root/radiance/ray/doc/man/man1/rpict.1
Tue Jun 14 03:34:14 2005 UTC (18 years, 11 months ago) by greg
Diff to previous 1.9 , to selected 1.5
Had to change new -R rendering option to -u to avoid conflict with rpiece
Mon Jun 13 20:07:55 2005 UTC (18 years, 11 months ago) by greg
Changes since 1.8: +7 -1 lines
Diff to previous 1.8 , to selected 1.5
Tue May 31 18:01:08 2005 UTC (19 years ago) by greg
Changes since 1.7: +20 -4 lines
Diff to previous 1.7 , to selected 1.5
Thu Apr 14 18:04:12 2005 UTC (19 years, 1 month ago) by greg
Changes since 1.6: +10 -10 lines
Diff to previous 1.6 , to selected 1.5
Wed Feb 16 05:40:06 2005 UTC (19 years, 3 months ago) by greg
Diff to previous 1.5
Tue Jan 18 01:13:23 2005 UTC (19 years, 4 months ago) by greg
Changes since 1.4: +4 -1 lines
Diff to previous 1.4
Added comment about -vd length being used by -pd option
Tue Jan 18 00:33:15 2005 UTC (19 years, 4 months ago) by greg
Changes since 1.3: +19 -2 lines
Thu Jan 1 19:31:45 2004 UTC (20 years, 5 months ago) by greg
Tue Dec 9 15:59:07 2003 UTC (20 years, 5 months ago) by greg
Fixed RCSid specification
Tue Mar 11 19:20:21 2003 UTC (21 years, 2 months ago) by greg
Diff to selected 1.5
Added documentation to repository
