remaining light source samples is less than
284     this fraction of the accumulated value.
285     (See the
286     .I \-dc
287     option below.)\0
288     The remaining light source contributions are approximated
289     statistically.
290     A value of zero means that all light source samples will be tested for shadow.
291     .TP
292     .BI \-dc \ frac
293     Set the direct certainty to
294     .I frac.
295     A value of one guarantees that the absolute accuracy of the direct calculation
296     will be equal to or better than that given in the
297     .I \-dt
298     specification.
299     A value of zero only insures that all shadow lines resulting in a contrast
300     change greater than the
301     .I \-dt
302     specification will be calculated.
303     .TP
304     .BI -dr \ N
305     Set the number of relays for secondary sources to
306     .I N.
307     A value of 0 means that secondary sources will be ignored.
308     A value of 1 means that sources will be made into first generation
309     secondary sources; a value of 2 means that first generation
310     secondary sources will also be made into second generation secondary
311     sources, and so on.
312     .TP
313     .BI -dp \ D
314     Set the secondary source presampling density to D.
315     This is the number of samples per steradian
316     that will be used to determine ahead of time whether or not
317     it is worth following shadow rays through all the reflections and/or
318     transmissions associated with a secondary source path.
319     A value of 0 means that the full secondary source path will always
320     be tested for shadows if it is tested at all.
321     .TP
322     .BR \-dv
323     Boolean switch for light source visibility.
324     With this switch off, sources will be black when viewed directly
325     although they will still participate in the direct calculation.
326     This option may be desirable in conjunction with the
327     .I \-i
328     option so that light sources do not appear in the output.
329     .TP
330     .BI -sj \ frac
331     Set the specular sampling jitter to
332     .I frac.
333     This is the degree to which the highlights are sampled
334     for rough specular materials.
335     A value of one means that all highlights will be fully sampled
336     using distributed ray tracing.
337     A value of zero means that no jittering will take place, and all
338     reflections will appear sharp even when they should be diffuse.
339     This may be desirable when used in combination with image sampling
340     (see
341     .I \-ps
342     option above) to obtain faster renderings.
343     .TP
344     .BI -st \ frac
345     Set the specular sampling threshold to
346     .I frac.
347     This is the minimum fraction of reflection or transmission, under which
348     no specular sampling is performed.
349     A value of zero means that highlights will always be sampled by
350     tracing reflected or transmitted rays.
351     A value of one means that specular sampling is never used.
352     Highlights from light sources will always be correct, but
353     reflections from other surfaces will be approximated using an
354     ambient value.
355     A sampling threshold between zero and one offers a compromise between image
356     accuracy and rendering time.
357     .TP
358     .BR -bv
359     Boolean switch for back face visibility.
360     With this switch off, back faces of opaque objects will be invisible
361     to all rays.
362     This is dangerous unless the model was constructed such that
363     all surface normals on opaque objects face outward.
364     Although turning off back face visibility does not save much
365     computation time under most circumstances, it may be useful as a
366     tool for scene debugging, or for seeing through one-sided walls from
367     the outside.
368     This option has no effect on transparent or translucent materials.
369     .TP
370     .BI -av " red grn blu"
371     Set the ambient value to a radiance of
372     .I "red grn blu".
373     This is the final value used in place of an
374     indirect light calculation.
375     If the number of ambient bounces is one or greater and the ambient
376     value weight is non-zero (see
377     .I -aw
378     and
379     .I -ab
380     below), this value may be modified by the computed indirect values
381     to improve overall accuracy.
382     .TP
383     .BI -aw \ N
384     Set the relative weight of the ambient value given with the
385     .I -av
386     option to
387     .I N.
388     As new indirect irradiances are computed, they will modify the
389     default ambient value in a moving average, with the specified weight
390     assigned to the initial value given on the command and all other
391     weights set to 1.
392     If a value of 0 is given with this option, then the initial ambient
393     value is never modified.
394     This is the safest value for scenes with large differences in
395     indirect contributions, such as when both indoor and outdoor
396     (daylight) areas are visible.
397     .TP
398     .BI -ab \ N
399     Set the number of ambient bounces to
400     .I N.
401     This is the maximum number of diffuse bounces
402     computed by the indirect calculation.
403     A value of zero implies no indirect calculation.
404     .TP
405     .BI -ar \ res
406     Set the ambient resolution to
407     .I res.
408     This number will determine the maximum density of ambient values
409     used in interpolation.
410     Error will start to increase on surfaces spaced closer than
411     the scene size divided by the ambient resolution.
412     The maximum ambient value density is the scene size times the
413     ambient accuracy (see the
414     .I \-aa
415     option below) divided by the ambient resolution.
416     The scene size can be determined using
417     .I getinfo(1)
418     with the
419     .I \-d
420     option on the input octree.
421     A value of zero is interpreted as unlimited resolution.
422     .TP
423     .BI -aa \ acc
424     Set the ambient accuracy to
425     .I acc.
426     This value will approximately equal the error
427     from indirect illuminance interpolation.
428     A value of zero implies no interpolation.
429     .TP
430     .BI -ad \ N
431     Set the number of ambient divisions to
432     .I N.
433     The error in the Monte Carlo calculation of indirect
434     illuminance will be inversely proportional to the square
435     root of this number.
436     A value of zero implies no indirect calculation.
437     .TP
438     .BI -as \ N
439     Set the number of ambient super-samples to
440     .I N.
441     Super-samples are applied only to the ambient divisions which
442     show a significant change.
443     .TP
444     .BI -af \ fname
445     Set the ambient file to
446     .I fname.
447     This is where indirect illuminance will be stored and retrieved.
448     Normally, indirect illuminance values are kept in memory and
449     lost when the program finishes or dies.
450     By using a file, different invocations can share illuminance
451     values, saving time in the computation.
452     Also, by creating an ambient file during a low resolution rendering,
453     better results can be obtained in a second high resolution pass.
454     The ambient file is in a machine-independent binary format
455     which may be examined with
456     .I lookamb(1).
457     .IP
458     The ambient file may also be used as a means of communication and
459     data sharing between simultaneously executing processes.
460     The same file may be used by multiple processes, possibly running on
461     different machines and accessing the file via the network (ie.
462     .I nfs(4)).
463     The network lock manager
464     .I lockd(8)
465     is used to insure that this information is used consistently.
466     .IP
467     If any calculation parameters are changed or the scene
468     is modified, the old ambient file should be removed so that
469     the calculation can start over from scratch.
470     For convenience, the original ambient parameters are listed in the
471     header of the ambient file.
472     .I Getinfo(1)
473     may be used to print out this information.
474     .TP
475 greg 1.7 .BI -ae \ mod
476 greg 1.1 Append
477 greg 1.7 .I mod
478 greg 1.1 to the ambient exclude list,
479     so that it will not be considered during the indirect calculation.
480     This is a hack for speeding the indirect computation by
481     ignoring certain objects.
482     Any object having
483 greg 1.7 .I mod
484 greg 1.1 as its modifier will get the default ambient
485     level rather than a calculated value.
486 greg 1.7 Any number of excluded modifiers may be given, but each
487 greg 1.1 must appear in a separate option.
488     .TP
489 greg 1.7 .BI -ai \ mod
490 greg 1.1 Add
491 greg 1.7 .I mod
492 greg 1.1 to the ambient include list,
493     so that it will be considered during the indirect calculation.
494     The program can use either an include list or an exclude
495     list, but not both.
496     .TP
497     .BI -aE \ file
498     Same as
499     .I \-ae,
500 greg 1.7 except read modifiers to be excluded from
501 greg 1.1 .I file.
502     The RAYPATH environment variable determines which directories are
503     searched for this file.
504 greg 1.7 The modifier names are separated by white space in the file.
505 greg 1.1 .TP
506     .BI -aI \ file
507     Same as
508     .I \-ai,
509 greg 1.7 except read modifiers to be included from
510 greg 1.1 .I file.
511     .TP
512     .BI -me " rext gext bext"
513     Set the global medium extinction coefficient to the indicated color,
514     in units of 1/distance (distance in world coordinates).
515     Light will be scattered or absorbed over distance according to
516     this value.
517     The ratio of scattering to total scattering plus absorption is set
518     by the albedo parameter, described below.
519     .TP
520     .BI -ma " ralb galb balb"
521     Set the global medium albedo to the given value between 0\00\00
522     and 1\01\01.
523     A zero value means that all light not transmitted by the medium
524     is absorbed.
525     A unitary value means that all light not transmitted by the medium
526     is scattered in some new direction.
527     The isotropy of scattering is determined by the Heyney-Greenstein
528     parameter, described below.
529     .TP
530     .BI \-mg \ gecc
531     Set the medium Heyney-Greenstein eccentricity parameter to
532     .I gecc.
533     This parameter determines how strongly scattering favors the forward
534     direction.
535     A value of 0 indicates perfectly isotropic scattering.
536     As this parameter approaches 1, scattering tends to prefer the
537     forward direction.
538     .TP
539     .BI \-ms \ sampdist
540     Set the medium sampling distance to
541     .I sampdist,
542     in world coordinate units.
543     During source scattering, this will be the average distance between
544     adjacent samples.
545     A value of 0 means that only one sample will be taken per light
546     source within a given scattering volume.
547     .TP
548     .BR \-i
549     Boolean switch to compute irradiance rather than radiance values.
550     This only affects the final result, substituting a Lambertian
551     surface and multiplying the radiance by pi.
552     Glass and other transparent surfaces are ignored during this stage.
553     Light sources still appear with their original radiance values,
554     though the
555     .I \-dv
556     option (above) may be used to override this.
557     .TP
558 greg 1.10 .BR \-u
559     Boolean switch to control uncorrelated random sampling.
560 greg 1.9 When "off", a low-discrepancy sequence is used, which reduces
561     variance but can result in a brushed appearance in specular highlights.
562     When "on", pure Monte Carlo sampling is used in all calculations.
563     .TP
564 greg 1.1 .BI -lr \ N
565     Limit reflections to a maximum of
566     .I N.
567 greg 1.8 If
568     .I N
569     is zero, then Russian roulette is used for ray
570     termination, and the
571     .I -lw
572     setting (below) must be positive.
573     If N is a negative integer, then this sets the upper limit
574     of reflections past which Russian roulette will not be used.
575     In scenes with dielectrics and total internal reflection,
576     a setting of 0 (no limit) may cause a stack overflow.
577 greg 1.1 .TP
578     .BI -lw \ frac
579     Limit the weight of each ray to a minimum of
580     .I frac.
581 greg 1.8 During ray-tracing, a record is kept of the estimated contribution
582     (weight) a ray would have in the image.
583     If this weight is less than the specified minimum and the
584     .I -lr
585     setting (above) is positive, the ray is not traced.
586     Otherwise, Russian roulette is used to
587     continue rays with a probability equal to the ray weight
588     divided by the given
589     .I frac.
590 greg 1.1 .TP
591     .BI -S \ seqstart
592     Instead of generating a single picture based only on the view
593     parameters given on the command line, this option causes
594     .I rpict
595     to read view options from the standard input and for each line
596     containing a valid view specification, generate a corresponding
597     picture.
598     This option is most useful for generating animated sequences, though
599     it may also be used to control rpict from a remote process for
600     network-distributed rendering.
601     .I Seqstart
602     is a positive integer that will be associated with the first output
603     frame, and incremented for successive output frames.
604     By default, each frame is concatenated to the output stream, but it
605     is possible to change this action using the
606     .I \-o
607     option (described below).
608     Multiple frames may be later extracted from the output using
609     .I ra_rgbe(1).
610     .IP
611     Note that the octree may not be read from the standard input when
612     using this option.
613     .TP
614     .BI -o \ fspec
615     Send the picture(s) to the file(s) given by
616     .I fspec
617     instead of the standard output.
618     If this option is used in combination with
619     .I \-S
620     and
621     .I fspec
622     contains an integer field for
623     .I printf(3)
624     (eg. "%03d") then the actual output file name will include
625     the current frame number.
626     .I Rpict
627     will not allow a picture file to be clobbered (overwritten)
628     with this option.
629     If an image in a sequence already exists
630     .I (\-S
631     option),
632     .I rpict
633     will skip until it reaches an image that doesn't, or the end of
634     the sequence.
635     This is useful for running rpict on multiple machines or processors
636     to render the same sequence, as each process will skip to the next
637     frame that needs rendering.
638     .TP
639     .BI -r \ fn
640     Recover pixel information from the file
641     .I fn.
642     If the program gets killed during picture generation, the information
643     may be recovered using this option.
644     The view parameters and picture dimensions are also recovered from
645     .I fn
646     if possible.
647     The other options should be identical to those which created
648     .I fn,
649     or an inconsistent picture may result.
650     If
651     .I fn
652     is identical to the file specification given with the
653     .I \-o
654     option,
655     .I rpict
656     will rename the file prior to copying its contents.
657     This insures that the old file is not overwritten accidentally.
658     (See also the
659     .I \-ro
660     option, below.)\0
661     .IP
662     If
663     .I fn
664     is an integer and the recover option is used in combination with the
665     .I \-S
666     option, then
667     .I rpict
668     skips a number of view specifications on its input equal to the
669     difference between
670     .I fn
671     and
672     .I seqstart.
673     .I Rpict
674     then performs a recovery operation on the file constructed from the
675     frame number
676     .I fn
677     and the output file specification given with the
678     .I \-o
679     option.
680     This provides a convenient mechanism for recovering in the middle of
681     an aborted picture sequence.
682     .IP
683     The recovered file
684     will be removed if the operation is successful.
685     If the recover operation fails (due to lack of disk space)
686     and the output file and recover file specifications
687     are the same, then the original information may be left in a
688     renamed temporary file.
689     (See FILES section, below.)\0
690     .TP
691     .BI -ro \ fspec
692     This option causes pixel information to be recovered from and
693     subsequently returned to the picture file
694     .I fspec.
695     The effect is the same as specifying identical recover and output
696     file names with the
697     .I \-r
698     and
699     .I \-o
700     options.
701     .TP
702     .BI -z \ fspec
703     Write pixel distances out to the file
704     .I fspec.
705     The values are written as short floats, one per pixel in scanline order,
706     as required by
707     .I pinterp(1).
708     Similar to the
709     .I \-o
710     option, the actual file name will be constructed using
711     .I printf
712     and the frame number from the
713     .I \-S
714     option.
715     If used with the
716     .I \-r
717     option,
718     .I \-z
719     also recovers information from an aborted rendering.
720     .TP
721     .BI \-P \ pfile
722     Execute in a persistent mode, using
723     .I pfile
724     as the control file.
725     This option must be used together with
726     .I \-S,
727     and is incompatible with the recover option
728     .I (\-r).
729     Persistent execution means that after reaching end-of-file on
730     its input,
731     .I rpict
732     will fork a child process that will wait for another
733     .I rpict
734     command with the same
735     .I \-P
736     option to attach to it.
737     (Note that since the rest of the command line options will be those
738     of the original invocation, it is not necessary to give any arguments
739     besides
740     .I \-P
741     for subsequent calls.)
742     Killing the process is achieved with the
743     .I kill(1)
744     command.
745     (The process ID in the first line of
746     .I pfile
747     may be used to identify the waiting
748     .I rpict
749     process.)
750     This option may be less useful than the
751     .I \-PP
752     variation, explained below.
753     .TP
754     .BI \-PP \ pfile
755     Execute in continuous-forking persistent mode, using
756     .I pfile
757     as the control file.
758     The difference between this option and the
759     .I \-P
760     option described above is the creation of multiple duplicate
761     processes to handle any number of attaches.
762     This provides a simple and reliable mechanism of memory sharing
763     on most multiprocessing platforms, since the
764     .I fork(2)
765     system call will share memory on a copy-on-write basis.
766     This option may be used with
767     .I rpiece(1)
768     to efficiently render a single image using multiple processors
769     on the same host.
770     .TP
771     .BI -t \ sec
772     Set the time between progress reports to
773     .I sec.
774     A progress report writes the number of rays traced, the percentage
775     completed, and the CPU usage to the standard error.
776     Reports are given either automatically after the specified interval,
777     or when the process receives a continue (-CONT) signal (see
778     .I kill(1)).
779     A value of zero turns automatic reporting off.
780     .TP
781     .BI -e \ efile
782     Send error messages and progress reports to
783     .I efile
784     instead of the standard error.
785     .TP
786     .BR \-w
787     Boolean switch for warning messages.
788     The default is to print warnings, so the first appearance of
789     this option turns them off.
790     .SH EXAMPLE
791     rpict -vp 10 5 3 -vd 1 -.5 0 scene.oct > scene.pic
792     .PP
793     rpict -S 1 -o frame%02d.pic scene.oct < keyframes.vf
794     .SH ENVIRONMENT
795     RAYPATH the directories to check for auxiliary files.
796     .SH FILES
797 greg 1.6 /tmp/rtXXXXXX common header information for picture sequence
798 greg 1.1 .br
799     rfXXXXXX temporary name for recover file
800     .SH DIAGNOSTICS
801     If the program terminates from an input related error, the exit status
802     will be 1.
803     A system related error results in an exit status of 2.
804     If the program receives a signal that is caught, it will exit with a status
805     of 3.
806     In each case, an error message will be printed to the standard error, or
807     to the file designated by the
808     .I \-e
809     option.
810     .SH AUTHOR
811     Greg Ward
812     .SH "SEE ALSO"
813 greg 1.4 getinfo(1), lookamb(1), oconv(1), pdfblur(1), pfilt(1), pinterp(1), pmblur(1),
814 greg 1.3 printf(3), ra_rgbe(1), rad(1), rtrace(1), rvu(1)
